    Small 'Picture frame' MagicMirror (first attempt)
    15 inchpicture framemagicmirrothin
    13 Posts 6 Posters 13.1k Views 6 Watching
      Mykle1 Project Sponsor Module Developer @Robert_K
      @Robert_K said in Small ‘Picture frame’ MagicMirror (first attempt):
      Made an acrylic top plate. Doesn’t do anything more than looking nice.
      The acrylic top plate does look nice, giving it a professional, finished look. One suggestion, and this is just one old man’s opinion. Keep an eye on the temperature, now that you’ve closed the back of the frame.
      Robert_KR 1 Reply Last reply Reply Quote 2
      • michael24hM Offline
        michael24h
        Nice work, I did something very similar. Using apple first gen iPad screen :-)
        MY CLOCK
        MY 10" inch MagicMirror
        0_1519688876538_magicmirror front.jpg 0_1519688885110_Game Boy Color.jpeg 0_1519688891927_Gunship screenshot.jpeg
        • emloweE Offline
          emlowe Module Developer
          I like what you did with the power, nice and clean. FYI, a number of the LCD driver boards have 5v outputs and I’ve successfully powered an rpi3 from the output from the board itself.
          (http://www.panelook.com/upload/201511/MNT686762A_12516-Specification_A2_(1)_201511187301.pdf)
          Supplies 5v on the CN3 pins (probably headless on the board, but 5v is there)
          This guy says it’s good up to 1.5 amps (https://www.raspberrypi.org/forums/viewtopic.php?t=67312)
          I wired it to a USB cable rather than directly to the GPIO
          -Earle
            michael24h
            The Raspberry Pi 3 is powered by a +5.1V and 2.5A
            small lcd screen takes about 3.3v.
            • Robert_KR Offline
              Robert_K @Mykle1
              @Mykle1 said in Small ‘Picture frame’ MagicMirror (first attempt):
              I’ve been thinking about that too. So I started with a closed plate, monitored the temperature and was thinking about making ventilator holes. Then again the temperature isn’t raising above 40degC. So I think it will be okay. I’ll keep it in mind with a hot summer day, thanks!
              Regards Robert
              michael24hM 1 Reply Last reply Reply Quote 0
              • E Offline
                E3V3A
                Wow, beautiful inside!
                How did you make the cables stay so nicely squared? With hot-glue?
                "Everything I do (here) is for free – altruism is the way!"
                Robert_KR michael24hM 2 Replies Last reply Reply Quote 0
                • Robert_KR Offline
                  Robert_K @E3V3A
                  @E3V3A said in Small ‘Picture frame’ MagicMirror (first attempt):
                  Yes, hot glue indeed.
                  Regards Robert
                    michael24h @Robert_K
                    @Robert_K
                    leave back of mirror open.that will help
                      michael24h @E3V3A
                      @E3V3A
                      In my mm-clock, all 3d printed. No hot glue.
                      • LupearnL Offline
                        Lupearn
                        For me when I started to decorate my house it was very important to have original and matching picture frames.
                        LupearnL 1 Reply Last reply Reply Quote 0
