    Need help with internet monitor-module
    20 Posts 5 Posters 9.7k Views 6 Watching
      duedahlb @schlachtkreuzer6
      @schlachtkreuzer6 I uploaded the standard file now… and the script module i want to use too
      • schlachtkreuzer6S Offline
        schlachtkreuzer6 @duedahlb
        @duedahlb
        Check your quotes. Change this: ’ to this: " and apply the missing quotes @
        Maxtime
        update … Etc.
          doubleT Module Developer
          And please check the following link: https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners/2
          Right now, the config.js you posted is near-unreadable.
          • yawnsY Offline
            yawns Moderator
            Both schlachtkreuzer6 and doubleT are totally right. I tried to change the post with your config, but akismet.com flags this as spam.
            Besides wrong quotes the position of your added module was incorrect.
            Please try this config:
            /* Magic Mirror Config Sample
            By Michael Teeuw http://michaelteeuw.nl
            MIT Licensed.
            For more information how you can configurate this file
            See https://github.com/MichMich/MagicMirror#configuration
            var config = {
            address: "localhost",
            port: 8080,
            language: "en",
            timeFormat: 24,
            units: "metric",
            		module: "alert",
            		module: "updatenotification",
            		position: "top_bar"
            		module: "clock",
            		position: "top_left"
            		header: "US Holidays",
            					symbol: "calendar-check-o ",
            		module: "compliments",
            		position: "lower_third"
            		module: "currentweather",
            			locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
            		module: "weatherforecast",
            		header: "Weather Forecast",
            			locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
            		module: "newsfeed",
            		position: "bottom_bar",
            			feeds: [
            					title: "New York Times",
            			showSourceTitle: true,
            			showPublishDate: true
            		module: "internet-monitor",
            		position: "top_center",
            		header: "Internet Monitor",
            			type: "",
            			maxTime: 20000,
            			updateInterval: 0,
            			verbose: false,
            			displayStrength: true,
            			displaySpeed: true,
            			strengthIconSize: 80,
            			maxGaugeScale: 100,
            			wifiSymbol: {
            				fullColor: "#3afc25",
            				almostColor: "#ffff0c",
            				halfColor: "#ff8c00",
            				noneColor: "#ff1111"
            D 2 Replies Last reply Reply Quote 1
              duedahlb @yawns
              @yawns wow, thanks!, but now my screen is just black… tried rebooting:/ anu suggestions?
                Might not be the problem (as modern browser are pretty forgiving about this) but the last property of an object (or array) doesn’t get a trailing comma.
                Other than that I don’t see any obvious problems. A black screen is better than a config error because it might load the basic MM but just not the modules.
                Now, what I can suggest and what a developer would do is:
                • Reduce the config.js to the basics or the originally suggested example.
                • Add one module after another, always checking if it works or not.
                • If one doesn’t work or breaks something, note it down, remove it, try the next one. Or figure out directly why it doesn’t work.
                But that way you can easily point to where it breaks. Everything else is guesswork.
                  duedahlb @yawns
                  @yawns it gives me the damn config error… plz help!
                  schlachtkreuzer6S 1 Reply Last reply Reply Quote 0
                    @duedahlb do you change the quotes and the missing quotes? than upload your config again pls.
                      @schlachtkreuzer6 it’s just the standard file, with one extra module…
                       * MIT Licensed.
                      var config = {
                      	port: 8080,
                      	language: "en",
                      	timeFormat: 24,
                      	units: "metric",
                      			module: "alert",
                      			position: "top_bar"
                      			module: "clock",
                      			module: "newsfeed",
                      				feeds: [
                      	    	module: 'internet-monitor',
                                  	position: 'top_center',
                                  	header: 'Internet Monitor',
                                  	config:{
                                      	type: '',
                                      	maxTime: 20000,
                                      	updateInterval: 0,
                                      	verbose: false,
                                      	displaySpeed: true,
                                      	maxGaugeScale: 100,
                      			wifiSymbol:{
                                          		fullColor: '#3afc25',
                                          		almostColor: '#ffff0c',
                                          		halfColor: '#ff8c00',
                      	            		noneColor: '#ff1111'
                        Mykle1 Project Sponsor Module Developer @duedahlb
                        @duedahlb
                        did you install the dependencies as per the readme? I just installed this, installed the dependencies, and it fired right up.
