[Remote-Control] Shutdown, Configure and Update your MagicMirror
@Jopyth What Happen , When Press menu “Edit config.js”,The Error show like this
How to solve it,Thnaks so much -
@nobita It is not an error, just a warning. You can use it, but make sure to make a backup of your
config.js
file first.Also new release with the long overdue french translation (which might need some improvements - I do not know, PRs are welcome if you spot anything):
[1.1.5] - 2018-05-14
Added
- French translation
Fixed
- Updated documentation to new MagicMirror version
- Fix error on updating MagicMirror
@jopyth Thank so much
very cool.
question… can you get this to work using touch screen?
like the buttons you show on the screen, control them using touch instead of mouse pointer or keyboard? -
@justjim1220 This is intended to be used from a different device (i.e. not your MagicMirror), for example, your smartphone or tablet. Maybe you could get it to work on your MagicMirror with something like the IFrame module and a touchscreen?
@jopyth I just want to thank you again for your work on this module! Your module rocks!
BTW - It doesn’t have to be a mobile/tablet, I wrote an AI skill for Mycroft that uses your MMM-Remote-Control module to pass verbal commands to the MagicMirror.
If you’d like, check out the 2 min. video here.
And here’s a link to the repo if anyone would like to check out the Python code that interacts with the MMM-Remote-Control module.
Thanks again!
Cheers! -
Hi snille,
Have you ever found a solution? I want to do something similar, but was also not able to get a module to be hidden/shown during certain times using MMM-ModuleScheduler
I tried
{notification: 'REMOTE_ACTION', schedule: '*/2 * * * MON-FRI', payload: {action: "SHOW&module=module_15_MMM-Traffic"}}, {notification: 'REMOTE_ACTION', schedule: '1-59/2 * * * MON-FRI', payload: {action: "HIDE&module=module_15_MMM-Traffic"}}
Does not make real sense, switching on a module every other minute, but would have been nice for testing…
If I use this as a GET request via HTTP,
http://My_MM_IP:8080/remote?action=HIDE&module=module_16_MMM-Traffic
it works like charm…also curl works using another Raspi sending this command to the MM
Any idea?
Thanks, Peter
Dear MM-Builders,
does someone know how to solve attached problem?
Thanks in advace :-)
Is your device listed in “whitelist”, in your config.js?
Please check forum on whitelist issues.
Hein-Jan
@jopyth in light of topic resurrection, I’m looking into creating multiple functions for my pi’s. I’m using MMM-NetworkScanner and MMM-Remote-Control. The idea is like follows:
When I leave home, my mobile goes offline from home network. I’m looking for a command to enable camera (reboot y/n) to enable another project I’d like to combine with this. (Pi Camera Notifier: https://iotbreaks.com/build-a-camera-alert-application-with-raspberrypi-3-and-iosandroid-pushbullet-app/) turning it into a security cam. The commands available in the readme of MMM-RC didnt hand me a clue for further investigations
I’d love to see these work in conjunction that’d give it a whole new dimension :)
