    MMM-xiaomi - Temperature and Humidity from your smarthome
    141 Posts 27 Posters 216.9k Views 27 Watching
    • cowboysdudeC Offline
      Good call… that company is going to be making a ton of smart things! :) Great job.
      Do you have a link to the module?
        barnosch
        Great. Looking forward for the module…
        Meanwhile i order some of the Xiaomi stuff in China ;)
          cxlwill
          Great work. But mine keeps looking for gateway. I’m pretty sure that the ip of GW is correct.
            mirko3000
            Sorry, forgot about the link:
            https://github.com/mirko3000/MMM-xiaomi
            @barnosch, @cxlwill: Did you check the logs? Anything showing up there?
              mirko3000
              Also it only supports xiaomi temperature sensors, so if you don’t have any registered on your gateway it will not show anything (Keeping in “Connecting to gateway…” mode).
                cowboysdude Module Developer @mirko3000
                @mirko3000 Thank you for this!! Exactly what I have been looking for… this is truly awesome!
                I would like about 9 of these sensors… do I also need the gateway as well?
                  barnosch @cowboysdude
                  @cowboysdude : As i read, the Gateway is mandatory.
                  But as always Xiaomi is really cheap. GW is about 25$ i guess.
                  I ordered some temp sensors. Can’t wait to test the stuff.
                    cxlwill @mirko3000
                    @mirko3000 Well, I have temp&hum sensor and it works well with Home Assistant and Homebridge. So I think the API itself is OK. I will check the log. Nice plugin anyway. Maybe we can extend it to more Xiaomi devices.
                      cowboysdude Module Developer @barnosch
                      @barnosch said in MMM-xiaomi - Temperature and Humidity from your smarthome:
                      I saw the gateway was inexpensive so if I can find a US plug adapter for this I will be ordering the gateway and about 9 of the temp sensors :)
                        Albert2002
                        How to figure out the id of the sensor?
                        • 14
                        • 15
                        • 1 / 15
