    Cannot access to MagicMirror despite IpWhiteList
    10 Posts 2 Posters 7.9k Views 2 Watching
      MrNonoss
      Hi all,
      I come back with a hint…
      There are two web server on my computer, but I didn’t installed any “Apache” or so, so I didn’t configured anything
      One is with Home Assistant (coded in Python) and the other one is the MagicMiror.
      Could it be a sort of conflict between these two?
        Mykle1 Project Sponsor Module Developer @MrNonoss
        @MrNonoss
        If you remove or disable Home Assistant can you then connect to MagicMirror?
          MrNonoss
          There’s no other option than deleting the installation folder.
          I tried, but, with no succes.
          I’m bored. Il will try to reinstall the whole things, starting by MM, testing --> If Ok --> Then Install Home Assistant and test again, it will give tips (I hope)
          Thank you again Mykle
            @MrNonoss
            You’re welcome, mate.
            I agree. Install MM first and get your connection established. Let me know how you make out.
              MrNonoss
              Hi everyone,
              Problem solved with a new fresh install. Unfortunately, the issue came from me.
              From my config.js to be more accurate.
              My exact config.js was:
              var config = {
              	port: 8080,
              	adress: "0.0.0.0",
              	ipWhitelist: ["127.0.0.1", "192.168.1.1/24", "192.168.2.1/24", "192.168.2.100"], // Set [] to allow all IP addresses
              My new and working one is the one Mykle1 gave me:
              var config = {
                      port: 8080,
                      address: "0.0.0.0",
                      ipWhitelist: [],
              I assume it’s a coma mistake.
              Nothing to do with multi web server.
              Thank you again for your help.
              Best regards
