    MMM-Nixie – Nixie Tube Clock for your MagicMirror
    Scheduled Pinned Locked Moved Fun & Games
    8 Posts 6 Posters 6.8k Views 6 Watching
      Dennis27
      I really like the idea and it looks great, however as soon as I installed it and ran it on my Raspberry, the entire MM shifted to the top left hand corner… Before the picture was centred, as it should be on the monitor. Has anyone else had a similar problem? Or does anyone have an idea, on how I could fix this problem?
        doubleT Module Developer
        I’ll look into that. What position do you use the Nixie clock on? Have you checked what happens if you move it?
          Dennis27
          Thank you for your reply. I have tested the following positions: bottom, bottom_bar, lower_third, middle_third, upper_third and the result was the same for every position. The picture is still too far to the left and top, even though all the modules are working perfectly fine.
          I am using the MMM-ModuleScheduler and the MMM-Carousel with Navigation in addition to other modules, however I don’t think they are part of the problem. Restarting MM or the Raspberry Pi isn’t making a difference either. As soon as I comment out the Nixie Clock, the picture is centered again. Thank you for your help in advance!
          • N Offline
            nobita @doubleT
            @doubleT How To Change Font Style,color and size
            Thanks so much
            • V Offline
              vanhoekd 0 Module Developer
              Good looking. I would definitely use it when i wouldn’t have a real nixie clock next to it =)
