Unable to update
15 Posts 6 Posters 7.9k Views 5 Watching
  • E Offline
    eugenelai
    Hi all,
    I’m trying to update my MagicMirror but have two issues:
    1. When I type in sudo git pull && npm install to try update I get fatal: Not a git repository (or any of the parent directories): .git. The current directory I am in is /home/Pi/MagicMirror. So not sure if I have to do a init git command?
    2. If and when I do update I’ve made some changes to the modules I’ve installed. Is the best way, to temporarily copy them some where else then copy them back after the update?
    Thanks in advance
    M S 2 Replies Last reply Jan 2, 2018, 12:28 PM Reply Quote 0
      Mykle1 Project Sponsor Module Developer @eugenelai
      @eugenelai
      You should not have to use sudo when updating. You’re in the right directory, so, just git pull && npm install
      Any changes you’ve made to the module files will be overwritten. So, yes, copy/move them to another location outside of the MagicMirror directory before updating
      E 1 Reply Last reply Jan 3, 2018, 12:10 AM Reply Quote 0
      • F Offline
        fox
          strawberry 3.141 Project Sponsor Module Developer @eugenelai
          @eugenelai sounds like you downloaded the mirror manually and didn’t use git clone.
          • E Offline
            eugenelai @Mykle1
            @Mykle1
            Sorry I get the same error message if I use sudo as well. I guess i’ll backup all the files I’ve changed do a git init then see what happens.
            @strawberry-3.141
            Nope did the automatic install.
            M 1 Reply Last reply Jan 3, 2018, 12:13 AM Reply Quote 0
              @eugenelai said in Unable to update:
              Ok, but I said you should NOT have to use sudo to run those commands
              E 1 Reply Last reply Jan 3, 2018, 12:17 AM Reply Quote 0
              • E Offline
                eugenelai @Mykle1
                @Mykle1
                Yeah still doesn’t work. I’ve done git init then tried both git pull && npm install with and without sudo and I get the following:
                pi@MagicMirrorPi:~ $ cd MagicMirror
                pi@MagicMirrorPi:~/MagicMirror $ sudo git pull && npm install
                fatal: No remote repository specified.  Please, specify either a URL or a
                remote name from which new revisions should be fetched.
                M 1 Reply Last reply Jan 3, 2018, 12:20 AM Reply Quote 0
                  @eugenelai
                  Personally, if this was me, I would rename my existing MagicMirror folder, install the new MagicMirror via git clone, run npm install in the new MagicMirror folder, then move what I want from the old MagicMirror installation into the new installation.
                  NO SUDO necessary
                  C E 2 Replies Last reply Jan 3, 2018, 12:21 AM Reply Quote 1
                    @Mykle1 Yes that would be the easiest way to do it!
                    • E Offline
                      eugenelai @Mykle1
                      @Mykle1
                      that’s a good idea… Let me try that.
                      Cheers for the help
                      C 1 Reply Last reply Jan 3, 2018, 12:26 AM Reply Quote 1
