    MMM-xiaomi - Temperature and Humidity from your smarthome
    142 Posts 28 Posters 242.3k Views 28 Watching
      blinky1989dk
        barnosch
        @blinky1989dk said in MMM-xiaomi - Temperature and Humidity from your smarthome:
        to my config file. that’s fine, but it can not connect to the gateway. but as soon as I add more then it will be the case
        so when i restart it does not start up :( what can i do? some have some bids
        sorry i have no idea, what you try to say with that sentence.
        B 1 Reply Last reply
          blinky1989dk @barnosch
          @barnosch my config file works. but as soon as i add mmm.xiaomi to config. then my config file does not work anymore and my mirror does not start up
          • yawnsY
            yawns Moderator
            Your config looks a bit misconfigured. Please remove these lines.
            If this is still not working, then please paste your entire config.
              blinky1989dk @yawns
              @yawns is dot work. so i had try to send config fil to you on pb
              • yawnsY
                yawns Moderator
                /* Magic Mirror Config Sample
                By Michael Teeuw http://michaelteeuw.nl
                MIT Licensed.
                var config = {
                zoom: 0.6,
                port: 8080,
                ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses.
                language: "da",
                timeFormat: 24,
                units: "metric",
                		module: "alert",
                		module: "clock",
                		position: "top_left"
                		module: 'MMM-WunderGround',
                		position: 'top_right',
                			apikey: 'xxxxxxxxxxxxxxxxxxxxxx', // private; don't share!
                			pws: 'pws:IVEJLE2', //culemborg
                			hourly: '1',
                			fctext: '1',
                			fcdaycount: "5",
                			fcdaystart: "0",
                			hourlyinterval: "3",
                			hourlycount: "2",
                			alerttime: 10000,
                			alerttruncatestring: "english:",
                			roundTmpDecs: 1,
                			UseCardinals: 0,
                			layout: "vertical",
                			iconset: "novaco",
                			sysstat: 0
                		module: "MMM-xiaomi",
                		position: "bottom_left",
                		header: "Temperature / Humidity", // This is optional
                			gatewayIP: "192.168.10.170",
                			gatewayToken: "xxxxxxxxxxxxxxxxxxx",
                			showwindow: true,
                			showVentilation: false,
                			minTemperature: true,
                			maxHumidity: true,
                			showlights: true,
                			rooms: [
                			{ name: "test", sortOrder: 30, devices: ["158d0001b911b9"] },
                Please try again. I don’t know which text editor you used, but it is very important to only use these around strings:
                Do not use
                B 2 Replies Last reply
                  shgmongohh @mirko3000
                  @mirko3000
                  Yes, i solved the problem with the token.
                  to my css:
                  I add
                  .xm-xiaomi .small {
                    font-size: 24px;
                  to get a bigger fonts.
                  I try to change the default colours e.g.
                  .xm-legend-temp {
                    position: absolute;
                    height: 100%;
                    width: 3px;
                    background-color: #FF1493;
                    left: 9%;
                    z-index: 0;
                  And I want to have bigger figueres for temperature and humidity
                  .xm-room-temp-humid {
                     margin: 10px;
                    blinky1989dk @yawns
                    @yawns okay THX. I Will try
                      blinky1989dk @yawns
                        joseska
                        Hi… We have an error with door sensor. Not show icons on MM. I think that the config is ok
                        			module: 'MMM-xiaomi',
                        			position: 'bottom_left',
                        			header: 'Temperatura / Humedad',
                        				gatewayIP: '192.168.1.103',
                        				gatewayToken: 'xxxxxxxxxxxx872e8bc25e415a7005a2',
                        				showWindow: true,
                        				showVentilation: true,
                        				showLights: false,
                        				audioNotifications: true,
                        				rooms: [
                        					{ name: 'Salon', sortOrder: 10, devices: ['158d0001f531bf', '158d00020258f4'] }
                        any idea???
                        Thanks…
                        M 1 Reply Last reply
                          mirko3000 @joseska
                          Hmm your config seems to be fine, make sure the IDs are ok, else it should work. Be aware that the icon only shows open window/doors, so if the door is closed you won’t see an icon.
                          I suppose the temperature sensor is working fine?
