    Custom module_data in payload MMM remote control
    remote controlpythonmodule
    3 Posts 3 Posters 2.4k Views 3 Watching
      saifkazi
      Hello
      I was thinking that is it possible to sent custom module_data payload via remote control
      So I can display module at position of my choice . It would make quite easier to program via python by simply sending http get requests
      Regards Saif
      • N Offline
        ninjabreadman @saifkazi
        @saifkazi Have a look at node_helper.js and the answerPost() and answerGet() functions. You should be able to modify one to catch your additional data and modify the position of a given module. Not sure if you can change the position on the fly, or whether you need to write the config and restart the mirror.
          Jopyth Moderator @ninjabreadman
          @ninjabreadman That is indeed not very simple. It was something I wanted to implement too, but it turned out to be a little more complicated than I initially thought, since the MagicMirror project does not directly support this. But it could be done, and if so a PR or even just an initial implementation would be awesome.
