    MMM-xiaomi - Temperature and Humidity from your smarthome
    142 Posts 28 Posters 242.3k Views 28 Watching
      blinky1989dk @yawns
        joseska
        Hi… We have an error with door sensor. Not show icons on MM. I think that the config is ok
        			module: 'MMM-xiaomi',
        			position: 'bottom_left',
        			header: 'Temperatura / Humedad',
        				gatewayIP: '192.168.1.103',
        				gatewayToken: 'xxxxxxxxxxxx872e8bc25e415a7005a2',
        				showWindow: true,
        				showVentilation: true,
        				showLights: false,
        				audioNotifications: true,
        				rooms: [
        					{ name: 'Salon', sortOrder: 10, devices: ['158d0001f531bf', '158d00020258f4'] }
        any idea???
        Thanks…
        M 1 Reply Last reply
          mirko3000 @joseska
          Hmm your config seems to be fine, make sure the IDs are ok, else it should work. Be aware that the icon only shows open window/doors, so if the door is closed you won’t see an icon.
          I suppose the temperature sensor is working fine?
          J 1 Reply Last reply
            joseska @mirko3000
            @mirko3000 Now Work… I don´t know why…
            simply copy again the id (the same) and change showVentilation: false (don´t have outdoor sensor) and work…
            sorry and thanks…
              Smotx
              HI,
              Anyone know why MMM Xiaomi need aplay ?
              Error: Cannot find module 'node-aplay'
                  at Module._resolveFilename (module.js:543:15)
                  at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                  at Function.Module._load (module.js:473:25)
                  at Module.require (module.js:586:17)
                  at require (internal/module.js:11:18)
                  at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-xiaomi/node_helper.js:11:20)
                  at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-xiaomi/node_helper.js:140:3)
                  at Module._compile (module.js:642:30)
                  at Object.Module._extensions..js (module.js:653:10)
                  at Module.load (module.js:561:32)
                Smotx @mirko3000
                @mirko3000 said in MMM-xiaomi - Temperature and Humidity from your smarthome:
                I just recieved my order of another 6 window sensors yesterday :) But I really think they will shut this down soon, guess they (gearbest) are not paying any taxes at all…
                Working on the new version, this is what I have in mind:
                How to have this screen ?
                E 1 Reply Last reply
                  Smotx @mirko3000
                    Smotx
                    it seems that these window sensors are not compatible.
                    Xiaomi Aqara Window Door Sensor
                    I added them to the config module and no return on MM.
                    When i launch
                    miio discover
                    it found
                    Device ID: 158d0001ab1f9c
                    Model info: lumi.magnet.aq2
                    but when i launch npm start, MMM-xiaomi say
                    Found device with ID 158d0001ab1f9c of type generic
                    and no
                    Found device with ID 158d0001ab1f9c of type magnet
                      Smotx
                      Thanks to owner of module : @mirko3000 for update to see this sensor !
                      Now that’s work
                      • V
                        VagelisAn
                        Dear @mirko3000 i have follow your instraction and i install the MMM-Xiaomi, i install and the miio to get the access token but the scan of miio is not find the getaway accesstoken
                        pi@raspberrypi:~ $ miio discover
                         INFO  Discovering devices. Press Ctrl+C to stop.
                        Device ID: 631XXXXX
                        Model info: Unknown
                        Address: XXX.XXX.X.XXX
                        Token: ???
                        Support: Unknown
                        I use the MI application and get the ip and accessToken and the id from temperature sensor.
                        The name is lumi.158xxxxxxxxxxx
                        this is the code of config
                        		position: 'top_right',
                        		header: 'Temperature / Humidity',  // This is optional
                        			gatewayIP: 'IP getaway from MI home',
                        			gatewayToken: 'accese getaway from MI home',
                        			showWindow: true,
                        			showLights: false,
                        			rooms:  [
                        					sortOrder: 10,
                        					devices : ['lumi.158xxxxxxxxxxx']
                        I execute and i have this error in terminal andthe xiaomi modules say connecting to xiaommi getaway.
                        { Error: Call to device timed out
                            at retry (/home/pi/MagicMirror/modules/MMM-xiaomi/node_modules/miio/lib/devi             ce.js:225:18)
                            at _ensureToken.catch.err (/home/pi/MagicMirror/modules/MMM-xiaomi/node_modu             les/miio/lib/device.js:238:8)
                            at <anonymous> code: 'timeout' }
                        Sorry if my English is bad
                        • G
                          gh057
                          Has anyone tried to get the module to work with a Gateway AND a Yeelight bed lamp ??
                          I mean i have the module working with my gateway (manually added the token, and then the sensors appeard in miio discovery) but i havent managed to get it to work with the yeelight lamp (that also acts as a bluetooth gateway for my other sensors).
