    My First Mirror... until now ^^
    37 Posts 17 Posters 55.6k Views 18 Watching
    • cowboysdudeC
      WOW that really looks awesome!! I love the LED lights!!!
      • N
        nikobelohlav
        Looks Fantastic! i have a couple questions though, how did you add the backround (THE GIRL)?, how is your PIR setup, i want to add one for mine but have been trying to figure out how to make the screen just turn black instead of shutting off completely , and last one is how did you get scrobbler to work? I installed scrobbler on my mirror but it only worked if i had last.fm running on a computer within my network and half the time it was’nt “seeing” what i was playing. any insight to those questions would be great, feel free to message me directly so you thread doesnt get packed with a bunch of non-essential post. thanks
        • Y
          yawns Moderator @nikobelohlav
          @nikobelohlav said in My First Mirror... until now ^^:
          Like this: https://forum.magicmirror.builders/topic/351/add-a-background-image
            barnosch
            Sieht super aus!
            Vergess bloß nicht die Fusselrolle zu kaufen ;)
            • cruunnerrC
              cruunnerr
              Thanks for the compliments.
              You can add a background with your custom.css like the link u posted, yawns.
              My custom.css looks like this:
               * Magic Mirror                                      *
               * Custom CSS                                        *
               * By Michael Teeuw http://michaelteeuw.nl           *
               * MIT Licensed.                                     *
               * Add any custom CSS below.                         *
               * Changes to this files will be ignored by GIT. *
               body {
              	background-image: url("background9.jpg");
              	background-size: cover;
              	margin-left: 0px;
              	margin-right: 30px;
              	margin-top: 15px;
              	margin-bottom: 15px;
                	position: absolute;
                	height: calc(100% - 28px);
                	width: calc(100% - 22px);
              .MMM-SystemStats  {
                      color: #CEF6CE;
              .MMM-MyCalendar {
                max-width: 300px;
              The image is called “background9.jpg” and has been placed in the “home/pi/MagicMirror/css” folder.
              I needed to play a little bit with the margin’s, until it fits perfect. Keep in mind that your picture should fit the screen resolution. It shouldn’t be smaller. if it is, you should take a look at the MMM-ProfilePicture module.
              @nikobelohlav
              I just used the MMM-PIR module for it. It turns the HDMI signal off, and my monitor recognized that via HDMI-CEC/ARC and turns off. When the signal comes back the motor turns on within 2 seconds. thats quick enough i think.
              I don’t know if it is possible to change the MMM-Pir-Sensor.js so that not the command “tvservice …” is executed, but a notification will be sent to other modules like the profile-switcher. Maybe you should open a new thread, even if I don’t quite understand why you don’t want to turn off your monitor.
              The scrobbler module was a little bit tricky. First you need to register your apps, to share the current playing music with last.fm.
              I actually just use Spotify, so in the Spotify-settings of my phone, tablet and macbook i needed to login to last.fm via the Spotify app.
              Sometimes i got the same problem as you, but its not a failure of the module. I played music and checked on last.fm if there is actually scribbling something, but there wasn’t. Then i turn back to my Spotify app and just log out and log in again (to last.fm in the Spotify settings) and that brings the scrobbling back.
              So its more a bug, that happens sometimes, cause Spotify didn’t correctly streams to last.fm i think.
              When u don’t pause the music it should scrobble continuous.
              Also keep in mind:
              When is a scrobble a scrobble?
              A track should only be scrobbled when the following conditions have been met:
              The track must be longer than 30 seconds.
              And the track has been played for at least half its duration, or for 4 minutes (whichever occurs earlier.)
              As soon as these conditions have been met, the scrobble request may be sent at any time. It is often most convenient to send a scrobble request when a track has finished playing.
              @barnosch
              Ja im Winter ist es manchmal schlimm mit den Hundis ^^
                doubleT Module Developer
                I really like how you integrated the motion sensor! The rest is a little bit too much “screen” (as opposed to mirror) for me, but I can see the appeal. I like it.
                • cruunnerrC
                  cruunnerr
                  @doubleT said in My First Mirror... until now ^^:
                  i know what you mean ^^
                  But since i found out how many things can be shown with the MM, i couldn’t let it be :D
                  Maybe the background is “too much”, but i like it anyhow XD
                  but if i turn on the room lights, its bright enough to use it as a mirror :P
                  • Mykle1M
                    Mykle1 Project Sponsor Module Developer @cruunnerr
                    @cruunnerr said in My First Mirror... until now ^^:
                    Whatever you like is how your mirror should be.
                    Again, well done, mate. :-)
                    Peace
                    • cruunnerrC
                      cruunnerr
                      Very tinkered cause i am experimenting a lot ^^
                      • F
                        fischi87
                        Hello, is a really awesome mirror really!!!
