    MMM-Assistant (updated) -- Your voice to the world!
    22 Posts 10 Posters 14.5k Views 11 Watching
      Damian @E3V3A
      @E3V3A said
      But now I can focus to also add Alexa!
      Thanks very much for your work on this, and will, along with many others, really look forward to seeing Alexa actually working on my Mirror.
      Thanks again.
        Mykle1 Project Sponsor Module Developer @E3V3A
        @E3V3A said in MMM-Assistant (updated) -- Your voice to the world!:
        Thank you! Not sure there will be that many… But now I can focus to also add Alexa!
        You are welcome, sir. Oh, I think there will be more and more once the word gets out. And once you’ve integrated Alexa, you’ll be famous. :-)
          Damian @Mykle1
          @Mykle1 said
          @E3V3A
          I’m unsure if @E3V3A knows the grief and suffering so many have endured trying to install Alexa, by the book, word by word, and failed to get it to work, and/or it failed to work shortly afterwards?
          So yeah, I’m sure there are quite a lot of people who would agree that @E3V3A Will be famous ;-)
          • drftgD Offline
            drftg
            @E3V3A Wow, thank you for contributing!
            I installed a fresh copy using the instructions. Not all instructions are completely up-to-date at the moment but I think I found where everything is located. Keys and such now go into the assets folder and I found a google-auth.js in the scripts folder. Unfortunately when i run
            node google-auth.js
            it reports the following error:
            /home/pi/MagicMirror/modules/MMM-Assistant/node_modules/google-assistant/components/auth.js:18
            throw new Error(‘Missing “keyFilePath” from config (should be where your JSON file is)’);
            The same error is given when running google-auth2.js
            Any ideas how I should proceed?
            v9.10.1
            5.8.0
            Linux MagicMirror 4.14.30-v7+ #1102 SMP Mon Mar 26 16:45:49 BST 2018 armv7l GNU/Linux
            No LSB modules are available.
            Distributor ID: Raspbian
            Description: Raspbian GNU/Linux 9.4 (stretch)
            Release: 9.4
            Codename: stretch
            E 2 Replies Last reply Reply Quote 1
            • E Offline
              E3V3A @drftg
              @drftg Hi! Did you clone that in the last 20 hours? I made a lot of changes the last few days…
              I still did not test that script since my changes. You’re the one now!
              Please post:
              • the content of script file
              • the MM config (with only your MMM-Assistant part)
              • the output of ls -al ./assets (from this module directory)
              "Everything I do (here) is for free – altruism is the way!"
              • E Offline
                E3V3A @drftg
                @drftg
                Try this:
                cd ./assets
                # check if you already have an access token file (google-access-tokens.json)?
                ls -al
                # if YES, then try:
                chmod 666 google-access-tokens.json
                cd ../scripts
                node google-auth.js
                # if not OK, then try:
                cd ..
                node ./scripts/google-auth.js
                # if not OK, then try to edit the script file, and remove one "dot" from the locations to:
                # "./assets/google-access-tokens.json" and try to run again from base module location.
                # if not OK, IDK and we try something else
                drftgD A 2 Replies Last reply Reply Quote 0
                • MedoM Offline
                  Medo
                  Can this module be worked with by NOT using Google functionallity?
                  I just want to control my mirror modules…
                  • drftgD Offline
                    drftg @E3V3A
                    @drftg
                    Try this:
                    cd ./assets
                    ls -al
                    # if YES, then try:
                    cd ../scripts
                    node google-auth.js
                    cd ..
                    @E3V3A Thank you. I already tried a lot of those changes. Running the old script, supplying absolute paths, placing files in different folders, naming them differently, etcetera. Possibly something changed in the node module google-assistant? … I will test more later, maybe start from scratch again
                    • ChrisC Offline
                      Chris
                      I have also tried to reinstall this module since its update but I also failed to make it work. I will wait until the wiki is updated because I did not understand the entire installation process.
                      I have the impression that elements of the old installation procedure and the new one have mixed up and it is not very clear.
                      Anyway, thanks for the work done by E3V3A to make this module work.
                        aelmiri @E3V3A
                        @E3V3A Hi!
                        Finished my magic mirror last week.
                        Been struggling for a week and I am getting the same error:
                        node google-auth.js
                        only file in assets is: config.txt
                        We will be very thankfull if the wiki installation instruction get an update too.
                        Thanks for your great support. You are making many people happy.
