    show integer logs from python script as diagram in MM ?
    18 Posts 4 Posters 7.5k Views 4 Watching
    • cruunnerrC Offline
      cruunnerr
      @tbbear
      since u wrote the brilliant Openhab module this would really be a good option :)
      I will keep that in mind.
      @doubleT
      i will take a look at it. looks great. But i am sure i will have questions :D
      edit:
      i also found this: https://forum.magicmirror.builders/topic/2470/mmm-chart-view-your-graphs-on-your-mirror
      But what is meant by “JSON data source”? is it just a *.js file with text in it? And is that the only file needed to use this module? i am still looking. ^^
        cruunnerr
        so i actually edited my python script, so that the results will be automatically loaded up to my MySQL Database on the Synology NAS.
        With PHP i can show the Data as a diagram :)
        So now i could use an iFrame module.
        So far so good ^^ (never thought i get this working)
        next days i will take a look at the MMM-Chart Module and the OpenHAB solution. (or a other that maybe works with MySQL)
        For those, who are interested so far:
        #!/usr/bin/env python
        # -*- coding: utf-8 -*-
        # import required modules
        import time
        import datetime
        import RPi.GPIO as GPIO
        import os
        import ftplib
        import mysql
        import mysql.connector
        GPIO.setwarnings(False)
        # define server data
        # ftpserver = "..."  //optional, when needed uncomment the FTP-Upload further down
        # ftpuser = "..."
        # ftppassword = "..."
        # ftppath = "/web"
        sqlhost = "..."
        sqlport = "..."
        sqluser = "..."
        sqlpassword = "..."
        sqldb = "Tank"
        # define GPIO pins
        GPIOTrigger = 18
        GPIOEcho    = 24
        # function to measure the distance
        def MeasureDistance():
          # set trigger to high
          time.sleep(0.2)
          GPIO.output(GPIOTrigger, True)
          # set trigger after 10µs to low
          time.sleep(0.0001)
          GPIO.output(GPIOTrigger, False)
          # store initial start time
          StartTime = time.time()
          # store start time
          while GPIO.input(GPIOEcho) == 0:
          # store stop time
          while GPIO.input(GPIOEcho) == 1:
            StopTime = time.time()
          # calculate distance
          TimeElapsed = StopTime - StartTime
          Distance = (TimeElapsed * 34400) / 2
          return Distance
        print("Messe Volumen...")
        # main function
        def main():
          try:
        #    while True:
              Distance0 = MeasureDistance()
              Distance01 = MeasureDistance()
              Distance02 = MeasureDistance()
              Distance03 = MeasureDistance()
              Distance04 = MeasureDistance()
              Distance05 = MeasureDistance()
              Distance06 = MeasureDistance()
              Distance07 = MeasureDistance()
              Distance08 = MeasureDistance()
              Distance09 = MeasureDistance()
              Distance10 = MeasureDistance()
              Distance11 = MeasureDistance()
              Distance12 = MeasureDistance()
              Distance13 = MeasureDistance()
              Distance14 = MeasureDistance()
              Distance15 = MeasureDistance()
              Distance16 = MeasureDistance()
              Distance17 = MeasureDistance()
              Distance18 = MeasureDistance()
              Distance19 = MeasureDistance()
              Distance20 = MeasureDistance()
              Distance_sum = Distance01 + Distance02 + Distance03 + Distance04 + Distance05 + Distance06 + Distance07 + Distance08 + Distance09 + Distance10 + Distance11 + Distance12 + Distance13 + Distance14 + Distance15 + Distance16 + Distance17 + Distance18 + Distance19 + Distance20
              Distance = round(Distance_sum / 20,1)
        #    Meine Tanks haben Maximal 3.200 Liter bei 150 cm Füllhöhe
        #    Zusätzlich 9 cm Offset vom Einbauort des Sensors;
              Fuelstand = 150 - Distance
              Liter = 3200 / 141 * Fuelstand
              Zeit = time.time()
              ZeitStempel = datetime.datetime.fromtimestamp(Zeit).strftime('%Y-%m-%d_%H:%M:%S')
              print (ZeitStempel),("Entfernung: %.1f cm" % Distance),(" Fuelhoehe: %.1f cm" % Fuelstand),(" Liter: %.0f l" % Liter)
              time.sleep(.1)
              Auslesezeitpunkt = datetime.datetime.fromtimestamp(Zeit).strftime('%d-%m-%Y_%H:%M:%S')
              Tag = datetime.datetime.fromtimestamp(Zeit).strftime('%Y-%m-%d')
              Uhr = datetime.datetime.fromtimestamp(Zeit).strftime('%H:%M:%S')
        	# schreibe Langzeitmessung in *.csv Datei
              file = open("longtimelog.csv", "a")
              file.write(str(Tag))
              file.write(", ")
              file.write(str(Liter))
              file.write("\n")
              file.close()
                # schreibe aktuelle Messung in *.csv Datei
              file = open("log.csv", "w")
              file.write(", ")
              file.write("\n")
              file.close()
              print("Logs aktualisiert")
              time.sleep(.1)
              print("Upload Logs auf FTP...")
