show integer logs from python script as diagram in MM ?
Hey guys,
i am trying again to get a new feature to my MM ^^
Background Story:
I finally installed a second Raspberry Pi on my heat oil tank for measuring the tank level.
Therefore i am using a HC-SR04 and a python script i found in the web.
As the script just showed the actual measurement in the console, i modified it to write the logs in a *.txt and a *.html file.
The script will be executed once a day via crontab.The index.html will be completely overwritten every time the script will be executed. Then the file will be uploaded to my NAS.
Actually i am using an iFrame module in the MM to show the result. This was just for trying it out :)The *.txt file is doing the longtime log of the results. At the moment it writes a time stamp and the result at the end of the file.
For future measurements i could also just print the result (in the script it is “Liter”).Question:
My aim is to show the longtime logs in a diagram on the MM. Probably this is just possible with html and an iFrame module, right or not?
It should look like this, just in MM-style:
https://forum-raspberrypi.de/attachment/5997-monatsansicht-03-jpg/or this: https://www.raspberrypi.org/forums/viewtopic.php?t=83808
If so, could someone help me find a good solution? Because writing html with python isn’t that easy^^
And I master neither python nor htmlHere comes the tank.py:
#!/usr/bin/env python # -*- coding: utf-8 -*- # import required modules import time import datetime import RPi.GPIO as GPIO import os import ftplib GPIO.setwarnings(False) print("Fair volume...") # define GPIO pins GPIOTrigger = 18 GPIOEcho = 24 # function to measure the distance def MeasureDistance(): # set trigger to high time.sleep(0.2) GPIO.output(GPIOTrigger, True) # set trigger after 10µs to low time.sleep(0.0001) GPIO.output(GPIOTrigger, False) # store initial start time StartTime = time.time() # store start time while GPIO.input(GPIOEcho) == 0: StartTime = time.time() # store stop time while GPIO.input(GPIOEcho) == 1: StopTime = time.time() # calculate distance TimeElapsed = StopTime - StartTime Distance = (TimeElapsed * 34400) / 2 return Distance # main function def main(): try: # while True: Distance0 = MeasureDistance() Distance01 = MeasureDistance() Distance02 = MeasureDistance() Distance03 = MeasureDistance() Distance04 = MeasureDistance() Distance05 = MeasureDistance() Distance06 = MeasureDistance() Distance07 = MeasureDistance() Distance08 = MeasureDistance() Distance09 = MeasureDistance() Distance10 = MeasureDistance() Distance11 = MeasureDistance() Distance12 = MeasureDistance() Distance13 = MeasureDistance() Distance14 = MeasureDistance() Distance15 = MeasureDistance() Distance16 = MeasureDistance() Distance17 = MeasureDistance() Distance18 = MeasureDistance() Distance19 = MeasureDistance() Distance20 = MeasureDistance() Distance_sum = Distance01 + Distance02 + Distance03 + Distance04 + Distance05 + Distance06 + Distance07 + Distance08 + Distance09 + Distance10 + Distance11 + Distance12 + Distance13 + Distance14 + Distance15 + Distance16 + Distance17 + Distance18 + Distance19 + Distance20 Distance = round(Distance_sum / 20,1) # Meine Tanks haben Maximal 3.200 Liter bei 150 cm Füllhöhe # Zusätzlich 9 cm Offset vom Einbauort des Sensors; Fuelstand = 150 - Distance Liter = 3200 / 141 * Fuelstand Zeit = time.time() ZeitStempel = datetime.datetime.fromtimestamp(Zeit).strftime('%Y-%m-%d_%H:%M:%S') print (ZeitStempel),("Entfernung: %.1f cm" % Distance),(" Fuelhoehe: %.1f cm" % Fuelstand),(" Liter: %.0f l" % Liter) time.sleep(1) Auslesezeitpunkt = datetime.datetime.fromtimestamp(Zeit).strftime('%d.%m.