    Updating MM on a PC?
    14 Posts 3 Posters 6.8k Views 2 Watching
    • cowboysdudeC Offline
      try:
      git pull origin master
      If you’re still having problems do this:
      sudo apt-get install git-all
      Then retry ‘git pull’…
        Damian @cowboysdude
        @cowboysdude said in Updating MM on a PC?:
        try:
        From ~MagicMirror
        $ git pull origin master
        fatal: Not a git repository (or any of the parent directories): .git
        $ sudo apt-get install git-all
        bash: sudo: command not found
          @Damian said in Updating MM on a PC?:
          Type ‘git init’ then retry ‘git pull’
            Damian @cowboysdude
            @cowboysdude
            $ git init
            Initialized empty git repository in C:/users/Damian/MagicMirror/.git/
            $ git pull
            fatal: no remote repository specified. Please, specify either a url or a remote name from which new revisions should be fetched.
              cowboysdude Module Developer @Damian
              git remote add origin https://github.com/MichMich/MagicMirror.git
                Damian @cowboysdude
                @cowboysdude
                Thanks will try that out when keyboard recharges, I have run battery flat with all the things I have tried 😮
                  @cowboysdude
                  Nice Job LOL I have to go to work :) Good luck!
                    Damian @cowboysdude
                    @cowboysdude
                    Think I may just delete MM, and start afresh with virgin modules, then try and update again, and start adding my changes… see if it’s maybe me messing around has done something eh?
                      @Damian very possible you could have broke something. If the suggestions I gave you didn’t work… good idea, start over :) This time make backups of the files you are changing before you change them :)
                        Damian @cowboysdude
                        @cowboysdude
                        Thanks, yeah for sure I will keep a “Master Files Folder” for all originals should something go weird?
                        As an aside, the updated compliments… on my Pi I noticed that they did not color since updating today, had a quick look and on comparing old file with updated file, there was a part missing … racking my brains to think the exact name, but it made reference to the CSS… so when I C&P that section from old file into new file, the compliments colored again!.. was this intentional to omit this or just an oversight from the dev?
                          @cowboysdude
                          I’m not really sure in all honesty. I have written most of my own modules and use none of the default ones.