                # Lädt die longtimelog.csv Datei auf das NAS
        #      filename = "longtimelog.csv"
        #      ftp = ftplib.FTP(ftpserver)
        #      ftp.login(ftpuser, ftppassword)
        #      ftp.cwd(ftppath)
        #      os.chdir(r"/home/pi")
        #      myfile = open("longtimelog.csv", 'r')
        #      ftp.storlines('STOR ' + "longtimelog.csv", myfile)
        #      myfile.close()
                # Lädt die log.csv Datei auf das NAS
        #      filename = "log.csv"
        #      ftp.cwd(ftppath)
        #      myfile = open("log.csv", 'r')
        #      ftp.storlines('STOR ' + "log.csv", myfile)
        #      myfile.close()
              time.sleep(.1)
              print("Verbinde mit MySQL-Datenbank...")
              time.sleep(.1)
              try:
                  connection = mysql.connector.connect(host = sqlhost, port = sqlport, user = sqluser, passwd = sqlpassword, db = sqldb)
              except:
                  print "Keine Verbindung zum MySQL-Server"
                  exit(0)
              cursor = connection.cursor()
              cursor.execute("INSERT INTO Volumen VALUES (%s,%s)", (Tag,Liter,))
              cursor.close()
              connection.commit()
              time.sleep(.1)
              print("Upload erfolgreich")
          # reset GPIO settings if user pressed Ctrl+C
          except KeyboardInterrupt:
            print("Measurement stopped by user")
            GPIO.cleanup()
        if __name__ == '__main__':
          # use GPIO pin numbering convention
          GPIO.setmode(GPIO.BCM)
          # set up GPIO pins
          GPIO.setup(GPIOTrigger, GPIO.OUT)
          GPIO.setup(GPIOEcho, GPIO.IN)
          # set trigger to false
          # call main function
          main()
        • N Offline
          ninjabreadman @cruunnerr
          @cruunnerr You could use a mysql module to query your database, create a route to output a JSON file, then use MMM-Charts to display.
          cruunnerrC 1 Reply Last reply Reply Quote 0
            cruunnerr @ninjabreadman
            @ninjabreadman said in show integer logs from python script as diagram in MM ?:
            alright, that sound makable for me i think. ^^Will take a look. Thank you
            edit: ehm…first question :D
            i installed this now (seems to be newer). But where to start? Where i need to create the file, and what type of file, and how will it be loaded?
            Is it a javascript file, which must be saved somewhere in the node directory?
              doubleT Module Developer
              I have been following this, but I didn’t have time to comment.
              You asked about the. json file. Simplyfied, it’s a file that holds a (JS) object for data sharing.
              {{date:"2018-01-01", litre:500},{date:"2018-01-02", litre:498},{date:"2018-01-03", litre:495}}
              Probably comparable to what you did with your txt file.
              For a working solution, that would actually be enough. Grab the json, handle the object, print the result with highcharts.
              To me, the SQL db seems a bit “heavy weight” for such a simple use case, but it’s solid if you can make it work. Just my opinion.
              • N Offline
                @cruunnerr @doubleT It would certainly be more easily handled in JSON or even a CSV (easiest to append readings). You can then set up cron to rsync the file to your mirror, load the file with an npm package like csv or fast-csv, and display in MMM-Chart (I would modify MMM-Chart to load the CSV directly).
