    Small 'Picture frame' MagicMirror (first attempt)
    15 inchpicture framemagicmirrothin
    13 Posts 6 Posters 12.5k Views 6 Watching
    • michael24hM Offline
      michael24h
      Nice work, I did something very similar. Using apple first gen iPad screen :-)
      MY CLOCK
      MY 10" inch MagicMirror
      0_1519688876538_magicmirror front.jpg 0_1519688885110_Game Boy Color.jpeg 0_1519688891927_Gunship screenshot.jpeg
      • emloweE Offline
        emlowe Module Developer
        I like what you did with the power, nice and clean. FYI, a number of the LCD driver boards have 5v outputs and I’ve successfully powered an rpi3 from the output from the board itself.
        (http://www.panelook.com/upload/201511/MNT686762A_12516-Specification_A2_(1)_201511187301.pdf)
        Supplies 5v on the CN3 pins (probably headless on the board, but 5v is there)
        This guy says it’s good up to 1.5 amps (https://www.raspberrypi.org/forums/viewtopic.php?t=67312)
        I wired it to a USB cable rather than directly to the GPIO
        -Earle
          michael24h
          The Raspberry Pi 3 is powered by a +5.1V and 2.5A
          small lcd screen takes about 3.3v.
          • Robert_KR Offline
            Robert_K @Mykle1
            @Mykle1 said in Small ‘Picture frame’ MagicMirror (first attempt):
            The acrylic top plate does look nice, giving it a professional, finished look. One suggestion, and this is just one old man’s opinion. Keep an eye on the temperature, now that you’ve closed the back of the frame.
            I’ve been thinking about that too. So I started with a closed plate, monitored the temperature and was thinking about making ventilator holes. Then again the temperature isn’t raising above 40degC. So I think it will be okay. I’ll keep it in mind with a hot summer day, thanks!
            Regards Robert
            michael24hM 1 Reply Last reply Reply Quote 0
            • E Offline
              E3V3A
              Wow, beautiful inside!
              How did you make the cables stay so nicely squared? With hot-glue?
              "Everything I do (here) is for free – altruism is the way!"
              Robert_KR michael24hM 2 Replies Last reply Reply Quote 0
              • Robert_KR Offline
                Robert_K @E3V3A
                @E3V3A said in Small ‘Picture frame’ MagicMirror (first attempt):
                Yes, hot glue indeed.
                Regards Robert
                  michael24h @Robert_K
                  @Robert_K
                  leave back of mirror open.that will help
                    michael24h @E3V3A
                    @E3V3A
                    In my mm-clock, all 3d printed. No hot glue.
                    • LupearnL Offline
                      Lupearn
                      For me when I started to decorate my house it was very important to have original and matching picture frames.
                      LupearnL 1 Reply Last reply Reply Quote 0
                      • LupearnL Offline
                        Lupearn @Lupearn
                        @lupearn hmm
                        • Robert_KR Robert_K referenced this topic on
