    So ... to update MagicMirror I would ... ??
    54 Posts 12 Posters 46.1k Views 10 Watching
      chef
      many thanks ;)
        Montanaro
        Same issue, i´ve updated and got a black screen.
          Richard238
          PIR disabled in config (as a precaution, elimination)
          Pi shutdown, powered off, and restarted.
          MM Still blank on Pi.
          MM OK on a LAN PC, via :8080
          Logs:
          pi@raspberrypi:~ $ pm2 log mm
          [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
          /home/pi/.pm2/logs/mm-error-0.log last 15 lines:
          0|mm       |     at exports._exceptionWithHostPort (util.js:1047:20)
          0|mm       |     at Server.setupListenHandle [as _listen2] (net.js:1319:14)
          0|mm       |     at listenInCluster (net.js:1367:12)
          0|mm       |     at doListen (net.js:1493:7)
          0|mm       |     at _combinedTickCallback (internal/process/next_tick.js:141:11)
          0|mm       |     at process._tickCallback (internal/process/next_tick.js:180:9)
          0|mm       |     at Function.Module.runMain (module.js:607:11)
          0|mm       |     at startup (bootstrap_node.js:167:16)
          0|mm       |     at bootstrap_node.js:589:3
          0|mm       |   code: 'EADDRINUSE',
          0|mm       |   errno: 'EADDRINUSE',
          0|mm       |   syscall: 'listen',
          0|mm       |   address: '0.0.0.0',
          0|mm       |   port: 8080 }
          0|mm       | [1745:0401/150319.460996:FATAL:bus.cc(1189)] D-Bus connection was disconnected. Aborting.
          /home/pi/.pm2/logs/mm-out-0.log last 15 lines:
          0|mm       | You're using a full whitelist configuration to allow for all IPs
          0|mm       | Server started ...
          0|mm       | Connecting socket for: MMM-MyTemps
          0|mm       | Starting module helper: MMM-MyTemps
          0|mm       | Connecting socket for: updatenotification
          0|mm       | Connecting socket for: calendar
          0|mm       | Starting node helper for: calendar
          0|mm       | Connecting socket for: newsfeed
          0|mm       | Starting module: newsfeed
          0|mm       | Sockets connected & modules started ...
          0|mm       | Launching application.
          0|mm       | Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/[###################] Interval: 300000
          0|mm       | Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/[##############}/basic.ics - Interval: 300000
          0|mm       | Create new news fetcher for url: http://feeds.reuters.com/reuters/UKTopNews - Interval: 120000
          0|mm       | Create new news fetcher for url: http://feeds.skynews.com/feeds/rss/world.xml - Interval: 120000
          • H Offline
            Harry
            Yep. I see I’m not the only one with a blank screen…
            I did the git pull && npm install. It went through with only two warnings. Then after pm2 restart mm.sh I got the blank screen. I see that there is an npm-debug.log that contains some errors:
            14 verbose stack Error: magicmirror@2.3.0 start: sh run-start.sh
            14 verbose stack Exit status 1
            14 verbose stack at EventEmitter. (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:255:16)
            14 verbose stack at emitTwo (events.js:106:13)
            14 verbose stack at EventEmitter.emit (events.js:191:7)
            14 verbose stack at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:40:14)
            14 verbose stack at ChildProcess.emit (events.js:191:7)
            14 verbose stack at maybeClose (internal/child_process.js:920:16)
            14 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:230:5)
            15 verbose pkgid magicmirror@2.3.0
            16 verbose cwd /home/pi/MagicMirror
            17 error Linux 4.4.43-v7+
            18 error argv “/usr/bin/node” “/usr/bin/npm” “start”
            19 error node v6.12.3
            20 error npm v3.10.10
            21 error code ELIFECYCLE
            22 error magicmirror@2.3.0 start: sh run-start.sh
            22 error Exit status 1
            23 error Failed at the magicmirror@2.3.0 start script ‘sh run-start.sh’.
            Any help would be appreciated.
            Harry
              Charley Module Developer
              I returned from a copied img from my sd card to an older version and only did
              git pull
              didn’t do the
              npm install
              at least now it works again
              MMM-Bose-Soundtouch, MMM-Domoticz, MMM-crypto-portfolio, MMM-Fibaro, MMM-rain-forecast
                chef
                strange I’m not seeing a black screen.
                Perhaps an issue with the auto start script? But I’m unsure.
                Electron was updated in this release as well.
                • MichMichM Offline
                  MichMich
                  In most cases it’s because the port is still in use. First thing to try if it fails to start after an update: reboot the pi.
                    Richard238
                    Power off & on restores VNC, and LAN access displaying MM. (Hurrah!).
                    Pi. Electron window is black, but shows cursor.
                      Cyberwrights
                      One more for blank screen, no joy after update per the instructions. Restarted MM using pm2, then rebooted the Pi. Ran the git reset --hard command, still nothing.
                      MMM-GoogleAssistant
                      MMM-Hue
                      MMM-MyCommute
                      MMM-Formula1
                      MMM-SystemStats
                      MMM-moon-phases
                      • N Offline
                        NoNameRo
                        for me it worked without problems as follows
                        pm2 stop mm
                        then
                        and then
                        pm2 restart mm
                        maybe it works for one or the other
                        • 1 / 6