                        one question, how can i get the header over the qr code picture?
                        thanks
                        cruunnerrC 1 Reply Last reply Reply Quote 0
                        • cruunnerrC
                          cruunnerr @fischi87
                          @fischi87
                          Just type a header in the config:
                              			module: "MMM-EasyPix",
                          			header: "WLAN-Code",
                          			position: "bottom_left",
                          				picName: "guest_wifi_config.png", // Enter the picture file name.
                          				maxWidth: "150px",      // Size picture precisely. Retains aspect ratio.
                          F 1 Reply Last reply Reply Quote 1
                          • F
                            fischi87 @cruunnerr
                            @cruunnerr
                            ah yes alright, thanks
                            • metalldetectorM
                              metalldetector
                              hi… i have motion detector pir. and a led5050 strip.
                              can you please provide the software part between pir and led… for dimming and on off feature … pleeeese
                              thx
                              • cruunnerrC
                                cruunnerr
                                Hey @metalldetector
                                I already did somewhere in the forum ^^
                                You need to install PIGPIOD.
                                sudo apt-get install build-essential python-dev unzip wget
                                wget http://abyz.me.uk/rpi/pigpio/pigpio.zip && unzip pigpio.zip && cd PIGPIO && sudo make install
                                Connect the PIR like shown at Part 2.2 and follow the guide:
                                https://forum.magicmirror.builders/topic/6291/howto-turn-on-off-your-monitor-time-based-pir-button-app?page=1
                                When creating the pir.py and fill ist with this code:
                                #!/usr/bin/env python
                                import sys
                                import time
                                import RPi.GPIO as io
                                import subprocess
                                import pigpio
                                io.setmode(io.BCM)
                                SHUTOFF_DELAY = 119 # seconds
                                PIR_PIN = 25       # 22 on the board
                                LED_PIN = 16
                                def main():
                                    io.setup(PIR_PIN, io.IN)
                                    io.setup(LED_PIN, io.OUT)
                                    turned_off = False
                                    last_motion_time = time.time()
                                    while True:
                                        if io.input(PIR_PIN):
                                            io.output(LED_PIN, io.LOW)
                                            print ".",
                                            sys.stdout.flush()
                                            if turned_off:
                                                turned_off = False
                                                turn_on()
                                        else:
                                            if not turned_off and time.time() > (last_motion_time +
        SHUTOFF_DELAY):
                                                turned_off = True
                                                turn_off()
                                            if not turned_off and time.time() > (last_motion_time + 1):
                                                io.output(LED_PIN, io.HIGH)
                                        time.sleep(.1)
                                def turn_on():
                                	subprocess.call("sh /home/pi/monitor_on.sh", shell=True)
                                def turn_off():
                                	subprocess.call("sh /home/pi/monitor_off.sh", shell=True)
                                if __name__ == '__main__':
                                    try:
                                        main()
                                    except KeyboardInterrupt:
                                        io.cleanup()
                                For the monitor_on.sh use this:
                                vcgencmd display_power 1
                                pigs p 17 1
                                pigs p 22 1
                                pigs p 24 1
                                sleep 0.06s
                                pigs p 17 2
                                pigs p 22 2
                                pigs p 24 2
                                sleep 0.06s
                                pigs p 17 3
                                pigs p 22 3
                                pigs p 24 3
                                sleep 0.06s
                                pigs p 17 4
                                pigs p 22 4
                                pigs p 24 4
                                sleep 0.06s
                                pigs p 17 5
                                pigs p 22 5
                                pigs p 24 5
                                sleep 0.06s
                                pigs p 17 6
                                pigs p 22 6
                                pigs p 24 5
                                sleep 0.06s
                                pigs p 17 7
                                pigs p 22 7
                                pigs p 24 6
                                sleep 0.06s
                                pigs p 17 8
                                pigs p 22 8
                                pigs p 24 7
                                sleep 0.06s
                                pigs p 17 9
                                pigs p 22 9
                                pigs p 24 8
                                sleep 0.06s
                                pigs p 17 10
                                pigs p 22 10
                                pigs p 24 9
                                sleep 0.06s
                                pigs p 17 11
                                pigs p 22 11
                                pigs p 24 10
                                sleep 0.06s
                                pigs p 17 12
                                pigs p 22 12
                                pigs p 24 11
                                For monitor_off.sh use this:
                                pigs p 17 12
                                pigs p 22 12
                                pigs p 24 11
                                sleep 0.06s
                                pigs p 17 11
                                pigs p 22 11
                                pigs p 24 10
                                sleep 0.06s
                                pigs p 17 10
                                pigs p 22 10
                                pigs p 24 9
                                sleep 0.06s
                                pigs p 17 9
