    Unable to update
    15 Posts 6 Posters 9.6k Views 5 Watching
    • E Offline
      eugenelai
      Hi all,
      I’m trying to update my MagicMirror but have two issues:
      1. When I type in sudo git pull && npm install to try update I get fatal: Not a git repository (or any of the parent directories): .git. The current directory I am in is /home/Pi/MagicMirror. So not sure if I have to do a init git command?
      2. If and when I do update I’ve made some changes to the modules I’ve installed. Is the best way, to temporarily copy them some where else then copy them back after the update?
      Thanks in advance
      Mykle1M strawberry 3.141S 2 Replies Last reply Reply Quote 0
        Mykle1 Project Sponsor Module Developer @eugenelai
        @eugenelai
        You should not have to use sudo when updating. You’re in the right directory, so, just git pull && npm install
        Any changes you’ve made to the module files will be overwritten. So, yes, copy/move them to another location outside of the MagicMirror directory before updating
        • foxF Offline
          fox
          • strawberry 3.141S Offline
            strawberry 3.141 Project Sponsor Module Developer @eugenelai
            @eugenelai sounds like you downloaded the mirror manually and didn’t use git clone.
            • E Offline
              eugenelai @Mykle1
              @Mykle1
              Sorry I get the same error message if I use sudo as well. I guess i’ll backup all the files I’ve changed do a git init then see what happens.
              @strawberry-3.141
              Nope did the automatic install.
                @eugenelai said in Unable to update:
                Ok, but I said you should NOT have to use sudo to run those commands
                • E Offline
                  eugenelai @Mykle1
                  @Mykle1
                  Yeah still doesn’t work. I’ve done git init then tried both git pull && npm install with and without sudo and I get the following:
                  pi@MagicMirrorPi:~ $ cd MagicMirror
                  pi@MagicMirrorPi:~/MagicMirror $ sudo git pull && npm install
                  fatal: No remote repository specified.  Please, specify either a URL or a
                  remote name from which new revisions should be fetched.
                    @eugenelai
                    Personally, if this was me, I would rename my existing MagicMirror folder, install the new MagicMirror via git clone, run npm install in the new MagicMirror folder, then move what I want from the old MagicMirror installation into the new installation.
                    NO SUDO necessary
                    cowboysdudeC E 2 Replies Last reply Reply Quote 1
                    • cowboysdudeC Offline
                      @Mykle1 Yes that would be the easiest way to do it!
                      • E Offline
                        eugenelai @Mykle1
                        @Mykle1
                        that’s a good idea… Let me try that.
                        Cheers for the help
                          cowboysdude Module Developer @eugenelai
                          @eugenelai It will save you endless headaches…
                          • E Offline
                            eugenelai @cowboysdude
                            @cowboysdude @Mykle1
                            Well, tried renaming, then installing a new MagicMirro via git clone and then run npm install and its totally gone tits up.
                            Ah well just going to wipe the SD card and start again. Thankfully have all my stuff backed up.
                            • K Offline
                              kidddrock
                              Hopefully it’s not too late to help save you (and others) some time and worry.
                              I just updated my install using ‘git pull && npm install’ and it actually aborts if it detects the update will overwrite files you’ve changed (pretty awesome feature imo).
                              Also, you don’t need to copy your main folder or even move any files elsewhere - all you need to do is rename the files it says would be overwritten with the update, and you can leave them in the same folder.
                              For instance, it said my main.css had changes and would be overwritten. I just renamed it to main2.css and left it where it was (and did similarly to a few other files).
                              After updating to the latest MM, I just went to the css folder, opened up that file (sudo nano main2.css), then saved it overwriting the newly updated version (saved to main.css).
                              That’s all I did for the few files I had customized and upon restart, all of my changes were present. Good luck!
                              • foxF Offline
                                fox
                                After every MagicMirror update i have to set up the MagicMirror from scratch.
                                It crashed my system completely.
                                So if you dont want to have hours of time and headache, simply do not update your system.
                                I had the same problem when i did the last update.
                                My journey yesterday
                                • E Offline
                                  eugenelai @kidddrock
                                  @kidddrock said in Unable to update:
                                  Actually it wasn’t a matter of overwriting files. That I could figure out. I couldn’t even do a git pull During the automatic installation a .git file wasn’t created or initialised. Worked out in the end thought… Just a massive ball ache.
