    MMM-xiaomi - Temperature and Humidity from your smarthome
    142 Posts 28 Posters 242.4k Views 28 Watching
      mirko3000
      Also it only supports xiaomi temperature sensors, so if you don’t have any registered on your gateway it will not show anything (Keeping in “Connecting to gateway…” mode).
      C 1 Reply Last reply
      • cowboysdudeC
        cowboysdude Module Developer @mirko3000
        @mirko3000 Thank you for this!! Exactly what I have been looking for… this is truly awesome!
        I would like about 9 of these sensors… do I also need the gateway as well?
        B 1 Reply Last reply
          barnosch @cowboysdude
          @cowboysdude : As i read, the Gateway is mandatory.
          But as always Xiaomi is really cheap. GW is about 25$ i guess.
          I ordered some temp sensors. Can’t wait to test the stuff.
            cxlwill @mirko3000
            @mirko3000 Well, I have temp&hum sensor and it works well with Home Assistant and Homebridge. So I think the API itself is OK. I will check the log. Nice plugin anyway. Maybe we can extend it to more Xiaomi devices.
            • cowboysdudeC
              cowboysdude Module Developer @barnosch
              @barnosch said in MMM-xiaomi - Temperature and Humidity from your smarthome:
              I saw the gateway was inexpensive so if I can find a US plug adapter for this I will be ordering the gateway and about 9 of the temp sensors :)
              • A
                Albert2002
                How to figure out the id of the sensor?
                  mirko3000
                  Well the IDs show up in your magic mirror - the problem is to identify which ID belongs to which sensor. I guessed them by checking the temperature, still I agree that this is not very convenient so far. Looking out for a better solution…
                  • A
                    Albert2002
                    Thank you for your replay!
                    When I do so I get a “Connecting to XIAOMI gatway…”
                    Connecting to XIAOMI gatway..
                    As far as I understand "ENETUNREACH " means Network unreachable. I can successfully ping the Gatway at 192.168.2.107 via VNC & LX Terminal.
                    Do I have to set up something on my Gateway first?
                    Any idea what to do?
                    This is what my error log says:
                    ERROR! Could not find main module js file for RepositoryForRC
                    ERROR! Could not find main module js file for async
                    { Error: send ENETUNREACH 192.168.2.107:54321
                        at Object.exports._errnoException (util.js:1050:11)
                        at exports._exceptionWithHostPort (util.js:1073:20)
                        at SendWrap.afterSend [as oncomplete] (dgram.js:402:11)
                      code: 'ENETUNREACH',
                      errno: 'ENETUNREACH',
                      syscall: 'send',
                      address: '192.168.2.107',
                      port: 54321 }
                    My mm out:
                    Starting MagicMirror: v2.1.3
                    Loading config ...
                    Loading module helpers ...
                    Module helper loaded: MMM-Remote-Control
                    Module helper loaded: MMM-xiaomi
                    All module helpers loaded.
                    Server started ...
                    Connecting socket for: MMM-Remote-Control
                    Starting node helper for: MMM-Remote-Control
                    Connecting socket for: MMM-xiaomi
                    Starting xiaomi helper
                    Launching application.
                    Triggering Xiaomi Gateway upate
                    • A
                      Albert2002
                      I’ve made a completely new Raspian & MM installation. No other modules installed. the default modules disabled in the config.js.
                      I Still get no connection. Im running the Home Gatewy V3 in Dev mode. Do I have to change any settings on my router or somewhere else?
                      Right now I get different error messages. Maybe it helps. I would love to see this module running!
                      mm-out:
                      > magicmirror@2.1.3 start /home/pi/MagicMirror
                      > sh run-start.sh
                      Loading config ...
                      You're using a full whitelist configuration to allow for all IPs
                      Server started ...
                      MagicMirror error log:
                      Error: Token could not be auto-discovered
                          at Device._tokenResolve (/home/pi/MagicMirror/modules/MMM-xiaomi/node_modules/miio/lib/device.js:141:13)
                          at Device._onMessage (/home/pi/MagicMirror/modules/MMM-xiaomi/node_modules/miio/lib/device.js:80:9)
                          at emitTwo (events.js:106:13)
                          at Socket.emit (events.js:194:7)
                          at UDP.onMessage [as onmessage] (dgram.js:545:8)
                      MagicMirror out:
                      > sh run-start.sh
                      Loading config ...
