    All stocks modules are not working for me.
    14 Posts 8 Posters 8.9k Views 8 Watching
      sceletus
      Don’t know if it is related, but since I updated my version of MM, the stock tickers are no more working.
      I tried bith MMM-Stock and stock and nothing appears.
      Is it not related to a change in Yahoo API?
      Thanks in advance.
      Mitch1138M 1 Reply Last reply Reply Quote 0
      • Mitch1138M Offline
        Mitch1138 @sceletus
        I am having the same issue with Stocks and MMM-Stocks, they just stopped working. I think they stopped some time after I updated MM but I can be sure.
        Does anyone have any insight into this?
        Many thanks.
          dmcinnes Module Developer
          The Google API has been shut down, which is why the stocks module is not working. I’m not sure about the others…
            Pakmann
            stocks is using Google API which is Not longer supported.
            MMM Stock is using Yahoo API. Normally the module should works. On my MM the Module is no more visible. I try to debug the implemented stock datastream from Yahoo API and it works. I dont know why the module is not visible on screen
              Mykle1 Project Sponsor Module Developer @Pakmann
              @Pakmann said in All stocks modules are not working for me.:
              What is the url to the datastream?
              http://www.financial-hacker.com/bye-yahoo-and-thank-you-for-the-fish/
                Pakmann
                @Mykle1 i Setup the module for one example stock. In the Module file i delete the comment for debug url write to console.
                For this case my url see below. When i copy the url in browser i received all data.
                https://query.yahooapis.com/v1/public/yql?q=env%20'store%3A%2F%2Fdatatables.org%2Falltableswithkeys'%3B%20select%20*%20from%20yahoo.finance.quotes%20where%20symbol%20in%20('VOW3.DE')&format=json&diagnostics=true&callback=
                  https://query.yahooapis.com/v1/public/yql?q=env ‘store%3A%2F%2Fdatatables.org%2Falltableswithkeys’%3B select * from yahoo.finance.quotes where symbol in (‘VOW3.DE’)&format=json&diagnostics=true&callback=
                  I don’t get the data in a browser. It’s a download url to a txt file
                    Pakmann
                    @Mykle1 you are right, the data are forbidden, i can see an http403 in the basic data.
                    I tested this URL last week end of october. I was searching on the yahoo api and found the decription on yahoo. On yahoo i can take a look of the example. Today the data are empty too(see link before).
                    Last week i made some tests with a second MM project glancr. Glancr has an Stocks modul, which is based on yahoo too. The modul was implemented this year in august. It works last week, so that was the reason why i try to debug the MMM-Stock Modul.
                    I dont know why the service are down right now. In case of cancel the service, yahoo will not decripe her api i think. Maybe its temporally.
                      From what I’ve read online it looks as if both Google and Yahoo have abandoned their respective stock API’s and it doesn’t look as if they have any plans to reinstate them.
                        Dracarys
                        Yes. They both shut down their realtime finance API.
                        But this link still kinda works. Maybe someone can build a new module with it?
                        https://finance.google.com/finance?output=json&q=ETR.BMW
                        Cheers
