    MMM-xiaomi - Temperature and Humidity from your smarthome
    142 Posts 28 Posters 239.3k Views 28 Watching
      shgmongohh @Albert2002
      @Albert2002
      I have some problems to get the token. See my errors here.
      Can anybody help me with the token?
      Sebastian
        shgmongohh
        I like to change the colour and the font size of the values in the css. But nothing change.
        Can anybody please explain, how to change?
        .xm-xiaomi .small {
          font-size: 24px;
        .xm-xiaomi {
            position: relative;
        .xm-disabled {
          color: black;
        .xm-icon {
          padding-left: 8px;
        .xm-room-item {
          font-size: 22px;
          margin-bottom: -15px;
          z-index: 5;
        .xm-room-title {
          display: inline-block;
          width: 40%;
          z-index: 5;
        .xm-room-bars {
          width: 60%;
          z-index: 5;
        .xm-legend-temp {
          position: absolute;
          height: 100%;
          width: 3px;
          background-color: #FF1493;
          left: 9%;
          z-index: 0;
        .xm-legend-humid {
          position: absolute;
          height: 100%;
          width: 3px;
          background-color: blue;
          left: 42%;
          z-index: 0;
        .xm-room-container
            height: 100%;
            min-height: 100%;
            height: 200px;
        .xm-room {
            width: 33.33%;
            height: 33.33%;
          background-color: #228B22;
        .xm-room-header {
          border-bottom-style : solid;
          border-width: 1px;
         margin: 5px;
         //padding: 5px;
        .xm-left {
          float: left;
        .xm-right {
          float: right;
        .xm-room-temp-humid {
           margin: 5px;
        .xm-room-temp {
            float: left;
            width: 50%;
            padding-top:2px;
        .xm-room-humid {
            float: right;
            width: 50%;
            text-align: right;
            padding-top:2px;
        .xm-room-icons {
           margin: 5px;
           vertical-align: bottom;
          // height: 100%;
        .xm-door-icon {
          float: left;
          width: 33%;
          padding-top:5px;
        .xm-light-icon {
          float: left;
          width: 33%;
          text-align: center;
          padding-top:5px;
        .xm-vent-icon {
          float: right;
          width: 33%;
          text-align: right;
          padding-top:5px;
          mirko3000
          Hi, sorry I did not reply to your last comment, did you solve the issues there?
          About the CSS: basically you are at the right spot, adjusting these values (e.g. font-size) should change font size. What did you edit exactly? Did you try restarting MM after the changes?
            blinky1989dk
              barnosch
              @blinky1989dk said in MMM-xiaomi - Temperature and Humidity from your smarthome:
              to my config file. that’s fine, but it can not connect to the gateway. but as soon as I add more then it will be the case
              so when i restart it does not start up :( what can i do? some have some bids
              sorry i have no idea, what you try to say with that sentence.
                blinky1989dk @barnosch
                @barnosch my config file works. but as soon as i add mmm.xiaomi to config. then my config file does not work anymore and my mirror does not start up
                • Y
                  yawns Moderator
                  Your config looks a bit misconfigured. Please remove these lines.
                  If this is still not working, then please paste your entire config.
                    blinky1989dk @yawns
                    @yawns is dot work. so i had try to send config fil to you on pb
                    • Y
                      yawns Moderator
                      /* Magic Mirror Config Sample
                      By Michael Teeuw http://michaelteeuw.nl
                      MIT Licensed.
                      var config = {
                      zoom: 0.6,
                      port: 8080,
                      ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses.
                      language: "da",
                      timeFormat: 24,
                      units: "metric",
                      		module: "alert",
                      		module: "clock",
                      		position: "top_left"
                      		module: 'MMM-WunderGround',
                      		position: 'top_right',
                      			apikey: 'xxxxxxxxxxxxxxxxxxxxxx', // private; don't share!
