    VoiceControl module
    79 Posts 27 Posters 112.4k Views 29 Watching
      alexyak
      I’ve managed to create the VoiceControl module based on Snowboy Hotword detection: https://snowboy.kitt.ai/
      https://github.com/alexyak/voicecontrol
      T 1 Reply Last reply Reply Quote 4
      • T Offline
        tyho @alexyak
        @alexyak cool! How does it work?
        1 Reply Last reply Reply Quote -1
          alexyak
          Pull it or clone from the github into your MM modules directory. Go to the https://snowboy.kitt.ai, login with any of your emails, create voice models as much as you need and copy the pmdl files into the root folder, modify the config.js as it described in the Readme.md.
          • T Offline
            tyho
            where to place “notificationReceived: function” to get a text output on the mirror?
              alexyak @tyho
              @tyho said in VoiceControl module:
              You can put it in any other module that you would like to react on the voice command and then just call self.updateDom(self.config.animationSpeed);
              • T Offline
                tyho
                Wow! @alexyak nice work. I got it running. and i am playing around with it.
                1 question:
                I want to display the commands i said for 3 seconds.
                If i say a command i can get the text with:
                this.config.text = “going to sleep…”;
                this.updateDom(this.config.animationSpeed);
                Is there a way to auto reset it to default/hide after a few seconds? (i am trying this for hours already ^^)
                  alexyak @tyho
                  @tyho, you can use setTimeout function to wait a for few seconds and then reset the text value. Something like that:
                  var self = this;
                  setTimeout(function(){
                  self.config.text = “”;
                  self.updateDom …
                  }, 3000);
                  • T Offline
                    tyho
                    thanks again it’s working :)
                    i made a notification.js:
                    		var self = this;
                    				if (notification === "go_to_sleep"){
                                		this.config.text = "going to sleep...";
                    						self.config.text = "";
                    					}, 3000);
                    				if (notification === "wake_up"){
                                		this.config.text = "waking up...";
                    					}, 3000);
                    i have made a node_helper.js:
                    const NodeHelper = require('node_helper');
                    const exec = require('child_process').exec;
                      start: function () {
                    	      this.started = false
                        if (notification === 'go_to_sleep' && this.started == false) {
                                exec("/opt/vc/bin/tvservice -o", null);
                    	    if (notification === 'wake_up' && this.started == false) {
                                exec("/opt/vc/bin/tvservice -p", null);
                    It shows the command i speak for 3 seconds. But i can’t get the node helper working to actualy turn on and off my monitor. How can i bind this 2 modules? Or do i have to include it as a separate js file?
                    • strawberry 3.141S Offline
                      strawberry 3.141 Project Sponsor Module Developer @tyho
                      @tyho try this.sendSocketNotification('go_to_sleep', {}); in notification.js otherwise the node_helper doesnt’t get any msg and will not perform any action
                      • T Offline
                        tyho
                        Great! it’s working! thanks!
                        • 1 / 8
