    MMM-xiaomi - Temperature and Humidity from your smarthome
    141 Posts 27 Posters 212.6k Views 27 Watching
      mirko3000
      Also it only supports xiaomi temperature sensors, so if you don’t have any registered on your gateway it will not show anything (Keeping in “Connecting to gateway…” mode).
      • cowboysdudeC Offline
        cowboysdude Module Developer @mirko3000
        @mirko3000 Thank you for this!! Exactly what I have been looking for… this is truly awesome!
        I would like about 9 of these sensors… do I also need the gateway as well?
          barnosch @cowboysdude
          @cowboysdude : As i read, the Gateway is mandatory.
          But as always Xiaomi is really cheap. GW is about 25$ i guess.
          I ordered some temp sensors. Can’t wait to test the stuff.
            cxlwill @mirko3000
            @mirko3000 Well, I have temp&hum sensor and it works well with Home Assistant and Homebridge. So I think the API itself is OK. I will check the log. Nice plugin anyway. Maybe we can extend it to more Xiaomi devices.
              cowboysdude Module Developer @barnosch
              @barnosch said in MMM-xiaomi - Temperature and Humidity from your smarthome:
              I saw the gateway was inexpensive so if I can find a US plug adapter for this I will be ordering the gateway and about 9 of the temp sensors :)
                Albert2002
                How to figure out the id of the sensor?
                  mirko3000
                  Well the IDs show up in your magic mirror - the problem is to identify which ID belongs to which sensor. I guessed them by checking the temperature, still I agree that this is not very convenient so far. Looking out for a better solution…
                    Albert2002
                    Thank you for your replay!
                    When I do so I get a “Connecting to XIAOMI gatway…”
                    Connecting to XIAOMI gatway..
                    As far as I understand "ENETUNREACH " means Network unreachable. I can successfully ping the Gatway at 192.168.2.107 via VNC & LX Terminal.
                    Do I have to set up something on my Gateway first?
                    Any idea what to do?
                    This is what my error log says:
                    ERROR! Could not find main module js file for RepositoryForRC
                    ERROR! Could not find main module js file for async
                    { Error: send ENETUNREACH 192.168.2.107:54321
                        at Object.exports._errnoException (util.js:1050:11)
                        at exports._exceptionWithHostPort (util.js:1073:20)
                        at SendWrap.afterSend [as oncomplete] (dgram.js:402:11)
                      code: 'ENETUNREACH',
                      errno: 'ENETUNREACH',
                      syscall: 'send',
                      address: '192.168.2.107',
                      port: 54321 }
                    My mm out:
                    Starting MagicMirror: v2.1.3
                    Loading config ...
                    Loading module helpers ...
                    Module helper loaded: MMM-Remote-Control
                    Module helper loaded: MMM-xiaomi
                    All module helpers loaded.
                    Server started ...
                    Connecting socket for: MMM-Remote-Control
                    Starting node helper for: MMM-Remote-Control
                    Connecting socket for: MMM-xiaomi
                    Starting xiaomi helper
                    Launching application.
                    Triggering Xiaomi Gateway upate
                      Albert2002
                      I’ve made a completely new Raspian & MM installation. No other modules installed. the default modules disabled in the config.js.
                      I Still get no connection. Im running the Home Gatewy V3 in Dev mode. Do I have to change any settings on my router or somewhere else?
                      Right now I get different error messages. Maybe it helps. I would love to see this module running!
                      mm-out:
                      > magicmirror@2.1.3 start /home/pi/MagicMirror
                      > sh run-start.sh
                      Loading config ...
                      You're using a full whitelist configuration to allow for all IPs
                      Server started ...
                      MagicMirror error log:
                      Error: Token could not be auto-discovered
                          at Device._tokenResolve (/home/pi/MagicMirror/modules/MMM-xiaomi/node_modules/miio/lib/device.js:141:13)
                          at Device._onMessage (/home/pi/MagicMirror/modules/MMM-xiaomi/node_modules/miio/lib/device.js:80:9)
                          at emitTwo (events.js:106:13)
                          at Socket.emit (events.js:194:7)
                          at UDP.onMessage [as onmessage] (dgram.js:545:8)
                      MagicMirror out:
                      > sh run-start.sh
                      Loading config ...
                      Server started ...
                      mm error log:
                      { Error: listen EADDRINUSE 127.0.0.1:8080
                          at Server.setupListenHandle [as _listen2] (net.js:1263:14)
                          at listenInCluster (net.js:1304:12)
                          at doListen (net.js:1428:7)
                          at GetAddrInfoReqWrap.asyncCallback [as callback] (dns.js:62:16)
                          at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:78:10)
                        code: 'EADDRINUSE',
                        errno: 'EADDRINUSE',
                        syscall: 'listen',
                        address: '127.0.0.1',
                        port: 8080 }
                        mirko3000
                        Hey Albert,
                        I think I have solved your issue: not all gateways seem to allow auto-discovery without authentification via a security token. I have added an additional configuration parameter now where you can provide your token:
                        https://github.com/mirko3000/MMM-xiaomi
                        Update the module and follow the description at the bottom:
                        https://github.com/mirko3000/MMM-xiaomi#authentification
                        Hope that works.
                        Best regards.
                        • 14
                        • 15
                        • 1 / 15
