    1 old noob + 1 rPi = I can't believe I did it! (revisited)
    193 Posts 29 Posters 478.9k Views 28 Watching
    • Mykle1M
      Hello Lucy! (my granddaughter)
      And here are the modifications I’ve made in Lucy’s name so far.
      https://youtu.be/M9C0ppGFJik
      Reply Quote 4
      • ChrisC
        Chris
        Superb work, as usual :)
        Could you point me to how to put this system in place?
        Having already installed the open-jarvis solution, I do not know if it would create a conflict or if I have to adapt your solution via jarvis voice recognition.
        Thank you in advance, truthfully yours,
        Mykle1M 2 Replies Last reply
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @Chris
          @Chris
          This is my own personal project at the moment. It involves many, many modifications to the MMM-voice module and any module that will be used in conjunction with it. I only just recently got it working to some satisfaction but I am still working on it. It’s going to take some time before I am done with it because I hope to add more features to it. I’ll keep you posted.
          It may create a conflict for you and jarvis voice when all is said and done.
          ChrisC 1 Reply Last reply
          • ChrisC
            Chris @Mykle1
            @Mykle1
            This seems very promising,
            I would follow with great interest this project,
            Good luck to you for the future,
            • Mykle1M
              @Chris said in 1 old noob + 1 rPi = I can’t believe I did it! (revisited):
              Hi Chris,
              I put together a repo with directions on how to use this system. I don’t know if you’re going to run into any problems with jarvis but this will work with any module you choose with some modifications on your part. It’s all in the directions.
              https://github.com/mykle1/Hello-Lucy
              And the most recent video with sound enhancement to the system
              https://youtu.be/ZXWf7s3K3as
              strawberry 3.141S ChrisC 2 Replies Last reply
              • strawberry 3.141S
                strawberry 3.141 Project Sponsor Module Developer @Mykle1
                @Mykle1 looks good
                Mykle1M 1 Reply Last reply
                • ChrisC
                  Chris @Mykle1
                  @Mykle1
                  Very good work,
                  I will be happy to test it on PI sometime this week as soon as I have time and you will return,
                  thank you very much
                  • Mykle1M
                    Mykle1 Project Sponsor Module Developer @strawberry 3.141
                    @strawberry-3.141
                    I don’t know about that, but it does work, even if it’s not done the proper way. I’m happy with it. It does what I want it to do and it works amazingly well on an old laptop.
                    • Mykle1M
                      thank you very much
                      You’re welcome, mate. Let me know how it goes
                      • Mykle1M
                        Hello Lucy with Pages!
                        https://youtu.be/bKHEXPzVb2A
                        A 1 Reply Last reply
                        Reply Quote 2
                        • Mykle1M
                          Just tested some new commands for turning off (standby) and on the display. Works on a laptop AND a desktop machine with monitor connected through DVI
                          • Mykle1M
                            Improved page functionality. Each page command will hide the previous page while still retaining the ability to hide and show individual modules and put the display into standby and wake it up. “Please Wake Up” will show the last used configuration as “Go To Sleep” affects the monitor, not MM. :-)
                            https://www.youtube.com/watch?v=2-K5NlT9zgQ
                            • Mykle1M
                              Bone diggity
                              • Mykle1M
                                • Mykle1M
                                  https://youtu.be/M3QvF-ctZEA
                                  • Mykle1M
                                    Ridiculous!
                                    https://youtu.be/08Ueb_cg9oA
                                    • Mykle1M
                                      https://youtu.be/syr_GCnpv2A
                                      • A
                                        achillealb @Mykle1
                                        @Mykle1 said in 1 old noob + 1 rPi = I can’t believe I did it! (revisited):
                                        'HIDE PAGE ONE',  'SHOW PAGE ONE',   for example page
                                        		'HIDE PAGE TWO',  'SHOW PAGE TWO',   for example page
                                        		'HIDE PAGE THREE','SHOW PAGE THREE', for example page
                                        works with the MMM-pages module or which module uses ???
                                        then post your config.js file
                                        • Mykle1M
                                          Mykle1 Project Sponsor Module Developer @achillealb
                                          @achillealb said in 1 old noob + 1 rPi = I can’t believe I did it! (revisited):
                                          Uhh . . . I’m sorry but you’ll have to be a bit clearer in your question. I’m not sure of what you are asking me.
                                          • A
                                            achillealb
                                            Ok, maybe I understand, i have to read well in
                                            How to add Pages of modules
                                            • 10
                                            • 7 / 10