                                pigs p 22 9
                                pigs p 24 8
                                sleep 0.06s
                                pigs p 17 8
                                pigs p 22 8
                                pigs p 24 7
                                sleep 0.06s
                                pigs p 17 7
                                pigs p 22 7
                                pigs p 24 6
                                sleep 0.06s
                                pigs p 17 6
                                pigs p 22 6
                                pigs p 24 5
                                sleep 0.06s
                                pigs p 17 5
                                pigs p 22 5
                                pigs p 24 5
                                sleep 0.06s
                                pigs p 17 4
                                pigs p 22 4
                                pigs p 24 4
                                sleep 0.06s
                                pigs p 17 4
                                pigs p 22 4
                                pigs p 24 4
                                sleep 0.06s
                                pigs p 17 3
                                pigs p 22 3
                                pigs p 24 3
                                sleep 0.06s
                                pigs p 17 2
                                pigs p 22 2
                                pigs p 24 2
                                vcgencmd display_power 0
                                sleep 0.06s
                                pigs p 17 1
                                pigs p 22 1
                                pigs p 24 1
                                sleep 0.06s
                                pigs p 17 0
                                pigs p 22 0
                                pigs p 24 0
                                Hope that helps. Try to find your best way and ask, if u need more help :)
                                Edit:
                                Oh and u need to start Pigpio on reboot with rc.local. ;)
                                metalldetectorM N 2 Replies Last reply Reply Quote 3
                                • swvalentiS
                                  swvalenti Project Sponsor
                                  If you told me that your background wasn’t a stock photo I would upvote this! Nice work!
                                  • cruunnerrC
                                    cruunnerr
                                    Well, meanwhile i changed my background, but still love it :P
                                    Bild Text
                                    • metalldetectorM
                                      metalldetector @cruunnerr
                                      @c:face_with_steam_from_nose: ruunnerr ok that works…
                                      -What ist the Funktion of LED_PIN = 16 .
                                      Only one pin …
                                      Do I need RGB pins in the script?
                                      -And then the led stripe start it’s flickering…
                                      Thx4yourhelp
                                      • cruunnerrC
                                        cruunnerr
                                        LED-Pin just shows, if the PIR detects motion. You don’t need to use it.
                                        The pir.py script starts the other shell scripts when motion is detected.
                                        So all commands for the RGB-Stripe are within the shell scripts (monitor_on / off.sh).
                                        And as u can see, i used GPIO 17,22 and 24.
                                        17 = red
                                        22 = green
                                        24 = blue
                                        To control the LEDs i used PIGPIOD and it’s commands, as i wrote.
                                        So after installing PIGIOD u can start it with:
                                        sudo pigpiod
                                        Commands like pigs p 22 128 will set green to 50%.
                                        pigs p 24 255 will set blue to 100%
                                        in the shell script i fade all colors from 1 to 12% with sleeps.
                                        Edit:
                                        As i wrote before u need to Autostart pigpiod via rc.local.
                                        sudo nano /etc/rc.local
                                        Mine looks like this:
                                        #!/bin/sh -e
                                        # rc.local
                                        # This script is executed at the end of each multiuser runlevel.
                                        # Make sure that the script will "exit 0" on success or any other
                                        # value on error.
                                        # In order to enable or disable this script just change the execution
                                        # bits.
                                        # By default this script does nothing.
                                        # Print the IP address
                                        _IP=$(hostname -I) || true
                                        if [ "$_IP" ]; then
                                          printf "My IP address is %s\n" "$_IP"
                                        fi
                                        iwconfig wlan0 power off &
                                        sleep 5 &
                                        /usr/local/bin/pigpiod
                                        sleep 10 &
                                        /usr/bin/python /home/pi/pir.py &
                                        exit 0
                                        metalldetectorM 1 Reply Last reply Reply Quote 0
                                        • metalldetectorM
                                          @cruunnerr ok I think this is the right way and I understand it with the led pin on Pin16
                                          … Just the flickering looks not good… I try a other power consumption…
                                          …can I only fade the LEDs or can I make a light like a animation around my mirror?
                                          Thanks for your help … And so fast.
                                          This is a good forum for me…
                                          Thx to all guys
                                          • cruunnerrC
                                            cruunnerr
                                            Well, if i had to do that project gain, i would not choose the RGB-5050 stripes again…
                                            I would directly get WS2812, because u just need one PWM Pin and with that you were able to do things like animations…
                                            In another project (infinity table) i choosed this one and was pretty amused :)
                                            https://youtu.be/IcDjzh03W-4
