    My First Mirror... until now ^^
    37 Posts 17 Posters 56.0k Views 18 Watching
      doubleT Module Developer
      I really like how you integrated the motion sensor! The rest is a little bit too much “screen” (as opposed to mirror) for me, but I can see the appeal. I like it.
      • cruunnerrC
        cruunnerr
        @doubleT said in My First Mirror... until now ^^:
        i know what you mean ^^
        But since i found out how many things can be shown with the MM, i couldn’t let it be :D
        Maybe the background is “too much”, but i like it anyhow XD
        but if i turn on the room lights, its bright enough to use it as a mirror :P
        Mykle1M 1 Reply Last reply
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @cruunnerr
          @cruunnerr said in My First Mirror... until now ^^:
          Whatever you like is how your mirror should be.
          Again, well done, mate. :-)
          Peace
          • cruunnerrC
            cruunnerr
            Very tinkered cause i am experimenting a lot ^^
            • F
              fischi87
              Hello, is a really awesome mirror really!!!
              one question, how can i get the header over the qr code picture?
              thanks
              cruunnerrC 1 Reply Last reply
              • cruunnerrC
                cruunnerr @fischi87
                @fischi87
                Just type a header in the config:
                    			module: "MMM-EasyPix",
                			header: "WLAN-Code",
                			position: "bottom_left",
                				picName: "guest_wifi_config.png", // Enter the picture file name.
                				maxWidth: "150px",      // Size picture precisely. Retains aspect ratio.
                F 1 Reply Last reply
                • F
                  fischi87 @cruunnerr
                  @cruunnerr
                  ah yes alright, thanks
                  • metalldetectorM
                    metalldetector
                    hi… i have motion detector pir. and a led5050 strip.
                    can you please provide the software part between pir and led… for dimming and on off feature … pleeeese
                    thx
                    • cruunnerrC
                      cruunnerr
                      Hey @metalldetector
                      I already did somewhere in the forum ^^
                      You need to install PIGPIOD.
                      sudo apt-get install build-essential python-dev unzip wget
                      wget http://abyz.me.uk/rpi/pigpio/pigpio.zip && unzip pigpio.zip && cd PIGPIO && sudo make install
                      Connect the PIR like shown at Part 2.2 and follow the guide:
                      https://forum.magicmirror.builders/topic/6291/howto-turn-on-off-your-monitor-time-based-pir-button-app?page=1
                      When creating the pir.py and fill ist with this code:
                      #!/usr/bin/env python
                      import sys
                      import time
                      import RPi.GPIO as io
                      import subprocess
                      import pigpio
                      io.setmode(io.BCM)
                      SHUTOFF_DELAY = 119 # seconds
                      PIR_PIN = 25       # 22 on the board
                      LED_PIN = 16
                      def main():
                          io.setup(PIR_PIN, io.IN)
                          io.setup(LED_PIN, io.OUT)
                          turned_off = False
                          last_motion_time = time.time()
                          while True:
                              if io.input(PIR_PIN):
                                  io.output(LED_PIN, io.LOW)
                                  print ".",
                                  sys.stdout.flush()
                                  if turned_off:
                                      turned_off = False
                                      turn_on()
                              else:
                                  if not turned_off and time.time() > (last_motion_time +
        SHUTOFF_DELAY):
                                      turned_off = True
                                      turn_off()
                                  if not turned_off and time.time() > (last_motion_time + 1):
                                      io.output(LED_PIN, io.HIGH)
                              time.sleep(.1)
                      def turn_on():
                      	subprocess.call("sh /home/pi/monitor_on.sh", shell=True)
                      def turn_off():
                      	subprocess.call("sh /home/pi/monitor_off.sh", shell=True)
                      if __name__ == '__main__':
                          try:
                              main()
                          except KeyboardInterrupt:
                              io.cleanup()
                      For the monitor_on.sh use this:
                      vcgencmd display_power 1
                      pigs p 17 1
                      pigs p 22 1
                      pigs p 24 1
                      sleep 0.06s
                      pigs p 17 2
                      pigs p 22 2
                      pigs p 24 2
                      sleep 0.06s
                      pigs p 17 3
                      pigs p 22 3
                      pigs p 24 3
                      sleep 0.06s
                      pigs p 17 4
                      pigs p 22 4
