    VoiceControl module
    79 Posts 27 Posters 119.5k Views 29 Watching
      alexyak
      I’ve managed to create the VoiceControl module based on Snowboy Hotword detection: https://snowboy.kitt.ai/
      https://github.com/alexyak/voicecontrol
      T 1 Reply Last reply Reply Quote 4
      • T Offline
        tyho @alexyak
        @alexyak cool! How does it work?
        1 Reply Last reply Reply Quote -1
          alexyak
          Pull it or clone from the github into your MM modules directory. Go to the https://snowboy.kitt.ai, login with any of your emails, create voice models as much as you need and copy the pmdl files into the root folder, modify the config.js as it described in the Readme.md.
          • T Offline
            tyho
            where to place “notificationReceived: function” to get a text output on the mirror?
              alexyak @tyho
              @tyho said in VoiceControl module:
              You can put it in any other module that you would like to react on the voice command and then just call self.updateDom(self.config.animationSpeed);
              • T Offline
                tyho
                Wow! @alexyak nice work. I got it running. and i am playing around with it.
                1 question:
                I want to display the commands i said for 3 seconds.
                If i say a command i can get the text with:
                this.config.text = “going to sleep…”;
                this.updateDom(this.config.animationSpeed);
                Is there a way to auto reset it to default/hide after a few seconds? (i am trying this for hours already ^^)
                  alexyak @tyho
                  @tyho, you can use setTimeout function to wait a for few seconds and then reset the text value. Something like that:
                  var self = this;
                  setTimeout(function(){
                  self.config.text = “”;
                  self.updateDom …
                  }, 3000);
                  • T Offline
                    tyho
                    thanks again it’s working :)
                    i made a notification.js:
                    		var self = this;
                    				if (notification === "go_to_sleep"){
                                		this.config.text = "going to sleep...";
                    						self.config.text = "";
                    					}, 3000);
                    				if (notification === "wake_up"){
                                		this.config.text = "waking up...";
                    					}, 3000);
                    i have made a node_helper.js:
                    const NodeHelper = require('node_helper');
                    const exec = require('child_process').exec;
                      start: function () {
                    	      this.started = false
                        if (notification === 'go_to_sleep' && this.started == false) {
                                exec("/opt/vc/bin/tvservice -o", null);
                    	    if (notification === 'wake_up' && this.started == false) {
                                exec("/opt/vc/bin/tvservice -p", null);
                    It shows the command i speak for 3 seconds. But i can’t get the node helper working to actualy turn on and off my monitor. How can i bind this 2 modules? Or do i have to include it as a separate js file?
                    • strawberry 3.141S Offline
                      strawberry 3.141 Project Sponsor Module Developer @tyho
                      @tyho try this.sendSocketNotification('go_to_sleep', {}); in notification.js otherwise the node_helper doesnt’t get any msg and will not perform any action
                      • T Offline
                        tyho
                        Great! it’s working! thanks!
                        • T Offline
                          tyho
                          I still have a little problem. I want to register that if the monitor is on or off. It’s working very well except on the autosleep function that is loaded in the node_helper.
                          My notification.js
                          var awake = 1;
                          Module.register("notification",{
                          	// Default module config.
                          	defaults: {
                          		text: "",
                          		animationSpeed: 500,
                          	notificationReceived: function(notification, callback) {
                          		var self = this;
                          				if (notification === "go_to_sleep" && awake === 1){
                          						self.sendSocketNotification('go_to_sleep', {});
                          					}, 1000);
                          					awake = 0;
                          					callback(awake);
                          				if (notification === "wake_up" && awake === 0){
                          					this.sendSocketNotification('wake_up', {});
                          					}, 5000);
                          					awake = 1;
                          					callback(awake);
                          				if (notification === "autosleep"){
                          					awake = 0;
                          					callback(awake);
                          	// Override dom generator.
                          	getDom: function() {
                          		wrapper.innerHTML = this.config.text;
                          		return wrapper;
                          and my node_helper.js
                          'use strict';
                          var timer;
                          function initialize() {
                          (function(){
                          	initialize();
                          			autosleep();
                          function autosleep(){
                          	  timer=setTimeout(function(){
                          		  	var self = this;
                          				self.sendSocketNotification('autosleep');
                          			},  10*60*1000);
                            socketNotificationReceived: function(notification) {
                              if (notification === 'go_to_sleep') {
                          			clearTimeout(timer);
                          	if (notification === 'wake_up') {
                          			exec("/bin/fbset -depth 8 && /bin/fbset -depth 16 ", null);
                                		exec("/usr/bin/xrefresh",null);
                          			autosleep();
                          what i want is: if the autosleep function turns my monitor off, the variable awake in the notification.js set to 0.
                          any other suggestion on junky code are also welcome ^^
                            alexyak
                            If you override socketNotificationReceived in your module then you should receive the message from node_helper and can reset your flag appropriately.
                            • T Offline
                              tyho @alexyak
                              @alexyak how to override that module? I already call it with notifications === ‘autosleep’. And that notification gets send by the node_helper right? what am i missing?
                                alexyak @tyho
                                @tyho What I meant is you need to add socketNotificationReceived to your module notification.js.
                                • T Offline
                                  tyho
                                  @alexyak i can’t get it to work. it tested:
                                  It sends sockets notifications from notifications.js to node_helper.js. But not from node_helper.js back to notifications.js.
                                  Even if i put it in the start function of the node_helper.js:
                                  start: function() {
                                    this.sendSocketNotification("autosleep", {});
                                  it won’t get received it my notification.js:
                                     if (notification === "autosleep") {
                                  	  alert("autosleep received");
                                  		awake = 0;
                                  any idea? is it even possible to use it backwards?
                                    alexyak
                                    Try to put a call in your start method of the module (notification.js) to establish the connection with node_helper. Something like that:
                                    this.sendSocketNotification(“CONNECT”, {});
                                      alexyak
                                      I’ve updated the VoiceControl module to display a list of commands on the mirror:
                                      [ card : alexyak/voicecontrol ]
                                        alexyak
                                        [card:alexyak/voicecontrol]
                                          brumoeller
                                          This is a really cool module. Does anyone know a good microphone that will work for the whole room? The mic I have only works when you are close.
                                          • G Offline
                                            gismo2006
                                            @alexyak sorry, but i have a little Problem. Maybe you can help me.
                                            You write on Github in your Readme file, I have to put the code (notificationReceived: function(notification, payload, sender)…) into the module to use it. I like to controll the module Simple music player by @EoF so i clone your github files copy the code into the config.js File train and download a pmdl file. But where should i paste the code notificationReceived: function(notification, payload, sender)… In the config.js File or in the mmm-music-player.js file in folder modules simple music Player?
                                            Sorry i’m new in the coding world, and now a little bit confused :-D
                                            Greets gismo2006
                                            • 1 / 4
