    (2.1.0) Calendar will broadcast events.
    Scheduled Pinned Locked Moved Upcoming Features
    9 Posts 5 Posters 10.8k Views 6 Watching
    • MichMichM
      MichMich
      Starting from MagicMirror² v2.1.0 (currently in develop stage) the default calendar module will broadcast all the events to all other modules with the notification message: CALENDAR_EVENTS. The event objects are stored in an array and contain the following fields: title, startDate, endDate, fullDayEvent, location and geo.
      Since this feature is still in the develop branch, it’s not final and might change. Suggestions are welcome.
        jer78
        Hi, I just started using MM and love it! Thanks for all your hard work! How would I use this to calculate my commute time in a different module? Is there an example? Thank you.
        Jeremy
        Mykle1M A 2 Replies Last reply
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @jer78
          @jer78
          There are a few modules that do that although it depends on where you are. Find the one that suits you, if it’s there.
          https://github.com/MichMich/MagicMirror/wiki/3rd-Party-Modules
            jer78
            My question was how do I pass along a variable from Calendar to another module. I’m trying to find what the format is.
            Mykle1M 1 Reply Last reply
            • Mykle1M
              @jer78 said in (2.1.0) Calendar will broadcast events.:
              Well, not exactly, young man. :-/
              https://github.com/MichMich/MagicMirror/tree/master/modules
              J 1 Reply Last reply
              • N
                ninjabreadman
                @jer78 Here is the Readme.md for third party modules, which details the notification system: https://github.com/MichMich/MagicMirror/blob/master/modules/README.md
                Your module will receive a CALENDAR_EVENTS notification, with a payload which is an array of calendar events objects with the following attributes: title, startDate, endDate, fullDayEvent, location and geo.
                You can make your own module, or modify an existing one. MMM-Traffic will display Google Maps directions to a given destination. You can override its receiveNotification function to (1) sort the payload to find the soonest event, (2) decide if there’s an event in the next 2 hours, and (3) display directions to the destination using the location or geo coordinates.
                Remember, you’ll need to populate those fields when creating your event entries, and you may also need to provide a hint (e.g. “Colombus, OH”) to Google so it knows which “Olive Garden” or “Municipal Library” you’re looking for.
                Reply Quote 2
                  jer78 @Mykle1
                  @Mykle1 said in (2.1.0) Calendar will broadcast events.:
                  Someone woke up on the wrong side of the bed! Geez! What a hostile community. Nice to feel welcome for my first post!
                    jer78 @ninjabreadman
                    @ninjabreadman Awesome! Thanks for pointing me in the right direction. Cheers!
                    • A
                      ATibbs @jer78
                      @jer78 If you are still looking to get this configured see this thread here. I had (what I believe to be) the exact same request and I got it working with this.
                      https://forum.magicmirror.builders/post/38213