                  Yes, that’d be the easiest option. Could be running tonigt. ;)
                  Personally, I’d go with the json, though. I did it like this with Highcharts.js, which seems familiar to MMM-Charts:
                  node-helper.js:
                  const fs = require("fs");
                          if (notification === "UpdateChart") {
                          	this.getChart();
                      getChart: function() {
                  		var rawdata = fs.readFileSync('path/to/my.json');
                  		var history = JSON.parse(rawdata);
                  		var history = history.slice(-84); // 12 per day x 7 = I only want the last 84 data points
                  		this.sendSocketNotification("ChartUpdate", history);
                  module.js:
                      getScripts: function() {
                          return [
                              this.file("highcharts/highcharts.js"),
                              this.file("highcharts/series-label.js"),
                              this.file("highcharts/exporting.js")
                          if (notification === "ChartUpdate") {
                          	this.getChart(payload);
                      getChart: function(history) {
                          var chart = "";
                              for(i = 0; i < history.length; i++) {
                                  if (i === 0) {
                  	    		chart = history[i].litre;
                  	    	else {
                  	    		chart = chart + ", " + history[i].price;
                  	    var maxi = Math.max.apply(Math, JSON.parse("[" + chart + "]"));
                  	    var highest = maxi.toString() + " L";
                  	    var mini = Math.min.apply(Math, JSON.parse("[" + chart + "]"));
                  	    var lowest  = mini.toString() + " L";
                  	    Highcharts.chart('module-chart', { // the id of the div to contain the chart!
                  	    	chart: {
                  		    	height: 175,
                  		    	margin: 0,
                  		    	left: 0
                  	        plotOptions: {
                  	            series: {
                  	                marker: {
                  	                    enabled: false
                  	        tooltip: {
                  	            pointFormat: "Value: {point.y:.2f}"
                  	        yAxis: {
                  	            min: mini-0.05,
                  	            max: maxi+0.05,
                  	            tickInterval: 0.05,
                  	            plotLines: [{
                  	            	value: this.price,
                  	            	dashStyle: 'solid',
                  	            	width: 1,
                  	            	color: {
                  		                linearGradient: [0, 0, 900, 0],
                  		                stops: [
                  		                    [0, 'rgba(255, 255, 255, 0.1)'],
                  		                    [1, 'rgba(255, 255, 255, 0.2)']
                  	            	value: Math.max.apply(Math, JSON.parse("[" + pricelist + "]")),
                  	            	dashStyle: 'dot',
                  	            	width: 1,
                  	            	color: {
                                              stops: [
                                                  [0, 'rgba(255, 255, 255, 0.2)'],
                                                  [1, 'rgba(255, 255, 255, 0.3)']
                                          label: {
                                              text: highest,
                                              x: -2,
                                              y: -7
                                      value: Math.min.apply(Math, JSON.parse("[" + pricelist + "]")),
                                      dashStyle: 'dot',
                                      width: 1,
                                      color: {
                                          stops: [
                                      label: {
                                          text: lowest,
                                          x: -2,
                                          y: 13
                              series: [{
                                  data: JSON.parse("[" + pricelist + "]"), // here's the action
                                  step: 'center',
                                  lineWidth: 2,
                                  color: {
                  	            stops: [
                  	                [0, 'rgba(255, 255, 255, 0.4)'],
                  	                [1, 'rgba(255, 255, 255, 1)']
                    cruunnerr
                    wow, thank u guys for your effort :)
                    personally for me this project is not that easy, because i need to learn and understand several languages at the same time. So pls be patient ^^
                    While u posted here i was able to create a JSON file from the mysql database. But the results were looking like this:
                    [{"Datum":"2018-02-03T23:00:00.000Z","Volumen":2488},{"Datum":"2018-02-03T23:00:00.000Z","Volumen":2488},]
                    thats probably because the columns in the database are defined as “date” (not datetime) and “decimal”
                    I think i would get this right and could load this into the MMM-Chart.
                    But now u guys posted several solutions. The easiest would be to create a CSV and log this directly with the MMM-Chart @ninjabreadman said.
