    So ... to update MagicMirror I would ... ??
    54 Posts 12 Posters 50.0k Views 10 Watching
      chef
      cd into the magicmirror folder and run:
      sudo apt-get update
      or
      sudo apt-get upgrade
      do I then have to run npm install???
      Thanks for the help
      chef
      • N Offline
        NoNameRo @chef
        @chef
        If you want to update your MagicMirror² to the latest version, use your terminal to go to your Magic Mirror folder and type the following command:
        git pull && npm install
        If you changed nothing more than the config or the modules, this should work without any problems. Type git status to see your changes, if there are any, you can reset them with git reset --hard. After that, git pull should be possible.
          Richard238
          I’ve just applied the latest update and get a blank, black screen.
          If I kill electron, I get back to the Pi desktop, until electron auto restarts.
          Any advice on how to get MM back again, please?
          Thanks!
            Charley Module Developer
            Also my MagicMirror is a blank screen. Will not start again
            MMM-Bose-Soundtouch, MMM-Domoticz, MMM-crypto-portfolio, MMM-Fibaro, MMM-rain-forecast
              chef
              many thanks ;)
                Montanaro
                Same issue, i´ve updated and got a black screen.
                  Richard238
                  PIR disabled in config (as a precaution, elimination)
                  Pi shutdown, powered off, and restarted.
                  MM Still blank on Pi.
                  MM OK on a LAN PC, via :8080
                  Logs:
                  pi@raspberrypi:~ $ pm2 log mm
                  [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
                  /home/pi/.pm2/logs/mm-error-0.log last 15 lines:
                  0|mm       |     at exports._exceptionWithHostPort (util.js:1047:20)
                  0|mm       |     at Server.setupListenHandle [as _listen2] (net.js:1319:14)
                  0|mm       |     at listenInCluster (net.js:1367:12)
                  0|mm       |     at doListen (net.js:1493:7)
                  0|mm       |     at _combinedTickCallback (internal/process/next_tick.js:141:11)
                  0|mm       |     at process._tickCallback (internal/process/next_tick.js:180:9)
                  0|mm       |     at Function.Module.runMain (module.js:607:11)
                  0|mm       |     at startup (bootstrap_node.js:167:16)
                  0|mm       |     at bootstrap_node.js:589:3
                  0|mm       |   code: 'EADDRINUSE',
                  0|mm       |   errno: 'EADDRINUSE',
                  0|mm       |   syscall: 'listen',
                  0|mm       |   address: '0.0.0.0',
                  0|mm       |   port: 8080 }
                  0|mm       | [1745:0401/150319.460996:FATAL:bus.cc(1189)] D-Bus connection was disconnected. Aborting.
                  /home/pi/.pm2/logs/mm-out-0.log last 15 lines:
                  0|mm       | You're using a full whitelist configuration to allow for all IPs
                  0|mm       | Server started ...
                  0|mm       | Connecting socket for: MMM-MyTemps
                  0|mm       | Starting module helper: MMM-MyTemps
                  0|mm       | Connecting socket for: updatenotification
                  0|mm       | Connecting socket for: calendar
                  0|mm       | Starting node helper for: calendar
                  0|mm       | Connecting socket for: newsfeed
                  0|mm       | Starting module: newsfeed
                  0|mm       | Sockets connected & modules started ...
                  0|mm       | Launching application.
                  0|mm       | Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/[###################] Interval: 300000
                  0|mm       | Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/[##############}/basic.ics - Interval: 300000
                  0|mm       | Create new news fetcher for url: http://feeds.reuters.com/reuters/UKTopNews - Interval: 120000
                  0|mm       | Create new news fetcher for url: http://feeds.skynews.com/feeds/rss/world.xml - Interval: 120000
                  • H Offline
                    Harry
                    Yep. I see I’m not the only one with a blank screen…
                    I did the git pull && npm install. It went through with only two warnings. Then after pm2 restart mm.sh I got the blank screen. I see that there is an npm-debug.log that contains some errors:
                    14 verbose stack Error: magicmirror@2.3.0 start: sh run-start.sh
                    14 verbose stack Exit status 1
                    14 verbose stack at EventEmitter. (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:255:16)
                    14 verbose stack at emitTwo (events.js:106:13)
                    14 verbose stack at EventEmitter.emit (events.js:191:7)
                    14 verbose stack at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:40:14)
                    14 verbose stack at ChildProcess.emit (events.js:191:7)
                    14 verbose stack at maybeClose (internal/child_process.js:920:16)
                    14 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:230:5)
                    15 verbose pkgid magicmirror@2.3.0
                    16 verbose cwd /home/pi/MagicMirror
                    17 error Linux 4.4.43-v7+
                    18 error argv “/usr/bin/node” “/usr/bin/npm” “start”
                    19 error node v6.12.3
                    20 error npm v3.10.10
                    21 error code ELIFECYCLE
                    22 error magicmirror@2.3.0 start: sh run-start.sh
                    22 error Exit status 1
                    23 error Failed at the magicmirror@2.3.0 start script ‘sh run-start.sh’.
                    Any help would be appreciated.
                    Harry
                      I returned from a copied img from my sd card to an older version and only did
                      git pull
                      didn’t do the
                      npm install
                      at least now it works again
                        chef
                        strange I’m not seeing a black screen.
                        Perhaps an issue with the auto start script? But I’m unsure.
                        Electron was updated in this release as well.
                        • MichMichM Offline
                          MichMich
                          In most cases it’s because the port is still in use. First thing to try if it fails to start after an update: reboot the pi.
                            Richard238
                            Power off & on restores VNC, and LAN access displaying MM. (Hurrah!).
                            Pi. Electron window is black, but shows cursor.
                              Cyberwrights
                              One more for blank screen, no joy after update per the instructions. Restarted MM using pm2, then rebooted the Pi. Ran the git reset --hard command, still nothing.
                              MMM-GoogleAssistant
                              MMM-Hue
                              MMM-MyCommute
                              MMM-Formula1
                              MMM-SystemStats
                              MMM-moon-phases
                              • N Offline
                                NoNameRo
                                for me it worked without problems as follows
                                pm2 stop mm
                                then
                                and then
                                pm2 restart mm
                                maybe it works for one or the other
                                  Cyberwrights @NoNameRo
                                  @NoNameRo Intuition tells me I should have stopped the service before applying the update, but unfortunately the instructions do not…
                                  MMM-GoogleAssistant
                                  MMM-Hue
                                  MMM-MyCommute
                                  MMM-Formula1
                                  MMM-SystemStats
                                  MMM-moon-phases
                                  • N Offline
                                    NoNameRo
                                    I do not know if it is absolutely necessary to stop the service, for me it was obvious to do it
                                      chef
                                      Perhaps try stopping all instances of electron and node.
                                      Stop pm2
                                      Then try the install again.
                                      Reboot the Pi.
                                      • MichMichM Offline
                                        MichMich
                                        Could everyone state what version of node you are running? (And if it works or not).
                                        • H Offline
                                          Harry @MichMich
                                          @MichMich said in So ... to update MagicMirror I would ... ??:
                                          Mine is v6.12.3
                                          Not working…
                                            Richard238
                                            Node version = v6.9.5
