    MMM-awesome-alexa
    241 Posts 43 Posters 452.0k Views 47 Watching
      mydiva
      I have tried to install this module, but it didn’t work. If I disable this module in config everything works fine. If i start with this module i get a black screen. In dev mode, i get an error DevTools was disconnected from the page …
      Do someone knows whats going wrong? I followed the instruction during the installation.
      • F
        Fonfon
        this module is only in english ?
        • X
          xchribiza
          Please help!
          I am trying to install this module and I am stuck at the refreshtoken thing…
          I always get error from amazon .
          Please any ideas ?
          • ArzegA
            Arzeg
            Hello Guys,
            i stuck … i tried the last days to configure the module right but i dont understand the step with auth_token.sh from the site How to get AVS Token.
            I got at the previous step the code for the second script “auth_token.sh” changed the client id, client secret and the code to my options all fine.
            When i will execute the script nothing happens or what should i do with the script?
            CLIENT_ID="amzn1.application-oa2-client.7efb5005320644ba9..."
            CLIENT_SECRET="a14de78ce1096593718..."
            CODE="ANXsEuOxBhQDk..."
            GRANT_TYPE="authorization_code"
            REDIRECT_URI="https://localhost:9745/authresponse"
            curl -X POST --data "grant_type=${GRANT_TYPE}&code=${CODE}&client_id=${CLIENT_ID}&client_secret=${CLIENT_SECRET}&redirect_uri=${REDIRECT_URI}" https://api.amazon.com/auth/o2/token
            my auth_token.sh script
            greets Arzeg
            • U
              uzumon
              Hello i need help.
              How to get refresh token?
              Now without refresh token in config i have problem with run module:
               2017-08-24 10:49 +02:00: Whoops! There was an uncaught exception...
              0|mm       | 2017-08-24 10:49 +02:00: { Error: Cannot find module '/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/binding/Release/electron-v1.6-linux-arm/snowboy.node'
              0|mm       |     at Module._resolveFilename (module.js:470:15)
              0|mm       |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
              0|mm       |     at Function.Module._load (module.js:418:25)
              0|mm       |     at Module.require (module.js:498:17)
              0|mm       |     at require (internal/module.js:20:19)
              0|mm       |     at Object. (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/index.js:8:29)
              0|mm       |     at Object. (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/index.js:132:3)
              0|mm       |     at Module._compile (module.js:571:32)
              0|mm       |     at Object.Module._extensions..js (module.js:580:10)
              0|mm       |     at Module.load (module.js:488:32) code: 'MODULE_NOT_FOUND' }
              Someone can help? Please.
              Edit: for error with snowboy. I fixed it by:
              npm run electron-rebuild
              • cowboysdudeC
                I guess he’s given up on getting this working correctly…
                Trust me this thing is a bloody nightmare…
                • cowboysdudeC
                  Well I have figured this out…it’s VERY simple.
                  IF You need the sh files to generate your info please go to my fork of this module…I’ve included them.
                  https://github.com/cowboysdude/MMM-awesome-alexa
                  • G
                    g_nandagpl
                    Thanks for this module. It works.
                    If we have visualization, it would be better.
                    dolanmiuD G 2 Replies Last reply Reply Quote 0
                    • dolanmiuD
                      dolanmiu @g_nandagpl
                      @g_nandagpl Thank you for the feedback, glad you got this working
                      As for visualization, it turned out really laggy on Raspberry Pi, so I postponed it
                      I might re-visit this feature, maybe figure out a way to speed it up if there is enough interest
                      • cowboysdudeC
                        cowboysdude Module Developer @dolanmiu
                        @dolanmiu OH there’s interest. I"m using a real computer to run mine so not an issue :)
                          jnstnr @cowboysdude
                          @cowboysdude thanks for the scripts! I’m trying to run auth_code.sh but I get the following errors, and no code to put in auth_code2.sh:
                          Can’t locate URI/Escape.pm in @INC (you may need to install the URI::Escape module) (@INC contains: /etc/perl /usr/local/lib/arm-linux-gnueabihf/perl/5.20.2 /usr/local/share/perl/5.20.2 /usr/lib/arm-linux-gnueabihf/perl5/5.20 /usr/share/perl5 /usr/lib/arm-linux-gnueabihf/perl/5.20 /usr/share/perl/5.20 /usr/local/lib/site_perl .).
                          BEGIN failed–compilation aborted.
                          /usr/bin/xdg-open: 1: eval: www-browser: not found
                          /usr/bin/xdg-open: 1: eval: links2: not found
                          /usr/bin/xdg-open: 1: eval: elinks: not found
                          /usr/bin/xdg-open: 1: eval: links: not found
                          /usr/bin/xdg-open: 1: eval: lynx: not found
                          /usr/bin/xdg-open: 1: eval: w3m: not found
                          xdg-open: no method available for opening ‘https://www.amazon.com/ap/oa?client_id=[removed my client id]&scope=&scope_data=&response_type=code&redirect_uri=’
                          Any ideas what could be wrong?
                          • cowboysdudeC
                            cowboysdude Module Developer @jnstnr
                            @jnstnr Yes I may have an idea…
                            open up both sh files and using your keyboard replace all the double quotes … for some reason they do not copy well. I did that and it ran great! :)
                              jnstnr @cowboysdude
                              @cowboysdude just got home and tried it, replaced all " with ’
                              And now I get another error:
                              pi@raspberrypi:~ $ bash auth_code.sh
                              auth_code.sh: line 10: syntax error near unexpected token (' auth_code.sh: line 10: perl -MURI::Escape -ne ‘chomp;print uri_escape($_),’\n’‘’
                              Pretty sure there’s a simple fix for line 10, but haven’t figured it out yet!
                              J S M H 4 Replies Last reply Reply Quote 0
                                jnstnr @jnstnr
                                Scratch that, finally managed to get a refresh token! Added it to the config and getting a black screen now though :/
                                • cowboysdudeC
                                  @jnstnr Well past that I cannot help you…just double check your config and make it look like the example if that doesn’t solve it msg @dolanmiu He created this module :)
                                    jnstnr @cowboysdude
                                    @cowboysdude Thanks. I managed to get this up and running, now trying to tackle my USB mic :) this isn’t the easiest module to get working!
                                    But thanks for all your help, you’re doing great work for the magic mirror community
                                    cowboysdudeC dolanmiuD 2 Replies Last reply Reply Quote 0
                                    • cowboysdudeC
                                      @jnstnr Thanks. Did you see the Troubleshoot section here:
                                      https://github.com/dolanmiu/MMM-awesome-alexa
                                      Perhaps that will help! :)
                                      • dolanmiuD
                                        dolanmiu @jnstnr
                                        @jnstnr Yeah, sorry for the complexity! I tried hard to make this as easy as possible
                                        But due to the nature of this project, there are a lot of variables. Everyones machine and setup is different etc
                                          jnstnr @dolanmiu
                                          @dolanmiu no worries, I totally understand that it’s quite complicated
                                            smyvy @jnstnr
                                            @jnstnr said in MMM-awesome-alexa:
                                            Hi, what was you fix? Thanks
                                            J M 2 Replies Last reply Reply Quote 0
                                            • 12
                                            • 13
                                            • 2 / 13