                      Server started ...
                      mm error log:
                      { Error: listen EADDRINUSE 127.0.0.1:8080
                          at Server.setupListenHandle [as _listen2] (net.js:1263:14)
                          at listenInCluster (net.js:1304:12)
                          at doListen (net.js:1428:7)
                          at GetAddrInfoReqWrap.asyncCallback [as callback] (dns.js:62:16)
                          at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:78:10)
                        code: 'EADDRINUSE',
                        errno: 'EADDRINUSE',
                        syscall: 'listen',
                        address: '127.0.0.1',
                        port: 8080 }
                        mirko3000
                        Hey Albert,
                        I think I have solved your issue: not all gateways seem to allow auto-discovery without authentification via a security token. I have added an additional configuration parameter now where you can provide your token:
                        https://github.com/mirko3000/MMM-xiaomi
                        Update the module and follow the description at the bottom:
                        https://github.com/mirko3000/MMM-xiaomi#authentification
                        Hope that works.
                        Best regards.
                        • A
                          Albert2002
                          Hi Mirko,
                          thank you for your work! I really appreciate this!
                          I’ve updated the module and installed the miio command line tools (with sudo)in the same directory. Or do I Have to install the miio command line tools in a different directory?
                          How ever, when am running miio command line tools i get
                          pi@raspberrypi:~/MagicMirror/modules/MMM-xiaomi $ miio --discover
                           INFO  Discovering devices. Press Ctrl+C to stop.
                          Device ID: 52238776
                          Model info: Unknown
                          Address: 192.168.2.107
                          Token: ???
                          Support: Unknown
                          My id I’ve discovered seams to be a different style then the one in your example.
                          After this I added the device id to my config:
                          devices: [{ id: '52238776', name: 'Wohnzimmer' }]
                          I still see the same as before.
                          mm error:
                          mm-out:
                          > sh run-start.sh
                          Loading config ...
                          Server started ...
                          MagicMirror error:
                            code: 'EADDRINUSE',
                            syscall: 'listen',
                            port: 8080 }
                          MagicMirror out:
                          > sh run-start.sh
                          Loading config ...
                          Server started ...
                            barnosch
                            God damnit.
                            Got a letter from the customs today, that my package from China arrived.
                            Sadly they are closing Fridays at 2.30pm. The letter arrived at 2.45pm.
                            So no chance to fetch it anymore.
                            The whole weekend is now useless!
                            Let`s see if i have also trouble …
                            • A
                              Albert2002
                              Maybe you can get it tomorrow? Would be great to figure out.
                              Something crossed my mind. When I set up the Developer mode in the Gateway there is a password too. I know that I need this one for OpenHAB. Maybe I need it for this module as well?
                              M 1 Reply Last reply
                                mirko3000 @Albert2002
                                So I just read through the documentation of miio and found this:
                                https://github.com/aholstenson/miio/blob/master/docs/management.md#getting-the-token-of-a-device
                                or:
                                https://github.com/aholstenson/miio/blob/master/docs/management.md#setting-the-token-of-a-device
                                My device seems to provide the token “via auto-token”, in your case it seems it does not. Maybe try either of the above.
                                IDs are same with me, maybe my documentation is wrong here.
                                  mirko3000
                                  When I run the discover tool I get the following:
                                  Device ID: 56804143
                                  Model info: Unknown
                                  Address: 192.168.0.9 (xiaomi-gateway.fritz.box)
                                  Token: cfbdb315c0825ccc971918e36923febe via auto-token
                                  Support: Unknown
                                  Device ID: 158d0001635bb3
                                  Model info: lumi.sensor_ht (sensor)
                                  Address: Owned by 56804143
                                  Token: Automatic via parent device
                                  Support: At least basic
                                  • A
                                    Albert2002
                                    I am a step ahead!
                                    I followed the instructions to get the token “Getting the token when using the Mi Home app”
                                    This was working. I could see all the connected devices to the Gateway.