                    To create the CSV is no problem for me, but how changing the MMM-Chart… i need to pass a.t.m. ^^
                    Actually i’m not sure how node.js and npm works so i need to read and try a little bit more to understand it better :)
                    @doubleT
                    How exactly would highcharts work together with the MM? Is it just like a web page or what? :D
                    How to start it, where to put the files, and how to implement to MM?
                    For me it looks nearly like an own module for the MM.
                    Sorry for the much questions, but i am trying not just to use a finished solution. I want to nearly understand that whole stuff XD
                    Thank you guys, u are great
                    edit:
                    So i changed the columns definition from “date” to “text”.
                    Now my with the javascript using node i can get a JSON file looks correct:
                    [{"Datum":"2018-02-04","Volumen":2490},{"Datum":"2018-02-04","Volumen":2488},]
                    but i am using a very very simple script i think and i am just able to execute it manually by typing in terminal “node script.js”
                    also i don’t know in what direction this has to be saved.
                    var mysql      = require('mysql');
                    var fs = require('fs');
                    var connection = mysql.createConnection({
                      host: 'xxx.xxx.xxx.xxx',
                      port: '3307',
                      user: '...',
                      password: '...',
                      database: 'Tank'
                    connection.connect();
                    connection.query('SELECT * from Volumen', function(err, results, fields) {
                        if(err) throw err;
                        fs.writeFile('results.json', JSON.stringify(results), function (err) {
                          if (err) throw err;
                          console.log('Saved!');
                    connection.end();
                      Sorry, I didn’t want to confuse you. I’d suggest Highcharts if you want to build your own module (which I thought you were going for in the beginning). It’s a library that you load (you load the scripts) and use. You address it, tell it the id of the element where the chart should sit and the data it should show along with some parameters on how to show it.
                      But maybe in your case you really want to use MMM-Chart. On first look it seems like the JSON you have there should be totally enough! No CSV needed, as far as I can see from the readme.
                      What he has is similar to your JSON:
                      [["2017-04-21 15:58:00",8.3,95.5],["2017-04-21 14:55:00",9.3,90.5],["2017-04-21 12:56:00",10.7,87.7],["2017-04-21 11:53:00",10.5,87.7],["2017-04-21 11:01:00",10.6,88.8]]
                      It’s just that he has arrays in an array and you have objects with keys and values in an array.
                      I didn’t check, but maybe MMM-Chart works with your style, too. Else, you could try to get your JSON to write as arrays in an array:
                      [["2018-02-03T23:00:00.000Z",2488],["2018-02-03T23:00:00.000Z",2488]]
                      From then on, MMM-Chart should print your chart.
                      BTW. please check if you can edit your process/function that writes your JSON so there is no comma after the last object (or array, if you change it).
                        cruunnerr
                        @doubleT
                        i edited my post while u wrote this ^^
                        for the first i didn’t want to create a own module, but maybe later, when i understand the stuff good.
                        as u can read in my edit, i can create a JSON with the script i posted. but i don’t know where to put the script to execute it automatically every 24 hours or something like that.
                        because i think using cronjob would be the wrong way, right? :D
                        edit:
                        i just tried the MMM-Charts module, but i even cannot get this to work with a sample JSON.
                        i created a test.json and loaded it up to my NAS.
                        [["2018-02-04",2490],["2018-02-05",2488]]
                        in the MM config.js i used this config:
                                                module: 'MMM-Chart',
                                                position: 'middle_center',
                                                header: 'Tankvolumen',
                                                        url: "http://192.168.178.220/test.json",
                                                        xaxisLabelTicks: true,
                                                        maintainAspectRatio: false,
                                                        graphLabel0: "Volumen",
                                                        graphLineColor0: "rgba(200, 200, 200, 1)",
                                                        graphTickColor0: "rgba(200, 200, 200, 0.8)",
                                                        graphFillColor0: "rgba(200, 200, 200, 0.4)",
                                                        xaxisTimeUnit: "hour",
                                                        xaxisTimeFormatLabels: "HH:mm",
                        and modified the custom.css as said in the readme like this:
                        .test {
                        	width: 1060px;
                        	height: 180px;
                        But it just shows the header and a long line below.
                        i am sure i don’t use the module the correct way. ^^
