    MMM-htmlvideo, Basic video file player
    videovideoplayermediamovie
    14 Posts 9 Posters 15.3k Views 11 Watching
      domi256
      where can i download this module? thanks :)
        broberg Project Sponsor @domi256
        @domi256 It’s in the first post above.
          Damian
          @broberg
          hello can you help me with your experience? im thinking to use this but have my own content play from my Pi-nas and even though it sounds overkill would making my own intranet possibly with another Pi, be okay in such like module? i understand pc workings but still unsure with linux and mm workings to allow suchlikes or as another suggested just use iframe? thank you
          • N
            nhl
            Is there anyway to play a video thats stored on the SD card? Mine rasp pi 3 lags when streaming the mp4
              Sputnik
              Yes, I am also trying to find a simple way to play a single mp4 file which is stored on my PI. Anyone has a solution inside a module ??
                jabellas @Sputnik
                @Sputnik I have had success with file://path/to/you/file.mp4 as the url but it is still choppy when played from the same sd card
                  maydaymiao
                  Hi, thanks for this great module, and it works well. I have a speical scenario and it will be great if someone can give some tips here (Sorry, I am not a JS programmer…)
                  Right now, the video is running by default when mm starts. Here is my scenario,
                  1. The video will not run automatically by default so that I can still see other information clearly.
                  2. I can store mutiple videos (let’s assume two videos: 1.mp4 & 2.mp4) in the local Pi directory, and only when there is a certain mqtt message “1” published to the topic, it triggers to play 1.mp4; another message “2” published, triggers 2.mp4.
                  I am not sure whether there is an easier to achieve that, thanks!
                  • cowboysdudeC
                    cowboysdude Module Developer @jabellas
                    @jabellas You are using a pi and they aren’t really powerhouses when it comes to computing. I would try having the video located off of the pi and try it again.
                    J 1 Reply Last reply Reply Quote 2
                      jabellas @cowboysdude
                      @cowboysdude Yes, thanks. I ended up doing just that. It seemed to me initially counterintuitive that it would play faster from an external location than locally but it is perfectly smooth if I host the video on a separate web server.
                      • cowboysdudeC
                        @jabellas said in MMM-htmlvideo, Basic video file player:
                        I agree with you!! Glad you got it working better :)
