    How to best process an [object Promise]?
    9 Posts 4 Posters 3.8k Views 4 Watching
    • E
      E3V3A
      I have an API that is returning a JSON object as an [object Promise]. At first I was completely cluless to what this was. I now understand it’s because the API is using some asynchronous function to obtain and present the data. I have spent the last day or two to reading up about this. In particular about Promises, async/await, fetch/catch, and even Generators.
      But since I’m completely new to this kind of JS programming, I’m rather overwhelmed by the various kinds of methods used for doing this. I could need a small hint of guidance for what to look into. Basically a super simple crash-course to get people like me started in the framework of MM modules. In addition, I’ve read that even seasoned developers get this wrong regularly.
      What I think I need to add in my node_helper is:
      • read the config file to get an option to be used in the API call
      • make the promised API call
      • wait for correct JSON response from API call
      • push JSON to MMM-module
      All the above need to be repeated on a regular interval. (I’m not sure this “polling” need to be implemented separately here, or if the MM config.js reload mechanism is enough.
      What is the simplest method to implement that?
      I’d love to hear from what you guys think.
      PS. I’ve read that async/await is syntactically simpler to use.
      “Everything I do (here) is for free – altruism is the way!”
      tbbearT 1 Reply Last reply
      • tbbearT
        tbbear Module Developer @E3V3A
        @E3V3A said in How to best process an [object Promise]?:
        Hi maybe i can help. Have a look at the node_helper.js in the MMM-NOAA modules. Their i use the google translate api which also gives back a promise. U can try the solution i useed.
        Robert the Bear
        E 1 Reply Last reply
        • E
          E3V3A @tbbear
          @tbbear Hi! Thank you, but that is quite an extensive code. Can you pinpoint where you do this?
          tbbearT N 2 Replies Last reply
          • tbbearT
            @E3V3A of course no problem gimme a ffew minutes
            Robert the Bear
            • N
              ninjabreadman @E3V3A
              @E3V3A I don’t think there’s a reload mechanism in MM’s config.js. For example, you can have an updateInterval variable in the module config, but it’s the module’s job to then implement the refresh – it isn’t done automagically by MM.
              See the code for the default compliments module for where it uses this.config.updateInterval to call setInterval() with updateDom() (to set a timer to reload the DOM after a delay) all within its start() function.
              Mykle1M 1 Reply Last reply
              Reply Quote 2
              • Mykle1M
                Mykle1 Project Sponsor Module Developer @ninjabreadman
                @ninjabreadman said in How to best process an [object Promise]?:
                automagically
                Absolutely the best term I have heard to date. :-)
                • E
                  E3V3A @Mykle1
                  @Mykle1 said in How to best process an [object Promise]?:
                  automagically
                  :) Especially in this context! I’m only now starting to understand why it’s called a magic mirror… Whatever you guys manage to create, it seem to have been done by development magic…
                  But, anyway, my problem is surely just a lack of conceptual and technical knowledge.
                  In my node_helper.js I was tryign to do this:
                  const NodeHelper = require("node_helper");
                  const fs = require('fs');
                  const async = require('async');
                  const radar = require('radar-api'); // This API return improper JSON
                      async function radarPing() {
                          console.log("ENTER (inside)");
                          try {
                              const ping = await radar(-8.20917,114.62177,-9.28715,115.71243);
                              console.log("GOT DATA: ", await ping);
                              return await ping;
                          } catch(error) {
                              console.log("API ERROR: ", error);
                          //return "None";
                          console.log("EXIT (inside)");
                      readData: function() {
                          var radarData = "";
                          radarData = radarPing();
                          console.log("The DATA:\n" + radarData);
                  but that ended up with some weird errors, like:
                  SyntaxError: Unexpected identifier
                      at Object.exports.runInThisContext (vm.js:76:16)
                      at Module._compile (module.js:528:28)
                  Since, I’ve only started to learn about Promises, sync/await, just 2 days ago, I must be missing a lot. Because all the examples I’ve seen, are using more or less this way of writing.
                  So how the eeek do I make sure that what is returned by the api/poll function, is actual data and not an [object Promise], and how can I handle the Promise { } that is returned in advance?
                  I’m overwhelmed…
                  • E
                    E3V3A
                    I also tried another variant, but that failed too:
                        radarPing: function() {
                            try {
                                var ping = radar(-8.20917,114.62177,-9.28715,115.71243);
                                ping.then({
                                return ping;
                                console.log("GOT DATA: ", ping);
                                //return await ping;
                            } catch(error) {
                            //return "None";
                            var radarData = "";
                            radarData = this.radarPing;
                    • E
                      E3V3A
                      I’ve got a partially working function, but it’s a bit funny. For some reason the call to cleanup the JSON is not liked, because it seem that the actual result is not returned, but the Promise .
                      This is the code snippet:
                          Promise.all([
                              ]).then(function(results) {
                                  var ping = results;
                                  console.log("PING1:");
                                  console.log(ping);
                                  var cleanData = jZen(ping);
                                  console.log("PING2: ", cleanData);
                                  self.sendSocketNotification("NEW_DATA", ping); //"PING"
                                  return cleanData; //ping;
                              //const myfile = 'modules/MMM-FlightsAbove/demo.json'; // The demo API use improper JSON
                              var radarData = "";
                              radarData = this.radarPing();
                              console.log("The DATA:\n", radarData);
                      /*        if ( radarData === "" ) {
                      */        //let cleanData = jZen(data);
                              //let cleanData = jZen(radarData);
                              let cleanData = radarData;
                              if (isJSON(cleanData) ) {
                                  this.sendSocketNotification("NEW_DATA", cleanData);
                              } else {
                                  // So WTF is it?
                                  console.log("- JSON: false");
                                  console.log("- isAO(dirty): " + isAO(radarData));
                                  console.log("- isAO(clean): " + isAO(cleanData));
                                  console.log("- Data:\n", radarData);
                      // To check if something is JSON
                      function isJSON(str) {
                          try { return (JSON.parse(str) && !!str); }
                          catch (e) { return false; }
                      // To check if something is an Array or Object (parsed JSON)
                      function isAO(val) {
                          return val instanceof Array || val instanceof Object ? true : false;
                      // What:  A dirt simple JSON cleanup function that also compactifies the data
                      // NOTE:  - Only use on flat and trustworthy ASCII JSON data!
                      //        - Cannot handle any characters outside [A-Za-z0-9_\-]. (e.g. UTF-8)
                      //        - Using remote data without further sanitation is a security risk!
                      const re1 = /([A-Za-z0-9_\-]+):/gm;  // use const to make sure it is compiled
                      function jZen(juice) {
                          //let re1 = /([A-Za-z0-9_\-]+):/gm; // Find all ASCII words $1 before an ":"
                          //let data = juice;
                          let str = "";
                          str = juice.replace(/\s/gm, '');     // Remove all white-space
                          str = str.replace(/\'/gm, '\"');    // Replace all ' with "
                          str = str.replace(re1, '\"$1\":');  // Replace $1: with "$1":
                          //console.log("Dirty JSON is:\n" + data.toString() );
                          //console.log("Clean JSON is:\n" + str);
                          return str;
                      The output is:
                      ENTER (inside)
                      EXIT (inside)
                      The DATA:
                       undefined
                      - JSON: false
                      - isAO(dirty): false
                      - isAO(clean): false
                      - Data:
                       undefined
                      PING1:
                      [ [ { id: '108be389',
                            timestamp: 1519647028,
                            registration: 'PK-GQL',
                            flight: 'QG8816',
                            callsign: 'CTV8816',
                      As you can see, PING2 never happens…
