    Magic Mirror Does Not Close
    9 Posts 4 Posters 3.2k Views 3 Watching
    • lavolp3L Offline
      lavolp3 Module Developer @okg21
      @okg21 said in Magic Mirror Does Not Close:
      if I close it, it launches back in seconds.
      How do you close it?
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
        Mykle1 Project Sponsor Module Developer @lavolp3
        @lavolp3
        Sounds like you have PM2 auto-starting.
        Minimize the MM window instead of quitting and run pm2 stop mm or pm2 stop magicmirror in your terminal. This will stop MM from auto launching until a reboot.
        • O Offline
          okg21 @Mykle1
          @lavolp3 @Mykle1 I close it with pm2 stop mm but there is still one remaining.
            Mykle1 Project Sponsor Module Developer @okg21
            @okg21
            Stop that one too.
            If you have 2 instances of pm2 you can delete one.
            pm2 stop mm
            pm2 delete mm
            pm2 save
            rm ~/mm.sh
            Then check your instances again
            • lavolp3L Offline
              lavolp3 Module Developer @Mykle1
              @Mykle1 I wouldn’t delete the mm.sh. Why?
              I’d say it’s best to first check if two instances are running with
              pm2 list
              Then stop one of these or both and you’re good.
                @lavolp3 said in Magic Mirror Does Not Close:
                3 posts above
                Quote from @okg21 : “@lavolp3 @Mykle1 I close it with pm2 stop mm but there is still one remaining.”
                • bheplerB Offline
                  bhepler Module Developer
                  You can stop them all at once by entering pm2 stop all
                  • O Offline
                    okg21
                    Sory guys it’s been a long time. İ deleted pm2 but it is something different mm starts back up whenever I close it.
