Updating MM on a PC?
14 Posts 3 Posters 5.3k Views 2 Watching
    Damian
    Hello, yeah I may be sounding thick, but how does one update all on MM running on a PC? The MM itself, and all modules?
    I tried the usual Pi commands, but they are surely different?
    cd MagicMirror -then git pull -then npm install
    sudo apt-get updateor even tried
    cd MagicMirror > cd modules > cd MMM-WuderGround then type in git pull or
    In terminal, ~/MagicMirror/modules/MMM-WunderGround $
    and type git pull
    M 1 Reply Last reply Feb 26, 2018, 1:28 AM Reply Quote 0
      Mykle1 Project Sponsor Module Developer @Damian
      @Damian said in Updating MM on a PC?:
      That should work. git commands and npm commands should work.
      sudo will not.
      D 1 Reply Last reply Feb 26, 2018, 12:49 PM Reply Quote 1
        Damian @Mykle1
        @Mykle1
        Damian@KitchenComputer ~/MagicMirror
        $ git pull
        Fatal: not a git repository (or any of the parent firectories): .git
          try:
          git pull origin master
          If you’re still having problems do this:
          sudo apt-get install git-all
          Then retry ‘git pull’…
          D 1 Reply Last reply Feb 26, 2018, 1:15 PM Reply Quote 1
            Damian @cowboysdude
            @cowboysdude said in Updating MM on a PC?:
            try:
            From ~MagicMirror
            $ git pull origin master
            fatal: Not a git repository (or any of the parent directories): .git
            $ sudo apt-get install git-all
            bash: sudo: command not found
              Type ‘git init’ then retry ‘git pull’
              D 1 Reply Last reply Feb 26, 2018, 1:34 PM Reply Quote 0
                Damian @cowboysdude
                @cowboysdude
                $ git init
                Initialized empty git repository in C:/users/Damian/MagicMirror/.git/
                $ git pull
                fatal: no remote repository specified. Please, specify either a url or a remote name from which new revisions should be fetched.
                C 1 Reply Last reply Feb 26, 2018, 1:42 PM Reply Quote 0
                  cowboysdude Module Developer @Damian
                  git remote add origin https://github.com/MichMich/MagicMirror.git
                  D 1 Reply Last reply Feb 26, 2018, 1:57 PM Reply Quote 1
                    Damian @cowboysdude
                    @cowboysdude
                    Thanks will try that out when keyboard recharges, I have run battery flat with all the things I have tried 😮
                    C 1 Reply Last reply Feb 26, 2018, 1:58 PM Reply Quote 0
                      @cowboysdude
                      Nice Job LOL I have to go to work :) Good luck!
                      D 1 Reply Last reply Feb 26, 2018, 2:39 PM Reply Quote 1
