    IR Frame
    11 Posts 4 Posters 5.9k Views 3 Watching
    • cowboysdudeC Offline
      cowboysdude Module Developer @maxbachmann
      @maxbachmann said in IR Frame:
      ok :) sounds good
      A 4K display is a waste of your money in all honesty.
        maxbachmann
        yeah, that was my first thought as well but thought it would be better to ask people that already did it because buying an FHD that looks crappy later is kind of unnecessary as well.
        • yawnsY Offline
          yawns Moderator
          As long as it is fullhd and not hdready you should be fine
            maxbachmann
              maxbachmann
              found a good monitor for myself which would be 31.5’’
              Is there a easy way to map those 32’’ IR frames you use to this slightly smaller monitor?
                @maxbachmann If you mean the touch frame? You can just build a bigger box that will fit the 32" frame in and then center the monitor and it should work just fine :)
                  maxbachmann
                  yeah thats exactly what I mean :)
                  I thought I would center the monitor like you said, however I don’t know how settings for the touch frame are changed because using a 32’’ touch frame with a 31,5 inches screen in standard the touch should be a little bit off
                  Or do I miss something?