                      pigs p 24 4
                      sleep 0.06s
                      pigs p 17 5
                      pigs p 22 5
                      pigs p 24 5
                      sleep 0.06s
                      pigs p 17 6
                      pigs p 22 6
                      pigs p 24 5
                      sleep 0.06s
                      pigs p 17 7
                      pigs p 22 7
                      pigs p 24 6
                      sleep 0.06s
                      pigs p 17 8
                      pigs p 22 8
                      pigs p 24 7
                      sleep 0.06s
                      pigs p 17 9
                      pigs p 22 9
                      pigs p 24 8
                      sleep 0.06s
                      pigs p 17 10
                      pigs p 22 10
                      pigs p 24 9
                      sleep 0.06s
                      pigs p 17 11
                      pigs p 22 11
                      pigs p 24 10
                      sleep 0.06s
                      pigs p 17 12
                      pigs p 22 12
                      pigs p 24 11
                      For monitor_off.sh use this:
                      pigs p 17 12
                      pigs p 22 12
                      pigs p 24 11
                      sleep 0.06s
                      pigs p 17 11
                      pigs p 22 11
                      pigs p 24 10
                      sleep 0.06s
                      pigs p 17 10
                      pigs p 22 10
                      pigs p 24 9
                      sleep 0.06s
                      pigs p 17 9
                      pigs p 22 9
                      pigs p 24 8
                      sleep 0.06s
                      pigs p 17 8
                      pigs p 22 8
                      pigs p 24 7
                      sleep 0.06s
                      pigs p 17 7
                      pigs p 22 7
                      pigs p 24 6
                      sleep 0.06s
                      pigs p 17 6
                      pigs p 22 6
                      pigs p 24 5
                      sleep 0.06s
                      pigs p 17 5
                      pigs p 22 5
                      pigs p 24 5
                      sleep 0.06s
                      pigs p 17 4
                      pigs p 22 4
                      pigs p 24 4
                      sleep 0.06s
                      pigs p 17 4
                      pigs p 22 4
                      pigs p 24 4
                      sleep 0.06s
                      pigs p 17 3
                      pigs p 22 3
                      pigs p 24 3
                      sleep 0.06s
                      pigs p 17 2
                      pigs p 22 2
                      pigs p 24 2
                      vcgencmd display_power 0
                      sleep 0.06s
                      pigs p 17 1
                      pigs p 22 1
                      pigs p 24 1
                      sleep 0.06s
                      pigs p 17 0
                      pigs p 22 0
                      pigs p 24 0
                      Hope that helps. Try to find your best way and ask, if u need more help :)
                      Edit:
                      Oh and u need to start Pigpio on reboot with rc.local. ;)
                      metalldetectorM N 2 Replies Last reply
                      Reply Quote 3
                      • swvalentiS
                        swvalenti Project Sponsor
                        If you told me that your background wasn’t a stock photo I would upvote this! Nice work!
                        • cruunnerrC
                          cruunnerr
                          Well, meanwhile i changed my background, but still love it :P
                          Bild Text
                          • metalldetectorM
                            metalldetector @cruunnerr
                            @c:face_with_steam_from_nose: ruunnerr ok that works…
                            -What ist the Funktion of LED_PIN = 16 .
                            Only one pin …
                            Do I need RGB pins in the script?
                            -And then the led stripe start it’s flickering…
                            Thx4yourhelp
                            • cruunnerrC
                              cruunnerr
                              LED-Pin just shows, if the PIR detects motion. You don’t need to use it.
                              The pir.py script starts the other shell scripts when motion is detected.
                              So all commands for the RGB-Stripe are within the shell scripts (monitor_on / off.sh).
                              And as u can see, i used GPIO 17,22 and 24.
                              17 = red
                              22 = green
                              24 = blue
                              To control the LEDs i used PIGPIOD and it’s commands, as i wrote.
                              So after installing PIGIOD u can start it with:
                              sudo pigpiod
                              Commands like pigs p 22 128 will set green to 50%.
                              pigs p 24 255 will set blue to 100%
                              in the shell script i fade all colors from 1 to 12% with sleeps.
                              Edit:
                              As i wrote before u need to Autostart pigpiod via rc.local.
