    All stocks modules are not working for me.
    14 Posts 8 Posters 9.8k Views 8 Watching
      Pakmann
      @Mykle1 i Setup the module for one example stock. In the Module file i delete the comment for debug url write to console.
      For this case my url see below. When i copy the url in browser i received all data.
      https://query.yahooapis.com/v1/public/yql?q=env%20'store%3A%2F%2Fdatatables.org%2Falltableswithkeys'%3B%20select%20*%20from%20yahoo.finance.quotes%20where%20symbol%20in%20('VOW3.DE')&format=json&diagnostics=true&callback=
        Mykle1 Project Sponsor Module Developer @Pakmann
        @Pakmann said in All stocks modules are not working for me.:
        https://query.yahooapis.com/v1/public/yql?q=env ‘store%3A%2F%2Fdatatables.org%2Falltableswithkeys’%3B select * from yahoo.finance.quotes where symbol in (‘VOW3.DE’)&format=json&diagnostics=true&callback=
        I don’t get the data in a browser. It’s a download url to a txt file
          Pakmann
          @Mykle1 you are right, the data are forbidden, i can see an http403 in the basic data.
          I tested this URL last week end of october. I was searching on the yahoo api and found the decription on yahoo. On yahoo i can take a look of the example. Today the data are empty too(see link before).
          Last week i made some tests with a second MM project glancr. Glancr has an Stocks modul, which is based on yahoo too. The modul was implemented this year in august. It works last week, so that was the reason why i try to debug the MMM-Stock Modul.
          I dont know why the service are down right now. In case of cancel the service, yahoo will not decripe her api i think. Maybe its temporally.
            From what I’ve read online it looks as if both Google and Yahoo have abandoned their respective stock API’s and it doesn’t look as if they have any plans to reinstate them.
              Dracarys
              Yes. They both shut down their realtime finance API.
              But this link still kinda works. Maybe someone can build a new module with it?
              https://finance.google.com/finance?output=json&q=ETR.BMW
              Cheers
                Mykle1 Project Sponsor Module Developer @Dracarys
                @Dracarys said in All stocks modules are not working for me.:
                Uhh, that is a link to download a txt file as well
                  A Former User
                  I don’t know anything about finance and stocks, So I cannot help about creating module about that.
                  Anyway, Before some Genius builds really nice one, you can use web widgets instead. (you can put the HTML codes into any iframe or static html module, if exists.)
                  I’ve got this for test.
                  To find the widget, just google it. there are plenties.
                    Jonathan5435
                    I recommend using MarketXLS.
                    They have regular updates and customer support.
                    It cost a little but it will save you time.
                    I had moved after Yahoo Finance API had been discontinued.
                      Dracarys
                      I use widgets from https://tradingview.com/widget/ now.
                      I think this is okay so far. And for free :)