%Y um %H:%M:%S Uhr') # write result in *.txt file (add to last line) file = open("longtimelog.txt", "a") file.write(str(Auslesezeitpunkt)) file.write(":\n") file.write("Ölstand = ") file.write(str(Liter)) file.write("\n\n") file.close() # write result to *.html file (will be overwritten) file = open("index.html", "w") file.write("<p></p>") file.write(str(Auslesezeitpunkt)) file.write(":<p>") file.write("Oelstand = ") file.write(str(Liter)) file.write("</p>") file.write("<p></p><p></p><p></p>") file.close() print("Logs updated") time.sleep(1) print("Upload actual log...") # Lädt die index.html Datei auf das NAS filename = "index.html" ftp = ftplib.FTP("192.168.178.220") ftp.login("USER_NAME", "PASSWORD") ftp.cwd("/web") os.chdir(r"/home/pi") myfile = open("index.html", 'r') ftp.storlines('STOR ' + "index.html", myfile) myfile.close() time.sleep(1) print("Upload done") # reset GPIO settings if user pressed Ctrl+C except KeyboardInterrupt: print("Measurement stopped by user") GPIO.cleanup() if __name__ == '__main__': # use GPIO pin numbering convention GPIO.setmode(GPIO.BCM) # set up GPIO pins GPIO.setup(GPIOTrigger, GPIO.OUT) GPIO.setup(GPIOEcho, GPIO.IN) # set trigger to false GPIO.output(GPIOTrigger, False) # call main function main()Even this thought is not makable i would like to thank you guys ahead ;)
edit:
oh, and i found this here, but i don’t know if this would help.
@cruunnerr Hi, i dont know if u would like what i have but i made the same u want to have.
I also use a HC-SR04 and a python script, i think its the same u use i put all results in a json file and than
i read it with my openhab server so now i can display via (MMM-Openhab) the actual filling on my mirror.
Also to get a diagram is no problem . I would realy recomment u to take a look at openhab and what it can do. In case of questions please contact me … Robert -
I use highcharts to make a diagram for my gas station price module. It’s quite easy to implement and use if you have the data in an object.
since u wrote the brilliant Openhab module this would really be a good option :)
I will keep that in mind.@doubleT
i will take a look at it. looks great. But i am sure i will have questions :Dedit:
i also found this: https://forum.magicmirror.builders/topic/2470/mmm-chart-view-your-graphs-on-your-mirror
But what is meant by “JSON data source”? is it just a *.js file with text in it? And is that the only file needed to use this module? i am still looking. ^^
so i actually edited my python script, so that the results will be automatically loaded up to my MySQL Database on the Synology NAS.
With PHP i can show the Data as a diagram :)
So now i could use an iFrame module.
So far so good ^^ (never thought i get this working)next days i will take a look at the MMM-Chart Module and the OpenHAB solution. (or a other that maybe works with MySQL)
For those, who are interested so far:
#!/usr/bin/env python # -*- coding: utf-8 -*- # import required modules import time import datetime import RPi.GPIO as GPIO import os import ftplib import mysql import mysql.connector GPIO.setwarnings(False) # define server data # ftpserver = "..." //optional, when needed uncomment the FTP-Upload further down # ftpuser = "..." # ftppassword = "..." # ftppath = "/web" sqlhost = "..." sqlport = "..." sqluser = "..." sqlpassword = "..." sqldb = "Tank" # define GPIO pins GPIOTrigger = 18 GPIOEcho = 24 # function to measure the distance def MeasureDistance(): # set trigger to high time.sleep(0.2) GPIO.output(GPIOTrigger, True) # set trigger after 10µs to low time.sleep(0.0001) GPIO.output(GPIOTrigger, False) # store initial start time StartTime = time.time() # store start time while GPIO.input(GPIOEcho) == 0: StartTime = time.time() # store stop time while GPIO.input(GPIOEcho) == 1: StopTime = time.time() # calculate distance TimeElapsed = StopTime - StartTime Distance = (TimeElapsed * 34400) / 2 return Distance print("Messe Volumen...") # main function def main(): try: # while True: Distance0 = MeasureDistance() Distance01 = MeasureDistance() Distance02 = MeasureDistance() Distance03 = MeasureDistance() Distance04 = MeasureDistance() Distance05 = MeasureDistance() Distance06 = MeasureDistance() Distance07 = MeasureDistance() Distance08 = MeasureDistance() Distance09 = MeasureDistance() Distance10 = MeasureDistance() Distance11 = MeasureDistance() Distance12 = MeasureDistance() Distance13 = MeasureDistance() Distance14 = MeasureDistance() Distance15 = MeasureDistance() Distance16 = MeasureDistance() Distance17 = MeasureDistance() Distance18 = MeasureDistance() Distance19 = MeasureDistance() Distance20 = MeasureDistance() Distance_sum = Distance01 + Distance02 + Distance03 + Distance04 + Distance05 + Distance06 + Distance07 + Distance08 + Distance09 + Distance10 + Distance11 + Distance12 + Distance13 + Distance14 + Distance15 + Distance16 + Distance17 + Distance18 + Distance19 + Distance20 Distance = round(Distance_sum / 20,1) # Meine Tanks haben Maximal 3.200 Liter bei 150 cm Füllhöhe # Zusätzlich 9 cm Offset vom Einbauort des Sensors; Fuelstand = 150 - Distance Liter = 3200 / 141 * Fuelstand Zeit = time.time() ZeitStempel = datetime.datetime.fromtimestamp(Zeit).strftime('%Y-%m-%d_%H:%M:%S') print (ZeitStempel),("Entfernung: %.1f cm" % Distance),(" Fuelhoehe: %.1f cm" % Fuelstand),(" Liter: %.0f l" % Liter) time.sleep(.1) Auslesezeitpunkt = datetime.datetime.fromtimestamp(Zeit).strftime('%d-%m-%Y_%H:%M:%S') Tag = datetime.datetime.fromtimestamp(Zeit).strftime('%Y-%m-%d') Uhr = datetime.datetime.fromtimestamp(Zeit).strftime('%H:%M:%S') # schreibe Langzeitmessung in *.csv Datei file = open("longtimelog.csv", "a") file.write(str(Tag)) file.write(", ") file.write(str(Liter)) file.write("\n") file.close() # schreibe aktuelle Messung in *.csv Datei file = open("log.csv", "w") file.write(str(Tag)) file.write(", ") file.write(str(Liter)) file.write("\n") file.close() print("Logs aktualisiert") time.sleep(.1) print("Upload Logs auf FTP...") # Lädt die longtimelog.csv Datei auf das NAS # filename = "longtimelog.csv" # ftp = ftplib.FTP(ftpserver) # ftp.login(ftpuser, ftppassword) # ftp.cwd(ftppath) # os.chdir(r"/home/pi") # myfile = open("longtimelog.csv", 'r') # ftp.storlines('STOR ' + "longtimelog.csv", myfile) # myfile.close() # Lädt die log.csv Datei auf das NAS # filename = "log.csv" # ftp = ftplib.FTP(ftpserver) # ftp.login(ftpuser, ftppassword) # ftp.cwd(ftppath) # os.chdir(r"/home/pi") # myfile = open("log.csv", 'r') # ftp.storlines('STOR ' + "log.csv", myfile) # myfile.close() time.sleep(.1) print("Verbinde mit MySQL-Datenbank...") time.sleep(.1) try: connection = mysql.connector.connect(host = sqlhost, port = sqlport, user = sqluser, passwd = sqlpassword, db = sqldb) except: print "Keine Verbindung zum MySQL-Server" exit(0) cursor = connection.cursor() cursor.execute("INSERT INTO Volumen VALUES (%s,%s)", (Tag,Liter,)) cursor.close() connection.commit() time.sleep(.1) print("Upload erfolgreich") # reset GPIO settings if user pressed Ctrl+C except KeyboardInterrupt: print("Measurement stopped by user") GPIO.cleanup() if __name__ == '__main__': # use GPIO pin numbering convention GPIO.setmode(GPIO.BCM) # set up GPIO pins GPIO.setup(GPIOTrigger, GPIO.OUT) GPIO.setup(GPIOEcho, GPIO.IN) # set trigger to false GPIO.output(GPIOTrigger, False) # call main function main() -
@cruunnerr You could use a
mysqlmodule to query your database, create a route to output a JSON file, then useMMM-Chartsto display. -
@ninjabreadman said in show integer logs from python script as diagram in MM ?:
alright, that sound makable for me i think. ^^Will take a look. Thank you
edit: ehm…first question :D
i installed this now (seems to be newer). But where to start? Where i need to create the file, and what type of file, and how will it be loaded?