                          J 1 Reply Last reply
                            joseska @mirko3000
                            @mirko3000 Now Work… I don´t know why…
                            simply copy again the id (the same) and change showVentilation: false (don´t have outdoor sensor) and work…
                            sorry and thanks…
                              Smotx
                              HI,
                              Anyone know why MMM Xiaomi need aplay ?
                              Error: Cannot find module 'node-aplay'
                                  at Module._resolveFilename (module.js:543:15)
                                  at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                                  at Function.Module._load (module.js:473:25)
                                  at Module.require (module.js:586:17)
                                  at require (internal/module.js:11:18)
                                  at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-xiaomi/node_helper.js:11:20)
                                  at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-xiaomi/node_helper.js:140:3)
                                  at Module._compile (module.js:642:30)
                                  at Object.Module._extensions..js (module.js:653:10)
                                  at Module.load (module.js:561:32)
                                Smotx @mirko3000
                                @mirko3000 said in MMM-xiaomi - Temperature and Humidity from your smarthome:
                                I just recieved my order of another 6 window sensors yesterday :) But I really think they will shut this down soon, guess they (gearbest) are not paying any taxes at all…
                                Working on the new version, this is what I have in mind:
                                How to have this screen ?
                                E 1 Reply Last reply
                                  Smotx @mirko3000
                                    Smotx
                                    it seems that these window sensors are not compatible.
                                    Xiaomi Aqara Window Door Sensor
                                    I added them to the config module and no return on MM.
                                    When i launch
                                    miio discover
                                    it found
                                    Device ID: 158d0001ab1f9c
                                    Model info: lumi.magnet.aq2
                                    but when i launch npm start, MMM-xiaomi say
                                    Found device with ID 158d0001ab1f9c of type generic
                                    and no
                                    Found device with ID 158d0001ab1f9c of type magnet
                                      Smotx
                                      Thanks to owner of module : @mirko3000 for update to see this sensor !
                                      Now that’s work
                                      • V
                                        VagelisAn
                                        Dear @mirko3000 i have follow your instraction and i install the MMM-Xiaomi, i install and the miio to get the access token but the scan of miio is not find the getaway accesstoken
                                        pi@raspberrypi:~ $ miio discover
                                         INFO  Discovering devices. Press Ctrl+C to stop.
                                        Device ID: 631XXXXX
                                        Model info: Unknown
                                        Address: XXX.XXX.X.XXX
                                        Token: ???
                                        Support: Unknown
                                        I use the MI application and get the ip and accessToken and the id from temperature sensor.
                                        The name is lumi.158xxxxxxxxxxx
                                        this is the code of config
                                        		header: 'Temperature / Humidity',  // This is optional
                                        			gatewayIP: 'IP getaway from MI home',
                                        			gatewayToken: 'accese getaway from MI home',
                                        			showWindow: true,
                                        			showLights: false,
                                        			rooms:  [
                                        					sortOrder: 10,
                                        					devices : ['lumi.158xxxxxxxxxxx']
                                        I execute and i have this error in terminal andthe xiaomi modules say connecting to xiaommi getaway.
                                        { Error: Call to device timed out
                                            at retry (/home/pi/MagicMirror/modules/MMM-xiaomi/node_modules/miio/lib/devi             ce.js:225:18)
                                            at _ensureToken.catch.err (/home/pi/MagicMirror/modules/MMM-xiaomi/node_modu             les/miio/lib/device.js:238:8)
                                            at <anonymous> code: 'timeout' }
                                        Sorry if my English is bad
                                        • G
                                          gh057
                                          Has anyone tried to get the module to work with a Gateway AND a Yeelight bed lamp ??
                                          I mean i have the module working with my gateway (manually added the token, and then the sensors appeard in miio discovery) but i havent managed to get it to work with the yeelight lamp (that also acts as a bluetooth gateway for my other sensors).
                                          When i reseted the lamp, and connected to its wifi, i discovered it with miio and extracted the token, but later when i registered the lamp with the mi app, and connected my pi to my wifi, while the lamp is pingable by the pi, now miio doesn’t discover it!!
                                          But, besides that, even if i manage to discover the lamp again with miio, i’m not aware if its even possible to add a second gateway to the module.
                                          Does anyone know??
                                          • G
                                            gauka12345
                                            HI there i have got same problem the gateway was turned off
                                            then i have tried to reconnect all the temperature sensors and tokens shows with ??? question marks… can some one help please!
                                            • 6 / 8
