    My First Mirror... until now ^^
    37 Posts 17 Posters 48.8k Views 18 Watching
    • cruunnerrC Offline
      cruunnerr
      Hey all,
      first i want to say, that this is a great community and it makes fun to be a part of it.
      Since i decided to build a MagicMirror i was more and more interested what you can do with it. So now i want to show you my first exemplar. At least one more is in planning.
      The original plan was to install the mirror, so that you can only see the front frame. I had to postpone that later. That’s why he’s hanging on the wall now.
      I build the frame with wood, but i put some acrylic glass on the front and on the sides.
      I drilled a hole in the middle for the PIR.
      In addition, speakers are installed, but are not yet in operation (I still explore the applications / modules and think about what I still want to process)
      Fun fact: Because the PIR always detected the movement of my dog i put some clear nail polish on the lower half of the PIR :) Works great.
      I just used one 12V / 5A power supply. The 12V is used for the 23" Monitor and the LED Stripe. For the rPi i used a Step Down Converter and put it to 5.1V
      Next time i hang the mirror up, i will take some pics from behind ;)
      Installed modules:
      calendar_monthly
      MMM-EasyPix (for Wifi-QR-Code)
      MMM-GoogleMapsTraffic
      MMM-MyCalendar
      MMM-PIR-Sensor
      MMM-MyCommute
      MMM-NOAA
      MMM-Scrobbler
      MMM-Remote-Control
      MMM-Remote-Control-Repository
      MMM-SystemStats
      MMM-Watchdog
      MMM-Wunderlist
      MMM-internet-monitor (not visible)
      I also have a wifi watchdog installed because my wifi connection sometimes breaks off.
      It automatically turn the wifi controller off and on again, when the pi can’t ping my router.
      I found the LED Stripe somewhere in my house. It is a RGB Stripe 5050.
      Since there is no Module for this Stripe i used some mosfet’s and an external Application and wrote a script to turn it slowly on and off when movement is detected by the PIR.
      For the Wifi-QR code i used this guide and let the picture show via MMM-EasyPix (thanks to @mykle1 ;) ).
      For the background image i used the custom.css
      Hope you enjoy :)
      https://youtu.be/DHIKPTTG0q4
      1 Reply Last reply Reply Quote 6
        Very well done, mate!
        Now, ask your desktop picture to turn around. ;-)
        • cowboysdudeC Offline
          WOW that really looks awesome!! I love the LED lights!!!
          • N Offline
            nikobelohlav
            Looks Fantastic! i have a couple questions though, how did you add the backround (THE GIRL)?, how is your PIR setup, i want to add one for mine but have been trying to figure out how to make the screen just turn black instead of shutting off completely , and last one is how did you get scrobbler to work? I installed scrobbler on my mirror but it only worked if i had last.fm running on a computer within my network and half the time it was’nt “seeing” what i was playing. any insight to those questions would be great, feel free to message me directly so you thread doesnt get packed with a bunch of non-essential post. thanks
            • yawnsY Offline
              yawns Moderator @nikobelohlav
              @nikobelohlav said in My First Mirror... until now ^^:
              Like this: https://forum.magicmirror.builders/topic/351/add-a-background-image
                barnosch
                Sieht super aus!
                Vergess bloß nicht die Fusselrolle zu kaufen ;)
                  cruunnerr
                  Thanks for the compliments.
                  You can add a background with your custom.css like the link u posted, yawns.
                  My custom.css looks like this:
                   * Magic Mirror                                      *
                   * Custom CSS                                        *
                   * By Michael Teeuw http://michaelteeuw.nl           *
                   * MIT Licensed.                                     *
                   * Add any custom CSS below.                         *
                   * Changes to this files will be ignored by GIT. *
                   body {
                  	background-image: url("background9.jpg");
                  	background-size: cover;
                  	margin-left: 0px;
                  	margin-right: 30px;
                  	margin-top: 15px;
                  	margin-bottom: 15px;
                    	position: absolute;
                    	height: calc(100% - 28px);
                    	width: calc(100% - 22px);
                  .MMM-SystemStats  {
                          color: #CEF6CE;
                  .MMM-MyCalendar {
                    max-width: 300px;
                  The image is called “background9.jpg” and has been placed in the “home/pi/MagicMirror/css” folder.
                  I needed to play a little bit with the margin’s, until it fits perfect. Keep in mind that your picture should fit the screen resolution. It shouldn’t be smaller. if it is, you should take a look at the MMM-ProfilePicture module.
                  @nikobelohlav
                  I just used the MMM-PIR module for it. It turns the HDMI signal off, and my monitor recognized that via HDMI-CEC/ARC and turns off. When the signal comes back the motor turns on within 2 seconds. thats quick enough i think.
                  I don’t know if it is possible to change the MMM-Pir-Sensor.js so that not the command “tvservice …” is executed, but a notification will be sent to other modules like the profile-switcher. Maybe you should open a new thread, even if I don’t quite understand why you don’t want to turn off your monitor.
                  The scrobbler module was a little bit tricky. First you need to register your apps, to share the current playing music with last.fm.
                  I actually just use Spotify, so in the Spotify-settings of my phone, tablet and macbook i needed to login to last.fm via the Spotify app.
                  Sometimes i got the same problem as you, but its not a failure of the module. I played music and checked on last.fm if there is actually scribbling something, but there wasn’t. Then i turn back to my Spotify app and just log out and log in again (to last.fm in the Spotify settings) and that brings the scrobbling back.
                  So its more a bug, that happens sometimes, cause Spotify didn’t correctly streams to last.fm i think.
                  When u don’t pause the music it should scrobble continuous.
                  Also keep in mind:
                  When is a scrobble a scrobble?
                  A track should only be scrobbled when the following conditions have been met:
                  The track must be longer than 30 seconds.
                  And the track has been played for at least half its duration, or for 4 minutes (whichever occurs earlier.)
                  As soon as these conditions have been met, the scrobble request may be sent at any time. It is often most convenient to send a scrobble request when a track has finished playing.
                  @barnosch
                  Ja im Winter ist es manchmal schlimm mit den Hundis ^^
                    doubleT Module Developer
                    I really like how you integrated the motion sensor! The rest is a little bit too much “screen” (as opposed to mirror) for me, but I can see the appeal. I like it.
                      cruunnerr
                      @doubleT said in My First Mirror... until now ^^:
                      i know what you mean ^^
                      But since i found out how many things can be shown with the MM, i couldn’t let it be :D
                      Maybe the background is “too much”, but i like it anyhow XD
                      but if i turn on the room lights, its bright enough to use it as a mirror :P
                        Mykle1 Project Sponsor Module Developer @cruunnerr
                        @cruunnerr said in My First Mirror... until now ^^:
                        Whatever you like is how your mirror should be.
                        Again, well done, mate. :-)
                        Peace
                        • 1 / 4