                                    pi@raspberrypi:~/MagicMirror/modules/MMM-xiaomi $ miio --discover --sync
                                    Device ID: 52238776
                                    Model info: Unknown
                                    Address: 192.168.13.1
                                    Token: 6eea5ac1eb475bfedbfff98aab7c2bc7 via auto-token
                                    Support: Unknown
                                    Device ID: 158d000119fcb2
                                    Model info: lumi.magnet (magnet)
                                    Address: Owned by 52238776
                                    Device ID: 158d00013e28ee
                                    Model info: lumi.plug (power-plug)
                                    Device ID: 158d00015aa973
                                    Model info: lumi.switch (controller)
                                    Device ID: 158d00015736a8
                                    At this point I had to switch over to the Pi with the installed MagicMirror:
                                    pi@MagicMirror:~ $ miio --discover
                                    Device ID: 52238776
                                    Model info: Unknown
                                    Token: ???
                                    Support: Unknown
                                    I’ve updated the Token as described:
                                    pi@MagicMirror:~ $ miio --update 52238776 --token 6eea5ac1eb475bfedbfff98aab7c2bc7
                                     INFO  Attempting to update 52238776
                                     INFO  Device updated
                                    I’ve searched for devices again. Now with success!
                                    Device ID: 52238776
                                    Model info: Unknown
                                    Token: 6eea5ac1eb475bfedbfff98aab7c2bc7 via stored token
                                    Support: Unknown
                                    The problem so far is, that I still don’t get any informations visible in MM. I’ve tried ‘158d00015736a8’ and as well ‘52238776’ as id.
                                    The second problem is, that I’ve lost the Gateway in my Mi Home app after updating the Token!
                                    The question is, how to copy ( Store?) over the Token to a different Machine?
                                    mm error:
                                    error: Token could not be auto-discovered
                                      mirko3000
                                      Ok at least some progress. So first to enable your manual token just update the configuration:
                                      	 interval: 30,
                                      	 gatewayIP: '192.168.13.1',
                                      	 gatewayToken: '6eea5ac1eb475bfedbfff98aab7c2bc7',
                                      	 devices : [{
                                      You only need the IDs from your sensors, not the gateway.
                                      About the Mi Home App and your lost token, I would try once this works to reconfigure your gateway with the Mi Home app, and then try to fetch the auto-token again (in your first sample it seems to provide auto-token).
                                      • A
                                        Albert2002
                                        I did the steps again to get the (new) Token. Now, I have a new Token and the Gateway again in my Mi Home app. I didn’t updated the Token on the different machine this time.
                                        I’ve tried out your new config. I still don’t see more than before on the MM, but I don’t have an error log as well, which make it a bit more harder.
                                        I have checked the IP address of the Gateway, its still the same. Dev is still enabled.
                                        My config with the new Token.
                                        		module: 'MMM-xiaomi',
                                        		position: 'bottom_left',
                                        		header: 'Temperatur / Feuchtigkeit',  // This is optional
                                        			interval: 30,
                                        			gatewayIP: '192.168.2.107',
                                        			gatewayToken: '050591e66a82f7adc92bfa6b03058cdb',
                                        			devices: [{ id: '158d00015736a8', name: 'Wohnzimmer' }]
                                        Edit:
                                        I get a error when I try to discover with miio:
                                        pi@MagicMirror:~/MagicMirror/modules/MMM-xiaomi/node_modules/miio $ miio --discover
                                        Device ID: 52238776
                                        Model info: Unknown
                                        Support: Unknown
                                        (node:3626) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 1): Error: Call to device timed out
                                        • A
                                          Albert2002
                                          Where did miio stored the Token?
                                          The Token Miio used “Token: 6eea5ac1eb475bfedbfff98aab7c2bc7 via stored token”
                                          is the old one! the new one is 050591e66a82f7adc92bfa6b03058cdb
                                            mirko3000
                                            Hmm not sure about miio details, I just know that you can sync the tokens via
                                            Else I would try manually setting to the correct (new) token.
                                            For the MM: try to uncomment line 51 in node_helper.js, this logs all found devices. You could also add some more logs here to see where the program fails.
                                            • 1 / 8
