    Copy and paste of text to nano config/config.js
    23 Posts 2 Posters 16.1k Views 2 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @IDCreate
      @IDCreate
      My answer is above your question :-)
      • I
        IDCreate @Mykle1
        @Mykle1 thanks that was what it looked like at the beginning and was not doing anything so I went ahead as suggested https://github.com/MichMich/MagicMirror/tree/master/modules/default/currentweather
        To test things out and to get things working you mentioned I needed an api key. So I went to the section information in the module set up a copy and past there example presuming that would be a working one.
        		module: "currentweather",
        		position: "top_right",	// This can be any of the regions.
        									// Best results in left or right regions.
        			locationID: "", //Location ID from http://openweathermap.org/help/city_list.txt
        			appid: "abcde12345abcde12345abcde12345ab" //openweathermap.org API key.
        But unfortunately nothing happens, I thought if I was to simply post there code in replacement for mine to test it as above it would work. :-(
        Mykle1M 1 Reply Last reply
        • Mykle1M
          @IDCreate said in Copy and paste of text to nano config/config.js:
          You presume incorrectly. That is an example. You need to go to openweathermap.org and sign up for your own API key. Get your locationID there at the same time. Enter those into your config
          I 1 Reply Last reply
          • I
            IDCreate @Mykle1
            @Mykle1 ok thanks going there as we speak
            • Mykle1M
              @IDCreate
              So. now your config entry should look like this:
              		locationID: "2639577",  // inside the quotes
              		appid: "YOUR API KEY GOES HERE",  // inside the quotes
              • I
                IDCreate @Mykle1
                @Mykle1 thanks you’ve a fantastic help. I’m trying it now but If I’m unable to do something like this. I don’t know how I’m going to be able to move forward, well I will just keep trying.
                • Mykle1M
                  Good attitude. You’ll get it.
                  Reply Quote 2
                  • I
                    IDCreate @Mykle1
                    @Mykle1 well I’ve done all you said, entered the locationID and put in the API KEY an it looks exactly like your code. I went to save it and the screen on my main screen where the mirror displayed the time, date and more just went blank.
                    • Mykle1M
                      @IDCreate
                      post any errors from your terminal
                      • I
                        IDCreate @Mykle1
                        @Mykle1 you mean post the code from config.js?
                        • Mykle1M
                          No, but you can post that too. I mean copy and paste the output from your terminal window after you’ve tried to run the mirror
                          • I
                            IDCreate @Mykle1
                            @Mykle1 ok I just thought it was a case of save the config.js and it would come up.
                            I’ll do that now
                            • Mykle1M
                              Yes, save the config, but then restart your MM
                              • I
                                IDCreate @Mykle1
                                @Mykle1 Oh wow it’s working! :-) The time in the top right above the weather bit says 7.02am where the actual correct time on the left of the screen is 1.04am. Thanks I’m well pleased, its a start.
                                Mykle1M 2 Replies Last reply
                                • Mykle1M
                                  @IDCreate
                                  That is the sunrise time. Notice the little icon that looks like a sunrise next to it. After sunrise you will get the sunset time and a sunset icon
                                  • Mykle1M
                                    Ahh, the sweet sound of success! :-)
                                    • I
                                      IDCreate @Mykle1
                                      @Mykle1 oh right ok haha, in that case I think I’ll call it a night for now and get some sleep. You’ve been an absolutely great help, I hope I’ve not been to much trouble. I’m not sure what time it is there but you certainly deserve a drink. :-)
                                      • Mykle1M
                                        Good idea! Sleep well, mate
