    MMM-aviationwx (Aviation weather)
    111 Posts 12 Posters 146.1k Views 11 Watching
    • 3 Offline
      320fan
      @Mykle1 Hi again.
      As I can see you continue to improve your mode - thats fine, thanks. Now I’ve some time for tests of this updated module. My points are:
      1. No possibility to set custom number of airports for the “Static” view: for example, line like:
      ICAO: "UUDD,UUWW,UUEE,UUOO,UWKD,URMT,ULLI,UWWW",  // separated by comma only
      works fine (8 ICAO codes), but when I’m decrease/increase number of ICAO codes it doesn’t work: “Loading PilotWX…” and thats all.
      1. My next proposal is to remove line “Station Conditions” for the Static view. It’s a little bit pointless ;)
      2. For the “Rotating” view: the whole text alltime yellow. How I can change that?
      3.1) For the “Rotating” view: pressure must be like xx.xx (not like xx as it is). In aircraft you must use all four digits for all the time. But for me - pressure in hectopascals (like 1019, without digits after comma) better in any case. Hovewer, in any case 1 hg = 33.863886666667 hPa. hg used for US airports at all the time, for EU/RU airports - hectopascals are the standard.
      3.2) And the last one regarding pressure - it’s nice to have it for a “Standard” view too - it’s a really important information.
      1. About time, which I can observe in the end of the line (tt:tt): I would ask you to display a UTC (Zulu) time, not a local time. So, thats the standard of METAR/TAF ;) In that case you display it like (ttttZ) or (tt:ttZ), and Zulu will be a remider for that.
      2. Thanks for visibility in KM, thats very usefull. And to have a same view - please, change speed in knots as “KT”, not a “kt”.
      3. For the “Loading PilotWX…” message - I would like to propose next code:
              if (!this.loaded) {
                  wrapper.classList.add("wrapper");
      //            wrapper.innerHTML = "Loading PilotWX . .";
      //            wrapper.className = "bright light small";
                    wrapper.innerHTML = (this.loaded) ? this.translate("EMPTY") : this.translate("LOADING");
                    wrapper.className = "small dimmed";
                  return wrapper;
      In that case this module will take into account locale settings for correct displaying of “Loading” message.
      1. In case of no cloudbase layer classification (like "BKN/OVC/etc.) you may see a OVX text:
        Thats not correct; the reply from server in that case is: sky_condition sky_cover=“OVX” cloud_base_ft_agl=“0”
      The right way - to display data directly from a string, as example:
      raw_text> URMT 071330Z 32006MPS 0650 0550NE R25/0800N +SHSN VV002 M01/M01 Q1010 R25/290255 NOSIG RMK QBB080 OBST OBSC QFE719 raw_text>
      • VV002 means vertical visibility in hundred of feets or QBB080 means vertical visibility in meters (this code not applicable for all airports).
      1. And if case of aligment to the right:
                              module: 'MMM-PilotWX',
                              header: 'Aviation weather',
                              position: 'bottom_right',
                              disabled: false,
      the whole layout is shifted to the right; Is it possible to align/to stretch all elements like for the “Weather forecast” plugin?
      1. Is it possible to use a same font/font size, like for standart modules (like "calendars, “weather”, etc.) to keep a same view for the whole mirror? It’s not a big deal, but in that case we can make a mirror looks more “arranged”.
      And last, but do not least: @Mykle1, thanks again for your job.
      • 3 Offline
        320fan
        • one moew issue:
        Datas from: https://aviationweather.gov/adds/dataserver_current/httpparam?dataSource=metars&requestType=retrieve&format=xml&stationString=UUDD&hoursBeforeNow=1
        raw_text
        UUDD 071630Z 34005MPS 9999 BKN022 M04/M08 Q1009 R88/520295 NOSIG
        /raw_text
        sky_condition sky_cover="BKN" cloud_base_ft_agl="2200"
        It must be BKN022, not BKN2200.
          Mykle1 Project Sponsor Module Developer @320fan
          @320fan said in MMM-aviationwx (Aviation weather):
          Yes, at the moment you MUST use 8. However, another user has graciously asked if he could modify some things and issue a PR that I will merge into the module. That is one of the changes.
          You mean the headers, “Station” and “Conditions”? Add this to your custom.css file and it will remove both
          .MMM-PilotWX .station {
            display: none;
          And this to change to any color for rotating
          .MMM-PilotWX .bottom_bar {
            color: yellow;
          Tell that to the API. That’s the data being given. I just display it.
          Use css to customize to your liking
          Alignment will always be an issue because the module is not set in a table. I did mention above that I am not capable of using tables yet. SO, for the time being, left regions will be better suited to the module
          Taking specific portions of the raw_text for display is beyond me.
          3 1 Reply Last reply Reply Quote 0
          • 3 Offline
            320fan @Mykle1
            @Mykle1 said in MMM-aviationwx (Aviation weather):
            For example:
            altim_in_hg 29.911417/altim_in_hg
            I think that this API converts pressure in hPa from raw_data (like Q1013) into hg by simply dividing by coefficient.
              Forgot I rounded this. My bad. So this should be
              29.91/hg ?
              • 3 Offline
                320fan @Mykle1
                @Mykle1 Hi again.
                Yea, 29.91Hg.
                  @320fan
                  Good morning
                  29.91Hg . Ok, I can work on that later. I’m getting ready for my work day right now
                  • 3 Offline
                    320fan @Mykle1
                    @Mykle1 Okay, no problem. Thanks.
                      @320fan
                      Wind speed now displays as such:
                      310/4KT
                      Pressure added to static view and formatted for both views as such:
                      29.91Hg
                      Config option added for time format, Zulu or Local in both views:
                      time: "Zulu", = (19:10Z)
                      time: "Local", = (14:10)
                      https://github.com/mykle1/MMM-PilotWX
                      git pull in your PilotWX directory for update or install as usual.
                        Please move all further inquiries regarding MMM-PilotWX to this topic:
                        https://forum.magicmirror.builders/topic/5686/mmm-pilotwx
                        • H Offline
                          hawkeyepilot69 @Mykle1
                          @Mykle1 is this module no longer working?
                            sdetweil @hawkeyepilot69
                            @hawkeyepilot69 Mykle1 is not available currently.
                            did u add the missing library like I advised?
                            • H Offline
                              hawkeyepilot69 @sdetweil
                              @sdetweil Like I had said, im very new to this and dont know how to do that.
                                @hawkeyepilot69 I have u a link to the instructions on how to deal w that problem.
                                as there are multiple libraries that cause the problem, I am trying to teach you how to find the problem by yourself and how to fix it.
                                vs just giving u the answer and having you come back for the next same failure
                                • 6 / 6
