    MMM-awesome-alexa
    241 Posts 43 Posters 445.1k Views 47 Watching
    • ArzegA Offline
      Arzeg
      Hello Guys,
      i stuck … i tried the last days to configure the module right but i dont understand the step with auth_token.sh from the site How to get AVS Token.
      I got at the previous step the code for the second script “auth_token.sh” changed the client id, client secret and the code to my options all fine.
      When i will execute the script nothing happens or what should i do with the script?
      CLIENT_ID="amzn1.application-oa2-client.7efb5005320644ba9..."
      CLIENT_SECRET="a14de78ce1096593718..."
      CODE="ANXsEuOxBhQDk..."
      GRANT_TYPE="authorization_code"
      REDIRECT_URI="https://localhost:9745/authresponse"
      curl -X POST --data "grant_type=${GRANT_TYPE}&code=${CODE}&client_id=${CLIENT_ID}&client_secret=${CLIENT_SECRET}&redirect_uri=${REDIRECT_URI}" https://api.amazon.com/auth/o2/token
      my auth_token.sh script
      greets Arzeg
      • U Offline
        uzumon
        Hello i need help.
        How to get refresh token?
        Now without refresh token in config i have problem with run module:
         2017-08-24 10:49 +02:00: Whoops! There was an uncaught exception...
        0|mm       | 2017-08-24 10:49 +02:00: { Error: Cannot find module '/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/binding/Release/electron-v1.6-linux-arm/snowboy.node'
        0|mm       |     at Module._resolveFilename (module.js:470:15)
        0|mm       |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
        0|mm       |     at Function.Module._load (module.js:418:25)
        0|mm       |     at Module.require (module.js:498:17)
        0|mm       |     at require (internal/module.js:20:19)
        0|mm       |     at Object. (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/index.js:8:29)
        0|mm       |     at Object. (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/index.js:132:3)
        0|mm       |     at Module._compile (module.js:571:32)
        0|mm       |     at Object.Module._extensions..js (module.js:580:10)
        0|mm       |     at Module.load (module.js:488:32) code: 'MODULE_NOT_FOUND' }
        Someone can help? Please.
        Edit: for error with snowboy. I fixed it by:
        npm run electron-rebuild
        • cowboysdudeC Offline
          I guess he’s given up on getting this working correctly…
          Trust me this thing is a bloody nightmare…
            Well I have figured this out…it’s VERY simple.
            IF You need the sh files to generate your info please go to my fork of this module…I’ve included them.
            https://github.com/cowboysdude/MMM-awesome-alexa
            • G Offline
              g_nandagpl
              Thanks for this module. It works.
              If we have visualization, it would be better.
              dolanmiuD G 2 Replies Last reply Reply Quote 0
              • dolanmiuD Offline
                dolanmiu @g_nandagpl
                @g_nandagpl Thank you for the feedback, glad you got this working
                As for visualization, it turned out really laggy on Raspberry Pi, so I postponed it
                I might re-visit this feature, maybe figure out a way to speed it up if there is enough interest
                  cowboysdude Module Developer @dolanmiu
                  @dolanmiu OH there’s interest. I"m using a real computer to run mine so not an issue :)
                    jnstnr @cowboysdude
                    @cowboysdude thanks for the scripts! I’m trying to run auth_code.sh but I get the following errors, and no code to put in auth_code2.sh:
                    Can’t locate URI/Escape.pm in @INC (you may need to install the URI::Escape module) (@INC contains: /etc/perl /usr/local/lib/arm-linux-gnueabihf/perl/5.20.2 /usr/local/share/perl/5.20.2 /usr/lib/arm-linux-gnueabihf/perl5/5.20 /usr/share/perl5 /usr/lib/arm-linux-gnueabihf/perl/5.20 /usr/share/perl/5.20 /usr/local/lib/site_perl .).
                    BEGIN failed–compilation aborted.
                    /usr/bin/xdg-open: 1: eval: www-browser: not found
                    /usr/bin/xdg-open: 1: eval: links2: not found
                    /usr/bin/xdg-open: 1: eval: elinks: not found
                    /usr/bin/xdg-open: 1: eval: links: not found
                    /usr/bin/xdg-open: 1: eval: lynx: not found
                    /usr/bin/xdg-open: 1: eval: w3m: not found
                    xdg-open: no method available for opening ‘https://www.amazon.com/ap/oa?client_id=[removed my client id]&scope=&scope_data=&response_type=code&redirect_uri=’
                    Any ideas what could be wrong?
                      cowboysdude Module Developer @jnstnr
                      @jnstnr Yes I may have an idea…
                      open up both sh files and using your keyboard replace all the double quotes … for some reason they do not copy well. I did that and it ran great! :)
                        jnstnr @cowboysdude
                        @cowboysdude just got home and tried it, replaced all " with ’
                        And now I get another error:
                        pi@raspberrypi:~ $ bash auth_code.sh
                        auth_code.sh: line 10: syntax error near unexpected token (' auth_code.sh: line 10: perl -MURI::Escape -ne ‘chomp;print uri_escape($_),’\n’‘’
                        Pretty sure there’s a simple fix for line 10, but haven’t figured it out yet!
                        J S M H 4 Replies Last reply Reply Quote 0
                          jnstnr @jnstnr
                          Scratch that, finally managed to get a refresh token! Added it to the config and getting a black screen now though :/
                            @jnstnr Well past that I cannot help you…just double check your config and make it look like the example if that doesn’t solve it msg @dolanmiu He created this module :)
                              jnstnr @cowboysdude
                              @cowboysdude Thanks. I managed to get this up and running, now trying to tackle my USB mic :) this isn’t the easiest module to get working!
                              But thanks for all your help, you’re doing great work for the magic mirror community
                              cowboysdudeC dolanmiuD 2 Replies Last reply Reply Quote 0
                                @jnstnr Thanks. Did you see the Troubleshoot section here:
                                https://github.com/dolanmiu/MMM-awesome-alexa
                                Perhaps that will help! :)
                                • dolanmiuD Offline
                                  dolanmiu @jnstnr
                                  @jnstnr Yeah, sorry for the complexity! I tried hard to make this as easy as possible
                                  But due to the nature of this project, there are a lot of variables. Everyones machine and setup is different etc
                                    jnstnr @dolanmiu
                                    @dolanmiu no worries, I totally understand that it’s quite complicated
                                      smyvy @jnstnr
                                      @jnstnr said in MMM-awesome-alexa:
                                      Hi, what was you fix? Thanks
                                      J M 2 Replies Last reply Reply Quote 0
                                        jnstnr @smyvy
                                        @smyvy I went to this url:
                                        https://sakirtemel.github.io/MMM-alexa/
                                        Put in the Client Id, Device ID & set serial number as 1234. I also added the above url as an allowed return url in the Amazon developer console before I clicked the “Request code” button.
                                          smyvy @jnstnr
                                            jnstnr @smyvy
                                            @smyvy the config that’s included in the mmm-awesome-alexa repo wasn’t working for me, so I adjusted it to make it look like other modules in my config. here’s my setup, I was actually missing a comma after the closing }, which fixed the black screen:
                                            module: ‘MMM-awesome-alexa’,
                                            position: “bottom_bar”,
                                            wakeWord: “Alexa”,
                                            clientId: “amzn1…”,
                                            clientSecret: “…”,
                                            deviceId: “magicmirror”,
                                            refreshToken: “…”,
                                            lite: false
                                            • 12
                                            • 13
                                            • 2 / 13
