    Small 'Picture frame' MagicMirror (first attempt)
    15 inchpicture framemagicmirrothin
    13 Posts 6 Posters 13.1k Views 6 Watching
    • emloweE Offline
      emlowe Module Developer
      I like what you did with the power, nice and clean. FYI, a number of the LCD driver boards have 5v outputs and I’ve successfully powered an rpi3 from the output from the board itself.
      (http://www.panelook.com/upload/201511/MNT686762A_12516-Specification_A2_(1)_201511187301.pdf)
      Supplies 5v on the CN3 pins (probably headless on the board, but 5v is there)
      This guy says it’s good up to 1.5 amps (https://www.raspberrypi.org/forums/viewtopic.php?t=67312)
      I wired it to a USB cable rather than directly to the GPIO
      -Earle
      • michael24hM Offline
        michael24h
        The Raspberry Pi 3 is powered by a +5.1V and 2.5A
        small lcd screen takes about 3.3v.
        • Robert_KR Offline
          Robert_K @Mykle1
          @Mykle1 said in Small ‘Picture frame’ MagicMirror (first attempt):
          The acrylic top plate does look nice, giving it a professional, finished look. One suggestion, and this is just one old man’s opinion. Keep an eye on the temperature, now that you’ve closed the back of the frame.
          I’ve been thinking about that too. So I started with a closed plate, monitored the temperature and was thinking about making ventilator holes. Then again the temperature isn’t raising above 40degC. So I think it will be okay. I’ll keep it in mind with a hot summer day, thanks!
          Regards Robert
          michael24hM 1 Reply Last reply Reply Quote 0
          • E Offline
            E3V3A
            Wow, beautiful inside!
            How did you make the cables stay so nicely squared? With hot-glue?
            "Everything I do (here) is for free – altruism is the way!"
            Robert_KR michael24hM 2 Replies Last reply Reply Quote 0
            • Robert_KR Offline
              Robert_K @E3V3A
              @E3V3A said in Small ‘Picture frame’ MagicMirror (first attempt):
              Yes, hot glue indeed.
              Regards Robert
                michael24h @Robert_K
                @Robert_K
                leave back of mirror open.that will help
                  michael24h @E3V3A
                  @E3V3A
                  In my mm-clock, all 3d printed. No hot glue.
                  • LupearnL Offline
                    Lupearn
                    For me when I started to decorate my house it was very important to have original and matching picture frames.
                    LupearnL 1 Reply Last reply Reply Quote 0
                    • LupearnL Offline
                      Lupearn @Lupearn
                      @lupearn hmm
                      • Robert_KR Robert_K referenced this topic on