                          When i reseted the lamp, and connected to its wifi, i discovered it with miio and extracted the token, but later when i registered the lamp with the mi app, and connected my pi to my wifi, while the lamp is pingable by the pi, now miio doesn’t discover it!!
                          But, besides that, even if i manage to discover the lamp again with miio, i’m not aware if its even possible to add a second gateway to the module.
                          Does anyone know??
                          • G
                            gauka12345
                            HI there i have got same problem the gateway was turned off
                            then i have tried to reconnect all the temperature sensors and tokens shows with ??? question marks… can some one help please!
                            • G
                              gauka12345
                              pi@raspberrypi:~/miio $ miio discover
                              Device ID: 72558327
                              Model info: lumi.gateway.v3
                              Address: 192.168.0.9
                              Token: ???
                              Support: At least generic
                                Smotx
                                hi,
                                Same problem here too
                                I have changed my router, so i have change wifi of Xiaomi hub
                                On magicmirror config i have set new ip 192.168.2.xxx (before 192.168.1.xxx).
                                But always nothing on MagicMirror after reboot.
                                perhaps token has changed with new router… So, on the rasp i launch command ```
                                miio discover
                                ` $ sudo miio discover
                                Device ID: 567xxxx54
                                Model info: Unknown
                                Address: 192.168.2.xxx
                                Token: ???
                                Support: Unknown
                                Anybody know why ? :(.
                                garblefluxG 1 Reply Last reply
                                • G
                                  gauka12345
                                  Hi
                                  You can get token by installing older version of mi home app on you mobile
                                  https://www.apkmirror.com/apk/xiaomi-inc/mihome/mihome-5-0-19-release/mihome-5-0-19-android-apk-download/
                                  Then you will need to follow this tutorial to obtain the token
                                  https://www.youtube.com/watch?v=Q4QV8tMI8H4
                                  however so far i have swap the tokens but with no luck. i think the device need to be discovered by MIiio.
                                    Smotx @gauka12345
                                    @gauka12345
                                    I gave found new token on Mi home app android, it worked a few days, and then again it does not work anymore, it tells me ‘time out’ and in mioo discover there is nothing at all
                                    at retry (/home/pi/MagicMirror/modules/MMM-xiaomi/node_modules/miio/lib/device.js:225:18)
                                    at _ensureToken.catch.err (/home/pi/MagicMirror/modules/MMM-xiaomi/node_modules/miio/lib/device.js:238:8)
                                    at code: ‘timeout’
                                    • garblefluxG
                                      garbleflux Project Sponsor @Smotx
                                      @smotx said in MMM-xiaomi - Temperature and Humidity from your smarthome:
                                      hi,
                                      miio discover
                                      Model info: Unknown
                                      Token: ???
                                      Support: Unknown
                                      I had the same problem. Meanwhile, I have found the solution. An update from Xiaomi changed the token in the gateway. This must now be read out via the smartphone. In my case the miio discovery command did not work any more. I followed this instruktion to get the new token
                                      https://forum.smartapfel.de/forum/thread/1219-xiaomi-mi-gateway-homebridge-mi-aqara/?postID=31779#post31779
                                      … and now all works fine again - I have all my sensors back on the mirror.
                                      regards
                                      Mike
                                        Smotx
                                        after this command :
                                        miio tokens update 567xxxxx --token 6xxxxxxxxxxxxxxxxxxxxxxxxxxx
                                        mine to work again a few days, and now is KO again… for the third time… :face_with_steam_from_nose: Token has not changed, ip has not changed…
                                          Serg
                                          I can’t find what needs to be changed in CSS to change the font color of the temperature and humidity numbers.
                                          • L
                                            lovesicker
                                            Hi guys,
                                            I have two temperature sensors. Each sensor registers with a gateway. Could anyone tell me how to add the two gateways in config.js file?
                                            I try to add the following codes in config.js:
                                            module: ‘MMM-xiaomi’,
                                            position: ‘top_right’,
                                            header: ‘Temperature / Humidity’,
                                            gatewayIP: ‘192.168.186.181’,
                                            gatewayToken: ‘xxxxxxxx-ceec093b30b1775dc741a7’,
                                            showWindow: true,
                                            showLights: false,
                                            rooms: [
                                            sortOrder: 20,
                                            devices : [‘158d000xxxx9f’]
                                            gatewayIP: ‘192.168.186.166’,
                                            gatewayToken: ‘xxxxxxxx–927e2d20b22c22b007194c’,
                                            rooms: [
                                            sortOrder: 30,
                                            devices : [‘158d000xxxx4f6’]
                                            but MagicMirror always display the last sensor, which registers with the secondary gateway in config.js file.
                                            Could anyone give me some suggestions? Thanks in advance!
                                            • 6 / 8