Is it a javascript file, which must be saved somewhere in the node directory? -
I have been following this, but I didn’t have time to comment.
You asked about the. json file. Simplyfied, it’s a file that holds a (JS) object for data sharing.
{{date:"2018-01-01", litre:500},{date:"2018-01-02", litre:498},{date:"2018-01-03", litre:495}}Probably comparable to what you did with your txt file.
For a working solution, that would actually be enough. Grab the json, handle the object, print the result with highcharts.
To me, the SQL db seems a bit “heavy weight” for such a simple use case, but it’s solid if you can make it work. Just my opinion. -
@cruunnerr @doubleT It would certainly be more easily handled in JSON or even a CSV (easiest to append readings). You can then set up
crontorsyncthe file to your mirror, load the file with annpmpackage likecsvorfast-csv, and display inMMM-Chart(I would modifyMMM-Chartto load the CSV directly). -
Yes, that’d be the easiest option. Could be running tonigt. ;)
Personally, I’d go with the json, though. I did it like this with Highcharts.js, which seems familiar to MMM-Charts:node-helper.js:
const fs = require("fs"); //... socketNotificationReceived: function(notification, payload) { if (notification === "UpdateChart") { this.getChart(); } }, getChart: function() { var rawdata = fs.readFileSync('path/to/my.json'); var history = JSON.parse(rawdata); var history = history.slice(-84); // 12 per day x 7 = I only want the last 84 data points this.sendSocketNotification("ChartUpdate", history); }module.js:
getScripts: function() { return [ this.file("highcharts/highcharts.js"), this.file("highcharts/series-label.js"), this.file("highcharts/exporting.js") ] }, socketNotificationReceived: function(notification, payload) { if (notification === "ChartUpdate") { this.getChart(payload); } }, getChart: function(history) { var chart = ""; for(i = 0; i < history.length; i++) { if (i === 0) { chart = history[i].litre; } else { chart = chart + ", " + history[i].price; } } var maxi = Math.max.apply(Math, JSON.parse("[" + chart + "]")); var highest = maxi.toString() + " L"; var mini = Math.min.apply(Math, JSON.parse("[" + chart + "]")); var lowest = mini.toString() + " L"; Highcharts.chart('module-chart', { // the id of the div to contain the chart! chart: { height: 175, margin: 0, left: 0 }, plotOptions: { series: { marker: { enabled: false } } }, tooltip: { pointFormat: "Value: {point.y:.2f}" }, yAxis: { min: mini-0.05, max: maxi+0.05, tickInterval: 0.05, plotLines: [{ value: this.price, dashStyle: 'solid', width: 1, color: { linearGradient: [0, 0, 900, 0], stops: [ [0, 'rgba(255, 255, 255, 0.1)'], [1, 'rgba(255, 255, 255, 0.2)'] ] } }, { value: Math.max.apply(Math, JSON.parse("[" + pricelist + "]")), dashStyle: 'dot', width: 1, color: { linearGradient: [0, 0, 900, 0], stops: [ [0, 'rgba(255, 255, 255, 0.2)'], [1, 'rgba(255, 255, 255, 0.3)'] ] }, label: { text: highest, x: -2, y: -7 } }, { value: Math.min.apply(Math, JSON.parse("[" + pricelist + "]")), dashStyle: 'dot', width: 1, color: { linearGradient: [0, 0, 900, 0], stops: [ [0, 'rgba(255, 255, 255, 0.2)'], [1, 'rgba(255, 255, 255, 0.3)'] ] }, label: { text: lowest, x: -2, y: 13 } }] }, series: [{ data: JSON.parse("[" + pricelist + "]"), // here's the action step: 'center', lineWidth: 2, color: { linearGradient: [0, 0, 900, 0], stops: [ [0, 'rgba(255, 255, 255, 0.4)'], [1, 'rgba(255, 255, 255, 1)'] ] } }] }); }
