    Cannot access to MagicMirror despite IpWhiteList
    10 Posts 2 Posters 7.4k Views 2 Watching
      MrNonoss
      Hi MagicMirror users,
      I have an issue.
      I can’t access to my brand new MagicMirror (other than localhost) despite having a proper IpWhiteList configuration.
      I’m building a small server on a tiny computer running Debian 9 (Stretch). The project is using it to control my home (Home Assistant), run MagicMirror in server mode, and maybe do some facial recognition later…
      I installed Home Assistant with no problem and can access to the web panel from another computer within my home network (so, fine… Everything is ok).
      Then, I installed and configured MagicMirror. It works without problem on my localhost.
      But unfortunately, I cannot access it elsewere using the IP of my server 192.168.X.X:8080.
      My IpWhiteList config is:
      var config = {
              port: 8080,
              ipWhitelist: [],
      The CLI gives this:
      XXX@serveur:~/MagicMirror$ npm start
      > magicmirror@2.1.3 start /home/XXX/MagicMirror
      > sh run-start.sh
      Gtk-Message: Failed to load module "canberra-gtk-module"
      Starting MagicMirror: v2.1.3
      Loading config ...
      Loading module helpers ...
      Module helper loaded: MMM-Paris-RATP-PG
      Module helper loaded: MMM-cryptocurrency
      Module helper loaded: MMM-WunderGround
      Module helper loaded: MMM-Remote-Control
      All module helpers loaded.
      You're using a full whitelist configuration to allow for all IPs
      Server started ...
      Starting module: newsfeed
      Connecting socket for: MMM-Paris-RATP-PG
      Connecting socket for: MMM-cryptocurrency
      Cryptocurrency module loaded!
      Connecting socket for: MMM-WunderGround
      MMM-WunderGround helper started ...
      Connecting socket for: MMM-Remote-Control
      Starting node helper for: MMM-Remote-Control
      Launching application.
      Create new calendar fetcher for url: https://calendar.google.com/calendar/XXX.ics - Interval: 300000
      Create new news fetcher for url: http://www.lemonde.fr/rss/une.xml - Interval: 300000
      GET_WUNDERGROUND
      And chrome gives me this:
      Ce site est inaccessible
      192.168.X.X n'autorise pas la connexion.
      Effectuez une recherche Google sur 192 168 8080.
      ERR_CONNECTION_REFUSED
      I don’t have any deny access on the CLI or another error message.
      Do you have a clue to help me out?
      Thank you all
        Mykle1 Project Sponsor Module Developer @MrNonoss
        @MrNonoss said in Cannot access to MagicMirror despite IpWhiteList:
        var config = {
        port: 8080,
        ipWhitelist: [],
        Try this:
        var config = {
                port: 8080,
                address: "0.0.0.0",
                ipWhitelist: [],
          MrNonoss
          Thank you for your tip @Mykle1, but unfortunately, it changed nothing.
          But looking at my CLI after launching MM, the end seems strange.
          Is it normal to stop like this?
          GET_WUNDERGROUND
            Ah, hmm. Are Home Assistant and MM accessing the same port?
            GET_WUNDERGROUND
            Yes, completely normal
              MrNonoss
              Thank you for your quick reply.
              Nope, Home Assistant is using port 80
                MrNonoss
                Hi all,
                I come back with a hint…
                There are two web server on my computer, but I didn’t installed any “Apache” or so, so I didn’t configured anything
                One is with Home Assistant (coded in Python) and the other one is the MagicMiror.
                Could it be a sort of conflict between these two?
                  @MrNonoss
                  If you remove or disable Home Assistant can you then connect to MagicMirror?
                    MrNonoss
                    There’s no other option than deleting the installation folder.
                    I tried, but, with no succes.
                    I’m bored. Il will try to reinstall the whole things, starting by MM, testing --> If Ok --> Then Install Home Assistant and test again, it will give tips (I hope)
                    Thank you again Mykle
                      @MrNonoss
                      You’re welcome, mate.
                      I agree. Install MM first and get your connection established. Let me know how you make out.
                        MrNonoss
                        Hi everyone,
                        Problem solved with a new fresh install. Unfortunately, the issue came from me.
                        From my config.js to be more accurate.
                        My exact config.js was:
                        var config = {
                        	port: 8080,
                        	adress: "0.0.0.0",
                        	ipWhitelist: ["127.0.0.1", "192.168.1.1/24", "192.168.2.1/24", "192.168.2.100"], // Set [] to allow all IP addresses
                        My new and working one is the one Mykle1 gave me:
                        var config = {
                                port: 8080,
                                address: "0.0.0.0",
                                ipWhitelist: [],
                        I assume it’s a coma mistake.
                        Nothing to do with multi web server.
                        Thank you again for your help.
                        Best regards
