Solved Need help with internet monitor-module
Check your quotes. Change this: ’ to this: " and apply the missing quotes @
Maxtime
update … Etc. -
And please check the following link: https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners/2
Right now, the config.js you posted is near-unreadable.
Both schlachtkreuzer6 and doubleT are totally right. I tried to change the post with your config, but akismet.com flags this as spam.
Besides wrong quotes the position of your added module was incorrect.
Please try this config:/* Magic Mirror Config Sample By Michael Teeuw http://michaelteeuw.nl MIT Licensed. For more information how you can configurate this file See https://github.com/MichMich/MagicMirror#configuration */ var config = { address: "localhost", port: 8080, ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses language: "en", timeFormat: 24, units: "metric", modules: [ { module: "alert", }, { module: "updatenotification", position: "top_bar" }, { module: "clock", position: "top_left" }, { module: "calendar", header: "US Holidays", position: "top_left", config: { calendars: [ { symbol: "calendar-check-o ", url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics" } ] } }, { module: "compliments", position: "lower_third" }, { module: "currentweather", position: "top_right", config: { location: "New York", locationID: "", //ID from http://www.openweathermap.org/help/city_list.txt appid: "YOUR_OPENWEATHER_API_KEY" } }, { module: "weatherforecast", position: "top_right", header: "Weather Forecast", config: { location: "New York", locationID: "5128581", //ID from http://www.openweathermap.org/help/city_list.txt appid: "YOUR_OPENWEATHER_API_KEY" } }, { module: "newsfeed", position: "bottom_bar", config: { feeds: [ { title: "New York Times", url: "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml" } ], showSourceTitle: true, showPublishDate: true } }, { module: "internet-monitor", position: "top_center", header: "Internet Monitor", config: { type: "", maxTime: 20000, updateInterval: 0, verbose: false, displayStrength: true, displaySpeed: true, strengthIconSize: 80, maxGaugeScale: 100, wifiSymbol: { size: 50, fullColor: "#3afc25", almostColor: "#ffff0c", halfColor: "#ff8c00", noneColor: "#ff1111" }, }, }, ] }; /*************** DO NOT EDIT THE LINE BELOW ***************/ if (typeof module !== "undefined") {module.exports = config;}
@yawns wow, thanks!, but now my screen is just black… tried rebooting:/ anu suggestions?
Might not be the problem (as modern browser are pretty forgiving about this) but the last property of an object (or array) doesn’t get a trailing comma.
Other than that I don’t see any obvious problems. A black screen is better than a config error because it might load the basic MM but just not the modules.
Now, what I can suggest and what a developer would do is:
- Reduce the config.js to the basics or the originally suggested example.
- Add one module after another, always checking if it works or not.
- If one doesn’t work or breaks something, note it down, remove it, try the next one. Or figure out directly why it doesn’t work.
But that way you can easily point to where it breaks. Everything else is guesswork.
@yawns it gives me the damn config error… plz help!
@duedahlb do you change the quotes and the missing quotes? than upload your config again pls.
@schlachtkreuzer6 it’s just the standard file, with one extra module…
/* Magic Mirror Config Sample * * By Michael Teeuw http://michaelteeuw.nl * MIT Licensed. * * For more information how you can configurate this file * See https://github.com/MichMich/MagicMirror#configuration * */ var config = { address: "localhost", // Address to listen on, can be: // - "localhost", "127.0.0.1", "::1" to listen on loopback interface // - another specific IPv4/6 to listen on a specific interface // - "", "0.0.0.0", "::" to listen on any interface // Default, when address config is left out, is "localhost" port: 8080, ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses // or add a specific IPv4 of 192.168.1.5 : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.5"], // or IPv4 range of 192.168.3.0 --> 192.168.3.15 use CIDR format : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/28"], language: "en", timeFormat: 24, units: "metric", modules: [ { module: "alert", }, { module: "updatenotification", position: "top_bar" }, { module: "clock", position: "top_left" }, { module: "calendar", header: "US Holidays", position: "top_left", config: { calendars: [ { symbol: "calendar-check-o ", url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics" } ] } }, { module: "compliments", position: "lower_third" }, { module: "currentweather", position: "top_right", config: { location: "New York", locationID: "", //ID from http://www.openweathermap.org/help/city_list.txt appid: "YOUR_OPENWEATHER_API_KEY" } }, { module: "weatherforecast", position: "top_right", header: "Weather Forecast", config: { location: "New York", locationID: "5128581", //ID from http://www.openweathermap.org/help/city_list.txt appid: "YOUR_OPENWEATHER_API_KEY" } }, { module: "newsfeed", position: "bottom_bar", config: { feeds: [ { title: "New York Times", url: "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml" } ], showSourceTitle: true, showPublishDate: true } }, { module: 'internet-monitor', position: 'top_center', header: 'Internet Monitor', config:{ type: '', maxTime: 20000, updateInterval: 0, verbose: false, displayStrength: true, displaySpeed: true, strengthIconSize: 80, maxGaugeScale: 100, wifiSymbol:{ size: 50, fullColor: '#3afc25', almostColor: '#ffff0c', halfColor: '#ff8c00', noneColor: '#ff1111' }, }, } ] }; /*************** DO NOT EDIT THE LINE BELOW ***************/ if (typeof module !== "undefined") {module.exports = config;}
did you install the dependencies as per the readme? I just installed this, installed the dependencies, and it fired right up.
@Mykle1 said in Need help with internet monitor-module:
yes i did, but i can do it again:)
