    Updating MM on a PC?
    14 Posts 3 Posters 5.8k Views 2 Watching
      Damian
      Hello, yeah I may be sounding thick, but how does one update all on MM running on a PC? The MM itself, and all modules?
      I tried the usual Pi commands, but they are surely different?
      cd MagicMirror -then git pull -then npm install
      sudo apt-get updateor even tried
      cd MagicMirror > cd modules > cd MMM-WuderGround then type in git pull or
      In terminal, ~/MagicMirror/modules/MMM-WunderGround $
      and type git pull
        Mykle1 Project Sponsor Module Developer @Damian
        @Damian said in Updating MM on a PC?:
        That should work. git commands and npm commands should work.
        sudo will not.
          Damian @Mykle1
          @Mykle1
          Damian@KitchenComputer ~/MagicMirror
          $ git pull
          Fatal: not a git repository (or any of the parent firectories): .git
          • cowboysdudeC Offline
            try:
            git pull origin master
            If you’re still having problems do this:
            sudo apt-get install git-all
            Then retry ‘git pull’…
              Damian @cowboysdude
              @cowboysdude said in Updating MM on a PC?:
              try:
              From ~MagicMirror
              $ git pull origin master
              fatal: Not a git repository (or any of the parent directories): .git
              $ sudo apt-get install git-all
              bash: sudo: command not found
                Type ‘git init’ then retry ‘git pull’
                  Damian @cowboysdude
                  @cowboysdude
                  $ git init
                  Initialized empty git repository in C:/users/Damian/MagicMirror/.git/
                  $ git pull
                  fatal: no remote repository specified. Please, specify either a url or a remote name from which new revisions should be fetched.
                    cowboysdude Module Developer @Damian
                    git remote add origin https://github.com/MichMich/MagicMirror.git
                      Damian @cowboysdude
                      @cowboysdude
                      Thanks will try that out when keyboard recharges, I have run battery flat with all the things I have tried 😮
                        @cowboysdude
                        Nice Job LOL I have to go to work :) Good luck!
