    Need help with internet monitor-module
    20 Posts 5 Posters 10.6k Views 6 Watching
    • Y Offline
      yawns Moderator
      Both schlachtkreuzer6 and doubleT are totally right. I tried to change the post with your config, but akismet.com flags this as spam.
      Besides wrong quotes the position of your added module was incorrect.
      Please try this config:
      /* Magic Mirror Config Sample
      By Michael Teeuw http://michaelteeuw.nl
      MIT Licensed.
      For more information how you can configurate this file
      See https://github.com/MichMich/MagicMirror#configuration
      var config = {
      address: "localhost",
      port: 8080,
      language: "en",
      timeFormat: 24,
      units: "metric",
      		module: "alert",
      		module: "updatenotification",
      		position: "top_bar"
      		module: "clock",
      		position: "top_left"
      		header: "US Holidays",
      					symbol: "calendar-check-o ",
      		module: "compliments",
      		position: "lower_third"
      		module: "currentweather",
      			locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
      		module: "weatherforecast",
      		header: "Weather Forecast",
      			locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
      		module: "newsfeed",
      		position: "bottom_bar",
      			feeds: [
      					title: "New York Times",
      			showSourceTitle: true,
      			showPublishDate: true
      		module: "internet-monitor",
      		position: "top_center",
      		header: "Internet Monitor",
      			type: "",
      			maxTime: 20000,
      			updateInterval: 0,
      			verbose: false,
      			displayStrength: true,
      			displaySpeed: true,
      			strengthIconSize: 80,
      			maxGaugeScale: 100,
      			wifiSymbol: {
      				fullColor: "#3afc25",
      				almostColor: "#ffff0c",
      				halfColor: "#ff8c00",
      				noneColor: "#ff1111"
      D 2 Replies Last reply Reply Quote 1
        duedahlb @yawns
        @yawns wow, thanks!, but now my screen is just black… tried rebooting:/ anu suggestions?
          doubleT Module Developer
          Might not be the problem (as modern browser are pretty forgiving about this) but the last property of an object (or array) doesn’t get a trailing comma.
          Other than that I don’t see any obvious problems. A black screen is better than a config error because it might load the basic MM but just not the modules.
          Now, what I can suggest and what a developer would do is:
          • Reduce the config.js to the basics or the originally suggested example.
          • Add one module after another, always checking if it works or not.
          • If one doesn’t work or breaks something, note it down, remove it, try the next one. Or figure out directly why it doesn’t work.
          But that way you can easily point to where it breaks. Everything else is guesswork.
            duedahlb @yawns
            @yawns it gives me the damn config error… plz help!
              schlachtkreuzer6 @duedahlb
              @duedahlb do you change the quotes and the missing quotes? than upload your config again pls.
                duedahlb @schlachtkreuzer6
                @schlachtkreuzer6 it’s just the standard file, with one extra module…
                 * MIT Licensed.
                var config = {
                	port: 8080,
                	language: "en",
                	timeFormat: 24,
                	units: "metric",
                			module: "alert",
                			position: "top_bar"
                			module: "clock",
                			module: "newsfeed",
                				feeds: [
                	    	module: 'internet-monitor',
                            	position: 'top_center',
                            	header: 'Internet Monitor',
                            	config:{
                                	type: '',
                                	maxTime: 20000,
                                	updateInterval: 0,
                                	verbose: false,
                                	displaySpeed: true,
                                	maxGaugeScale: 100,
                			wifiSymbol:{
                                    		fullColor: '#3afc25',
                                    		almostColor: '#ffff0c',
                                    		halfColor: '#ff8c00',
                	            		noneColor: '#ff1111'
                  Mykle1 Project Sponsor Module Developer @duedahlb
                  @duedahlb
                  did you install the dependencies as per the readme? I just installed this, installed the dependencies, and it fired right up.
                    duedahlb @Mykle1
                    @Mykle1 said in Need help with internet monitor-module:
                    @duedahlb
                    yes i did, but i can do it again:)
                      I don’t see any problem with it. But to be on the safe side, I changed the single quotes in the config object for the internet-monitor to double quotes (as the rest of the file), what Schlachtkreuzer said. Again, shouldn’t be an issue – unless it’s conflicting with single quotes in a different place.
                          config:{
                              type: "",
                              maxTime: 20000,
                              updateInterval: 0,
                              verbose: false,
                              displaySpeed: true,
                              maxGaugeScale: 100,
                              wifiSymbol:{
                      What happens if you leave out that module? Does it work then?
                      Are there any errors listed in the console where you start the mirror? Any errors listed in the browser’s console (if you start it with npm start dev)?
                        schlachtkreuzer6
                        Try this
                            config:{
                                type: "",
                                maxTime: "20000",
                                updateInterval: "0",
                                verbose: "false",
                                displayStrength: "true",
                                displaySpeed: "true",
                                strengthIconSize: "80",
                                maxGaugeScale: "100",
                                        wifiSymbol:{
                          That doesn’t make sense, the functions are expecting integer and boolean, not strings.
                          But maybe I found something while checking the module’s readme for the variables and default config:
                          “Please note that updateInterval has to be greater than maxTime”
                          https://github.com/ronny3050/internet-monitor
                            Mykle1 Project Sponsor Module Developer @doubleT
                            My config entry:
                                        config:{
                                            type: '',
                                            maxTime: 20000,
                                            updateInterval: 0,
                                            verbose: false,
                                            displaySpeed: true,
                                            maxGaugeScale: 100,
                            And my result:
                              duedahlb @Mykle1
                              @Mykle1 I got it now! I just reinstalled it, tnx:)
                                @duedahlb
                                Well done, mate.
