    MMM-Assistant (updated) -- Your voice to the world!
    22 Posts 10 Posters 16.8k Views 11 Watching
    • E
      E3V3A
      I have now updated to the Google Assistant and MM Voice Control module: MMM-Assistant. AFAICT it all works now. So now we can focus on improvements, but any help or testing is always appreciated.
      [card:eouia/MMM-Assistant]
      PS. I am not original developer of this module, I just help maintaining it.
      “Everything I do (here) is for free – altruism is the way!”
      Mykle1M 1 Reply Last reply
      Reply Quote 3
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @E3V3A
        @E3V3A
        I’m sure you just made a lot of people happy. Well done, sir. :-)
        E 1 Reply Last reply
        • E
          E3V3A @Mykle1
          @Mykle1 Thank you! Not sure there will be that many… But now I can focus to also add Alexa!
          D Mykle1M 2 Replies Last reply
          Reply Quote 3
            Damian @E3V3A
            Thanks very much for your work on this, and will, along with many others, really look forward to seeing Alexa actually working on my Mirror.
            Thanks again.
            • Mykle1M
              @E3V3A said in MMM-Assistant (updated) -- Your voice to the world!:
              You are welcome, sir. Oh, I think there will be more and more once the word gets out. And once you’ve integrated Alexa, you’ll be famous. :-)
              D 1 Reply Last reply
                Damian @Mykle1
                @Mykle1 said
                @E3V3A
                I’m unsure if @E3V3A knows the grief and suffering so many have endured trying to install Alexa, by the book, word by word, and failed to get it to work, and/or it failed to work shortly afterwards?
                So yeah, I’m sure there are quite a lot of people who would agree that @E3V3A Will be famous ;-)
                • drftgD
                  drftg
                  @E3V3A Wow, thank you for contributing!
                  I installed a fresh copy using the instructions. Not all instructions are completely up-to-date at the moment but I think I found where everything is located. Keys and such now go into the assets folder and I found a google-auth.js in the scripts folder. Unfortunately when i run
                  node google-auth.js
                  it reports the following error:
                  /home/pi/MagicMirror/modules/MMM-Assistant/node_modules/google-assistant/components/auth.js:18
                  throw new Error(‘Missing “keyFilePath” from config (should be where your JSON file is)’);
                  The same error is given when running google-auth2.js
                  Any ideas how I should proceed?
                  v9.10.1
                  5.8.0
                  Linux MagicMirror 4.14.30-v7+ #1102 SMP Mon Mar 26 16:45:49 BST 2018 armv7l GNU/Linux
                  No LSB modules are available.
                  Distributor ID: Raspbian
                  Description: Raspbian GNU/Linux 9.4 (stretch)
                  Release: 9.4
                  Codename: stretch
                  E 2 Replies Last reply
                  • E
                    E3V3A @drftg
                    @drftg Hi! Did you clone that in the last 20 hours? I made a lot of changes the last few days…
                    I still did not test that script since my changes. You’re the one now!
                    Please post:
                    • the content of script file
                    • the MM config (with only your MMM-Assistant part)
                    • the output of ls -al ./assets (from this module directory)
                    • E
                      E3V3A @drftg
                      @drftg
                      Try this:
                      cd ./assets
                      # check if you already have an access token file (google-access-tokens.json)?
                      ls -al
                      # if YES, then try:
                      chmod 666 google-access-tokens.json
                      cd ../scripts
                      node google-auth.js
                      # if not OK, then try:
                      cd ..
                      node ./scripts/google-auth.js
                      # if not OK, then try to edit the script file, and remove one "dot" from the locations to:
                      # "./assets/google-access-tokens.json" and try to run again from base module location.
                      # if not OK, IDK and we try something else
                      drftgD A 2 Replies Last reply
                        Medo
                        Can this module be worked with by NOT using Google functionallity?
                        I just want to control my mirror modules…
                        • drftgD
                          drftg @E3V3A
                          @drftg
                          Try this:
                          cd ./assets
                          ls -al
                          # if YES, then try:
                          cd ../scripts
                          node google-auth.js
                          cd ..