                              sudo nano /etc/rc.local
                              Mine looks like this:
                              #!/bin/sh -e
                              # rc.local
                              # This script is executed at the end of each multiuser runlevel.
                              # Make sure that the script will "exit 0" on success or any other
                              # value on error.
                              # In order to enable or disable this script just change the execution
                              # bits.
                              # By default this script does nothing.
                              # Print the IP address
                              _IP=$(hostname -I) || true
                              if [ "$_IP" ]; then
                                printf "My IP address is %s\n" "$_IP"
                              fi
                              iwconfig wlan0 power off &
                              sleep 5 &
                              /usr/local/bin/pigpiod
                              sleep 10 &
                              /usr/bin/python /home/pi/pir.py &
                              exit 0
                              metalldetectorM 1 Reply Last reply
                              • metalldetectorM
                                @cruunnerr ok I think this is the right way and I understand it with the led pin on Pin16
                                … Just the flickering looks not good… I try a other power consumption…
                                …can I only fade the LEDs or can I make a light like a animation around my mirror?
                                Thanks for your help … And so fast.
                                This is a good forum for me…
                                Thx to all guys
                                • cruunnerrC
                                  cruunnerr
                                  Well, if i had to do that project gain, i would not choose the RGB-5050 stripes again…
                                  I would directly get WS2812, because u just need one PWM Pin and with that you were able to do things like animations…
                                  In another project (infinity table) i choosed this one and was pretty amused :)
                                  https://youtu.be/IcDjzh03W-4
                                  • metalldetectorM
                                    metalldetector
                                    Yes. But what is the difference between WS2812, WS2812, neopixel…
                                    What is the best stripe with a good price…
                                    I think a meter for 60 euro is to much…
                                    Greetings from Saxony, Germany
                                    • cruunnerrC
                                      cruunnerr
                                      https://de.aliexpress.com/item/1m-2m-3m-4m-5m-ws2812b-ws2812-led-strip-individually-addressable-smart-led-strip-black-white/32682015405.html?spm=a2g0x.search0104.3.9.4eef3dc9EKAZdz&ws_ab_test=searchweb0_0,searchweb201602_3_10065_10068_10547_319_317_10548_10696_10084_453_10083_454_10618_10304_10307_10820_10821_537_10302_536_10843_10059_10884_10887_321_322_10103,searchweb201603_6,ppcSwitch_0&algo_expid=b24b32fc-d347-41f0-b20b-702e47e2d79c-1&algo_pvid=b24b32fc-d347-41f0-b20b-702e47e2d79c&transAbTest=ae803_3
                                      I have got this one. 5m with 60 LEDs per meter for about 17€
                                      • metalldetectorM
                                        @cruunnerr very good deal.
                                        But what is the difference in the product options… blue or black pcm …
                                        • metalldetectorM
                                          metalldetector
                                          Mensch… du sprichst bestimmt deutsch…
                                          Wie hast du die Temperatur Module angebunden?
                                          Etwa mit wlan esp’s ?
                                          • cruunnerrC
                                            cruunnerr
                                            Blau und schwarz beschreibt nur die Farbe des Streifens selber (nicht der LED). Also für die Funktion egal.
                                            Naja, also die Temperaturen kommen von meinem IoBroker Server. Um ehrlich zu sein habe ich schon länger nicht mehr an meinem Spiegel gearbeitet, sondern andere Projekte gestartet und vollendet.
                                            Mein ganzes Haus ist mittlerweile steuerbar (Licht, Thermostate, Lautsprecher etc…). Unter anderem habe ich eben auch Temperatursensoren von Xiaomi im Einsatz, die ihre Werte an meinen Server schicken.
                                            Auf dem Spiegel zeige ich die Werte dann mit dem MMM-iobroker Modul an.
                                            Aber ich habe auch viel mit ESP’s gemacht. Habe derzeit ca. 8 Stück im Einsatz. Einer steuert meine komplette Heizung. Einer steuert meine Klingel. Einer wertet meine Alarmanlage aus. Zwei sind für meinen Infinity Tisch… etc. pp… ^^
                                            Macht ziemlich viel Spaß
                                            Blue and black only describes the color of the strip itself (not the LED). So no matter for the function.
                                            Well, so the temperatures come from my IoBroker server. To be honest, I have not worked on my mirror for some time, but started and completed other projects.
                                            My whole house is now controllable (lights, thermostats, speakers etc …). Among other things, I have also used temperature sensors from Xiaomi, which send their values to my server.
                                            On the mirror I then display the values with the [MMM-iobroker] (https://github.com/ioBroker/MMM-ioBroker) module.
                                            But I also did a lot of ESP’s. Currently have about 8 pieces in use. One controls my entire heater. One controls my bell. One evaluates my alarm system. Two are for my infinity table … etc. pp … ^^
                                            It’s a lot of fun
