    Need help with internet monitor-module
    20 Posts 5 Posters 10.5k Views 6 Watching
      schlachtkreuzer6 @duedahlb
      @duedahlb do you change the quotes and the missing quotes? than upload your config again pls.
        duedahlb @schlachtkreuzer6
        @schlachtkreuzer6 it’s just the standard file, with one extra module…
        /* Magic Mirror Config Sample
         * MIT Licensed.
        var config = {
        	port: 8080,
        	language: "en",
        	timeFormat: 24,
        	units: "metric",
        			module: "alert",
        			module: "updatenotification",
        			position: "top_bar"
        			module: "clock",
        			position: "top_left"
        			header: "US Holidays",
        						symbol: "calendar-check-o ",
        			module: "compliments",
        			position: "lower_third"
        			module: "currentweather",
        				locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
        			module: "weatherforecast",
        			header: "Weather Forecast",
        				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
        			module: "newsfeed",
        			position: "bottom_bar",
        				feeds: [
        						title: "New York Times",
        				showSourceTitle: true,
        				showPublishDate: true
        	    	module: 'internet-monitor',
                    	position: 'top_center',
                    	header: 'Internet Monitor',
                    	config:{
                        	type: '',
                        	maxTime: 20000,
                        	updateInterval: 0,
                        	verbose: false,
                        	displayStrength: true,
                        	displaySpeed: true,
                        	strengthIconSize: 80,
                        	maxGaugeScale: 100,
        			wifiSymbol:{
                            		fullColor: '#3afc25',
                            		almostColor: '#ffff0c',
                            		halfColor: '#ff8c00',
        	            		noneColor: '#ff1111'
          Mykle1 Project Sponsor Module Developer @duedahlb
          @duedahlb
          did you install the dependencies as per the readme? I just installed this, installed the dependencies, and it fired right up.
            duedahlb @Mykle1
            @Mykle1 said in Need help with internet monitor-module:
            @duedahlb
            yes i did, but i can do it again:)
              doubleT Module Developer
              I don’t see any problem with it. But to be on the safe side, I changed the single quotes in the config object for the internet-monitor to double quotes (as the rest of the file), what Schlachtkreuzer said. Again, shouldn’t be an issue – unless it’s conflicting with single quotes in a different place.
                  module: "internet-monitor",
                  position: "top_center",
                  header: "Internet Monitor",
                  config:{
                      type: "",
                      maxTime: 20000,
                      updateInterval: 0,
                      verbose: false,
                      displaySpeed: true,
                      maxGaugeScale: 100,
                      wifiSymbol:{
                          fullColor: "#3afc25",
                          almostColor: "#ffff0c",
                          halfColor: "#ff8c00",
                          noneColor: "#ff1111"
              What happens if you leave out that module? Does it work then?
              Are there any errors listed in the console where you start the mirror? Any errors listed in the browser’s console (if you start it with npm start dev)?
                schlachtkreuzer6
                Try this
                    config:{
                        type: "",
                        maxTime: "20000",
                        updateInterval: "0",
                        verbose: "false",
                        displayStrength: "true",
                        displaySpeed: "true",
                        strengthIconSize: "80",
                        maxGaugeScale: "100",
                                wifiSymbol:{
                  That doesn’t make sense, the functions are expecting integer and boolean, not strings.
                  But maybe I found something while checking the module’s readme for the variables and default config:
                  “Please note that updateInterval has to be greater than maxTime”
                  https://github.com/ronny3050/internet-monitor
                    Mykle1 Project Sponsor Module Developer @doubleT
                    My config entry:
                                config:{
                                    type: '',
                                    maxTime: 20000,
                                    updateInterval: 0,
                                    verbose: false,
                                    displaySpeed: true,
                                    maxGaugeScale: 100,
                    And my result:
                      duedahlb @Mykle1
                      @Mykle1 I got it now! I just reinstalled it, tnx:)
                        @duedahlb
                        Well done, mate.