                          @E3V3A Thank you. I already tried a lot of those changes. Running the old script, supplying absolute paths, placing files in different folders, naming them differently, etcetera. Possibly something changed in the node module google-assistant? … I will test more later, maybe start from scratch again
                          • ChrisC
                            Chris
                            I have also tried to reinstall this module since its update but I also failed to make it work. I will wait until the wiki is updated because I did not understand the entire installation process.
                            I have the impression that elements of the old installation procedure and the new one have mixed up and it is not very clear.
                            Anyway, thanks for the work done by E3V3A to make this module work.
                            • A
                              aelmiri @E3V3A
                              @E3V3A Hi!
                              Finished my magic mirror last week.
                              Been struggling for a week and I am getting the same error:
                              node google-auth.js
                              only file in assets is: config.txt
                              We will be very thankfull if the wiki installation instruction get an update too.
                              Thanks for your great support. You are making many people happy.
                              • drftgD
                                drftg
                                Found a solution. In google-auth.js change
                                const config = {
                                  auth: {
                                    keyFilePath: path.resolve(__dirname,     '../assets/google-client-secret.json'), // secret.json
                                    savedTokensPath: path.resolve(__dirname, '../assets/google-access-tokens.json'), // resources/tokens.js
                                to
                                const config = {
                                • E
                                  E3V3A @Medo
                                  @Medo said in MMM-Assistant (updated) -- Your voice to the world!:
                                  Then you use MMM-Voice with Lucy.
                                  • E
                                    E3V3A @aelmiri
                                    @aelmiri said in MMM-Assistant (updated) -- Your voice to the world!:
                                    Ok, see solution from @drftg, above.
                                    Of those files, you need to download one, one is generated from script, and another you need to create… Hmm, yes, I see the wiki doc definitely need updating… I’ll try to go through the procedure myself and update wiki after Easter.
                                    richland007R 1 Reply Last reply
                                    • G
                                      goprojojo
                                      Thnx! I will check this out when I’m back from Milano
                                      • richland007R
                                        richland007
                                        Hello all,
                                        I have a mirror that is working fantastically, with swipe, and pages modules with sonic sensors, PIR sensor, facial recognition, dht22, relays ad a bunch of modules for me and my wife all working together on the same raspberry pi 3 i also have Alexa Pi a full blown Alexa assistant that only shows on the mirror that is listening and working all of them are working just fine the Alexa pi is using a usb audio device and a mic and for camera i use a raspberry pi camera.
                                        Anyhow my question is if i install MMM-Assistant to voice control the mirror’s modules etc, will it interfere with the Alexa assistant i already got working??? Does it have anything to do with access to the usb audio device which one of the modules will have access to it first?? Or will they both be able to cooperate each respectively answering to their own call signs??
                                        Thank you
                                        It sounds like a great module
                                        Denis
                                        • richland007R
                                          richland007 @E3V3A
                                          @e3v3a
                                          Well not like anyone answered on my first post on this thread right above but my next question is…Do i absolutely have to install the Google Assistant part meaning to configure the API etc for the GA??? … all i need is the mirror voice control to hide and show the modules ?? Will the mirror-control part work without configuring the GA side??
                                          Please let me know
                                          Denis
                                            dmwilsonkc @richland007
                                            @richland007 If all you want to do is control the modules I would recommend using MMM-voice with the Hello-Lucy modifications. You may run into the same problem that I had though. Two services cannot use the same resource at the same time (microphone). In the end, I wrote a skill for Mycroft and just decided to use the open-source AI Mycroft to also control the mirror.
                                            Here’s a short video.
                                            Here’s a thread on the Mycroft forum that covers the history of how I got there.
                                            I have not used the MMM-assistant, but my guess is you will run into the same Error: Resource busy that I had with Mycroft and the MMM-voice module.
                                            I hope this post helps.
                                            Mykle1M richland007R 2 Replies Last reply
