    Copy and paste of text to nano config/config.js
    23 Posts 2 Posters 15.3k Views 2 Watching
    • I Offline
      IDCreate @Mykle1
      @Mykle1 Hi I tried yesterday and it did not work. I tried just now and it copied the code in replacement of the original current weather but it still did not work. please see below my config.js
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: "en",
      	timeFormat: 12,
      	units: "metric",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			header: "US Holidays",
      						symbol: "calendar-check-o ",
      			module: "compliments",
      			position: "lower_third"
      		module: "currentweather",
      		position: "top_right",	// This can be any of the regions.
      									// Best results in left or right regions.
      			locationID: "", //Location ID from http://openweathermap.org/help/city_list.txt
      			appid: "abcde12345abcde12345abcde12345ab" //openweathermap.org API key.
      			module: "weatherforecast",
      			header: "Weather Forecast",
      				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "New York Times",
      				showSourceTitle: true,
      				showPublishDate: true
        Mykle1 Project Sponsor Module Developer @IDCreate
        @IDCreate
        My answer is above your question :-)
        • I Offline
          IDCreate @Mykle1
          @Mykle1 thanks that was what it looked like at the beginning and was not doing anything so I went ahead as suggested https://github.com/MichMich/MagicMirror/tree/master/modules/default/currentweather
          To test things out and to get things working you mentioned I needed an api key. So I went to the section information in the module set up a copy and past there example presuming that would be a working one.
          But unfortunately nothing happens, I thought if I was to simply post there code in replacement for mine to test it as above it would work. :-(
            @IDCreate said in Copy and paste of text to nano config/config.js:
            You presume incorrectly. That is an example. You need to go to openweathermap.org and sign up for your own API key. Get your locationID there at the same time. Enter those into your config
            I 1 Reply Last reply Reply Quote 1
            • I Offline
              IDCreate @Mykle1
              @Mykle1 ok thanks going there as we speak
                @IDCreate
                So. now your config entry should look like this:
                		locationID: "2639577",  // inside the quotes
                		appid: "YOUR API KEY GOES HERE",  // inside the quotes
                • I Offline
                  IDCreate @Mykle1
                  @Mykle1 thanks you’ve a fantastic help. I’m trying it now but If I’m unable to do something like this. I don’t know how I’m going to be able to move forward, well I will just keep trying.
                    Good attitude. You’ll get it.
                    I 1 Reply Last reply Reply Quote 2
                    • I Offline
                      IDCreate @Mykle1
                      @Mykle1 well I’ve done all you said, entered the locationID and put in the API KEY an it looks exactly like your code. I went to save it and the screen on my main screen where the mirror displayed the time, date and more just went blank.
                        @IDCreate
                        post any errors from your terminal
                        • I Offline
                          IDCreate @Mykle1
                          @Mykle1 you mean post the code from config.js?
                            No, but you can post that too. I mean copy and paste the output from your terminal window after you’ve tried to run the mirror
                            • I Offline
                              IDCreate @Mykle1
                              @Mykle1 ok I just thought it was a case of save the config.js and it would come up.
                              I’ll do that now
                                Yes, save the config, but then restart your MM
                                • I Offline
                                  IDCreate @Mykle1
                                  @Mykle1 Oh wow it’s working! :-) The time in the top right above the weather bit says 7.02am where the actual correct time on the left of the screen is 1.04am. Thanks I’m well pleased, its a start.
                                  Mykle1M 2 Replies Last reply Reply Quote 1
                                    @IDCreate
                                    That is the sunrise time. Notice the little icon that looks like a sunrise next to it. After sunrise you will get the sunset time and a sunset icon
                                      Ahh, the sweet sound of success! :-)
                                      • I Offline
                                        IDCreate @Mykle1
                                        @Mykle1 oh right ok haha, in that case I think I’ll call it a night for now and get some sleep. You’ve been an absolutely great help, I hope I’ve not been to much trouble. I’m not sure what time it is there but you certainly deserve a drink. :-)
                                          Good idea! Sleep well, mate