                      			pws: 'pws:IVEJLE2', //culemborg
                      			hourly: '1',
                      			fctext: '1',
                      			fcdaycount: "5",
                      			fcdaystart: "0",
                      			hourlyinterval: "3",
                      			hourlycount: "2",
                      			alerttime: 10000,
                      			alerttruncatestring: "english:",
                      			roundTmpDecs: 1,
                      			UseCardinals: 0,
                      			layout: "vertical",
                      			iconset: "novaco",
                      			sysstat: 0
                      		module: "MMM-xiaomi",
                      		position: "bottom_left",
                      		header: "Temperature / Humidity", // This is optional
                      			gatewayIP: "192.168.10.170",
                      			gatewayToken: "xxxxxxxxxxxxxxxxxxx",
                      			showwindow: true,
                      			showVentilation: false,
                      			minTemperature: true,
                      			maxHumidity: true,
                      			showlights: true,
                      			rooms: [
                      			{ name: "test", sortOrder: 30, devices: ["158d0001b911b9"] },
                      Please try again. I don’t know which text editor you used, but it is very important to only use these around strings:
                      Do not use
                        shgmongohh @mirko3000
                        @mirko3000
                        Yes, i solved the problem with the token.
                        to my css:
                        I add
                        .xm-xiaomi .small {
                          font-size: 24px;
                        to get a bigger fonts.
                        I try to change the default colours e.g.
                        .xm-legend-temp {
                          position: absolute;
                          height: 100%;
                          width: 3px;
                          left: 9%;
                          z-index: 0;
                        And I want to have bigger figueres for temperature and humidity
                           margin: 10px;
                          blinky1989dk @yawns
                          @yawns okay THX. I Will try
                            blinky1989dk @yawns
                              joseska
                              Hi… We have an error with door sensor. Not show icons on MM. I think that the config is ok
                              			module: 'MMM-xiaomi',
                              			position: 'bottom_left',
                              			header: 'Temperatura / Humedad',
                              				gatewayIP: '192.168.1.103',
                              				gatewayToken: 'xxxxxxxxxxxx872e8bc25e415a7005a2',
                              				showWindow: true,
                              				showVentilation: true,
                              				showLights: false,
                              				audioNotifications: true,
                              				rooms: [
                              					{ name: 'Salon', sortOrder: 10, devices: ['158d0001f531bf', '158d00020258f4'] }
                              any idea???
                              Thanks…
                                mirko3000 @joseska
                                Hmm your config seems to be fine, make sure the IDs are ok, else it should work. Be aware that the icon only shows open window/doors, so if the door is closed you won’t see an icon.
                                I suppose the temperature sensor is working fine?
                                  joseska @mirko3000
                                  @mirko3000 Now Work… I don´t know why…
                                  simply copy again the id (the same) and change showVentilation: false (don´t have outdoor sensor) and work…
                                  sorry and thanks…
                                    Smotx
                                    HI,
                                    Anyone know why MMM Xiaomi need aplay ?
                                    Error: Cannot find module 'node-aplay'
                                        at Module._resolveFilename (module.js:543:15)
                                        at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                                        at Function.Module._load (module.js:473:25)
                                        at Module.require (module.js:586:17)
                                        at require (internal/module.js:11:18)
                                        at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-xiaomi/node_helper.js:11:20)
                                        at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-xiaomi/node_helper.js:140:3)
                                        at Module._compile (module.js:642:30)
                                        at Object.Module._extensions..js (module.js:653:10)
                                        at Module.load (module.js:561:32)
                                      Smotx @mirko3000
                                      @mirko3000 said in MMM-xiaomi - Temperature and Humidity from your smarthome:
                                      I just recieved my order of another 6 window sensors yesterday :) But I really think they will shut this down soon, guess they (gearbest) are not paying any taxes at all…
                                      Working on the new version, this is what I have in mind:
                                      How to have this screen ?
                                        Smotx @mirko3000
                                          Smotx
                                          it seems that these window sensors are not compatible.
                                          Xiaomi Aqara Window Door Sensor
                                          I added them to the config module and no return on MM.
                                          When i launch
                                          miio discover
                                          it found
                                          Device ID: 158d0001ab1f9c
                                          Model info: lumi.magnet.aq2
                                          but when i launch npm start, MMM-xiaomi say
                                          Found device with ID 158d0001ab1f9c of type generic
                                          and no
                                          Found device with ID 158d0001ab1f9c of type magnet
                                            Smotx
                                            Thanks to owner of module : @mirko3000 for update to see this sensor !
                                            Now that’s work
                                            • 6 / 8
