    How to best process an [object Promise]?
    9 Posts 4 Posters 3.4k Views 4 Watching
    • tbbearT Offline
      tbbear Module Developer @E3V3A
      @E3V3A of course no problem gimme a ffew minutes
      Robert the Bear
      • N Offline
        ninjabreadman @E3V3A
        @E3V3A I don’t think there’s a reload mechanism in MM’s config.js. For example, you can have an updateInterval variable in the module config, but it’s the module’s job to then implement the refresh – it isn’t done automagically by MM.
        See the code for the default compliments module for where it uses this.config.updateInterval to call setInterval() with updateDom() (to set a timer to reload the DOM after a delay) all within its start() function.
          Mykle1 Project Sponsor Module Developer @ninjabreadman
          @ninjabreadman said in How to best process an [object Promise]?:
          automagically
          Absolutely the best term I have heard to date. :-)
          • E Offline
            E3V3A @Mykle1
            @Mykle1 said in How to best process an [object Promise]?:
            automagically
            :) Especially in this context! I’m only now starting to understand why it’s called a magic mirror… Whatever you guys manage to create, it seem to have been done by development magic…
            But, anyway, my problem is surely just a lack of conceptual and technical knowledge.
            In my node_helper.js I was tryign to do this:
            const NodeHelper = require("node_helper");
            const fs = require('fs');
            const async = require('async');
            const radar = require('radar-api'); // This API return improper JSON
                async function radarPing() {
                    console.log("ENTER (inside)");
                    try {
                        const ping = await radar(-8.20917,114.62177,-9.28715,115.71243);
                        console.log("GOT DATA: ", await ping);
                        return await ping;
                    } catch(error) {
                        console.log("API ERROR: ", error);
                    //return "None";
                    console.log("EXIT (inside)");
                readData: function() {
                    var radarData = "";
                    radarData = radarPing();
                    console.log("The DATA:\n" + radarData);
            but that ended up with some weird errors, like:
            SyntaxError: Unexpected identifier
                at Object.exports.runInThisContext (vm.js:76:16)
                at Module._compile (module.js:528:28)
            Since, I’ve only started to learn about Promises, sync/await, just 2 days ago, I must be missing a lot. Because all the examples I’ve seen, are using more or less this way of writing.
            So how the eeek do I make sure that what is returned by the api/poll function, is actual data and not an [object Promise], and how can I handle the Promise { } that is returned in advance?
            I’m overwhelmed…
            "Everything I do (here) is for free – altruism is the way!"
            • E Offline
              E3V3A
              I also tried another variant, but that failed too:
                  radarPing: function() {
                      try {
                          var ping = radar(-8.20917,114.62177,-9.28715,115.71243);
                          ping.then({
                          return ping;
                          console.log("GOT DATA: ", ping);
                          //return await ping;
                      } catch(error) {
                      //return "None";
                      var radarData = "";
                      radarData = this.radarPing;
              • E Offline
                E3V3A
                I’ve got a partially working function, but it’s a bit funny. For some reason the call to cleanup the JSON is not liked, because it seem that the actual result is not returned, but the Promise .
                This is the code snippet:
                    Promise.all([
                        ]).then(function(results) {
                            var ping = results;
                            console.log("PING1:");
                            console.log(ping);
                            var cleanData = jZen(ping);
                            console.log("PING2: ", cleanData);
                            self.sendSocketNotification("NEW_DATA", ping); //"PING"
                            return cleanData; //ping;
                        //const myfile = 'modules/MMM-FlightsAbove/demo.json'; // The demo API use improper JSON
                        var radarData = "";
                        radarData = this.radarPing();
                        console.log("The DATA:\n", radarData);
                /*        if ( radarData === "" ) {
                */        //let cleanData = jZen(data);
                        //let cleanData = jZen(radarData);
                        let cleanData = radarData;
                        if (isJSON(cleanData) ) {
                            this.sendSocketNotification("NEW_DATA", cleanData);
                        } else {
                            // So WTF is it?
                            console.log("- JSON: false");
                            console.log("- isAO(dirty): " + isAO(radarData));
                            console.log("- isAO(clean): " + isAO(cleanData));
                            console.log("- Data:\n", radarData);
                // To check if something is JSON
                function isJSON(str) {
                    try { return (JSON.parse(str) && !!str); }
                    catch (e) { return false; }
                // To check if something is an Array or Object (parsed JSON)
                function isAO(val) {
                    return val instanceof Array || val instanceof Object ? true : false;
                // What:  A dirt simple JSON cleanup function that also compactifies the data
                // NOTE:  - Only use on flat and trustworthy ASCII JSON data!
                //        - Cannot handle any characters outside [A-Za-z0-9_\-]. (e.g. UTF-8)
                //        - Using remote data without further sanitation is a security risk!
                const re1 = /([A-Za-z0-9_\-]+):/gm;  // use const to make sure it is compiled
                function jZen(juice) {
                    //let re1 = /([A-Za-z0-9_\-]+):/gm; // Find all ASCII words $1 before an ":"
                    //let data = juice;
                    let str = "";
                    str = juice.replace(/\s/gm, '');     // Remove all white-space
                    str = str.replace(/\'/gm, '\"');    // Replace all ' with "
                    str = str.replace(re1, '\"$1\":');  // Replace $1: with "$1":
                    //console.log("Dirty JSON is:\n" + data.toString() );
                    //console.log("Clean JSON is:\n" + str);
                    return str;
                The output is:
                ENTER (inside)
                EXIT (inside)
                The DATA:
                 undefined
                - JSON: false
                - isAO(dirty): false
                - isAO(clean): false
                - Data:
                 undefined
                PING1:
                [ [ { id: '108be389',
                      timestamp: 1519647028,
                      registration: 'PK-GQL',
                      flight: 'QG8816',
                      callsign: 'CTV8816',
                As you can see, PING2 never happens…
