    Need help with internet monitor-module
    20 Posts 5 Posters 10.8k Views 6 Watching
      doubleT Module Developer
      Might not be the problem (as modern browser are pretty forgiving about this) but the last property of an object (or array) doesn’t get a trailing comma.
      Other than that I don’t see any obvious problems. A black screen is better than a config error because it might load the basic MM but just not the modules.
      Now, what I can suggest and what a developer would do is:
      • Reduce the config.js to the basics or the originally suggested example.
      • Add one module after another, always checking if it works or not.
      • If one doesn’t work or breaks something, note it down, remove it, try the next one. Or figure out directly why it doesn’t work.
      But that way you can easily point to where it breaks. Everything else is guesswork.
        duedahlb @yawns
        @yawns it gives me the damn config error… plz help!
          schlachtkreuzer6 @duedahlb
          @duedahlb do you change the quotes and the missing quotes? than upload your config again pls.
          D 1 Reply Last reply
            duedahlb @schlachtkreuzer6
            @schlachtkreuzer6 it’s just the standard file, with one extra module…
            /* Magic Mirror Config Sample
             * MIT Licensed.
            var config = {
            	port: 8080,
            	language: "en",
            	timeFormat: 24,
            	units: "metric",
            			module: "alert",
            			module: "updatenotification",
            			position: "top_bar"
            			module: "clock",
            			position: "top_left"
            			header: "US Holidays",
            						symbol: "calendar-check-o ",
            			module: "compliments",
            			position: "lower_third"
            			module: "currentweather",
            				locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
            			module: "weatherforecast",
            			header: "Weather Forecast",
            				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
            			module: "newsfeed",
            			position: "bottom_bar",
            				feeds: [
            						title: "New York Times",
            				showSourceTitle: true,
            				showPublishDate: true
            	    	module: 'internet-monitor',
                        	position: 'top_center',
                        	header: 'Internet Monitor',
                        	config:{
                            	type: '',
                            	maxTime: 20000,
                            	updateInterval: 0,
                            	verbose: false,
                            	displayStrength: true,
                            	displaySpeed: true,
                            	strengthIconSize: 80,
                            	maxGaugeScale: 100,
            			wifiSymbol:{
                                		fullColor: '#3afc25',
                                		almostColor: '#ffff0c',
                                		halfColor: '#ff8c00',
            	            		noneColor: '#ff1111'
            Mykle1M 1 Reply Last reply
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @duedahlb
              @duedahlb
              did you install the dependencies as per the readme? I just installed this, installed the dependencies, and it fired right up.
              D 2 Replies Last reply
                duedahlb @Mykle1
                @Mykle1 said in Need help with internet monitor-module:
                @duedahlb
                yes i did, but i can do it again:)
                  I don’t see any problem with it. But to be on the safe side, I changed the single quotes in the config object for the internet-monitor to double quotes (as the rest of the file), what Schlachtkreuzer said. Again, shouldn’t be an issue – unless it’s conflicting with single quotes in a different place.
                      module: "internet-monitor",
                      position: "top_center",
                      header: "Internet Monitor",
                      config:{
                          type: "",
                          maxTime: 20000,
                          updateInterval: 0,
                          verbose: false,
                          displaySpeed: true,
                          maxGaugeScale: 100,
                          wifiSymbol:{
                              fullColor: "#3afc25",
                              almostColor: "#ffff0c",
                              halfColor: "#ff8c00",
                              noneColor: "#ff1111"
                  What happens if you leave out that module? Does it work then?
                  Are there any errors listed in the console where you start the mirror? Any errors listed in the browser’s console (if you start it with npm start dev)?
                    schlachtkreuzer6
                    Try this
                        config:{
                            type: "",
                            maxTime: "20000",
                            updateInterval: "0",
                            verbose: "false",
                            displayStrength: "true",
                            displaySpeed: "true",
                            strengthIconSize: "80",
                            maxGaugeScale: "100",
                                    wifiSymbol:{
                      That doesn’t make sense, the functions are expecting integer and boolean, not strings.
                      But maybe I found something while checking the module’s readme for the variables and default config:
                      “Please note that updateInterval has to be greater than maxTime”
                      https://github.com/ronny3050/internet-monitor
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @doubleT
                        My config entry:
                                    config:{
                                        type: '',
                                        maxTime: 20000,
                                        updateInterval: 0,
                                        verbose: false,
                                        displaySpeed: true,
                                        maxGaugeScale: 100,
                        And my result:
                          duedahlb @Mykle1
                          @Mykle1 I got it now! I just reinstalled it, tnx:)
                          • Mykle1M
                            @duedahlb
                            Well done, mate.
