    MMM-voice wont register commands
    11 Posts 4 Posters 5.0k Views 4 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @shazglass
      @shazglass as the author of MMM-voice I can tell you, that my module doesn’t support a command called hide clock at all. You are probably using hello-lucy, at least that’s a mod I’m aware of which enhances the commands. You can see the command list here https://github.com/fewieden/MMM-voice#usage
      S S 2 Replies Last reply Reply Quote 1
        sdetweil @strawberry 3.141
        @strawberry-3-141 said in MMM-voice wont register commands:
        then does ‘hide modules’ only hide the ‘supported’ modules list? vs ‘all/any’?
        also, could you add some text to the description of ‘mode’ … its unclear to me the value of this , and the possible choices…
          strawberry 3.141 Project Sponsor Module Developer @sdetweil
          @sdetweil the base module hides all modules. the mode has voice and those ones https://github.com/fewieden/MMM-voice/wiki/Supported-Modules
          not sure what rules apply for modifications of my module
            shazglass @strawberry 3.141
            @strawberry-3-141 oh my gosh!! I feel so stupid!! Yes, the first MM my son did was with Hello Lucy, we thought we deleted it, clearly not! and the new MM we just put MMM-voice! if you saw the two of use shouting at the mic and with a couple swear words you would find this very funny! Sorry for taking up your time!!!
              sorry, that description of mode doesn’t help… what does MODE mean? that you can supply words via voice or text strings, or ??? but its not used?
              ok, on my installation, ‘hide modules’ doesn’t do anything…
                @sdetweil the original idea was that every supported module has it’s on mode, so modules can have the same commands without conflicts. And then you enter the mode and you can use commands of that module as long as you dont change the mode.
                To change the mode you need to say the name of the mode as the first thing in your sentence, only the keyword can be before if necessery. Otherwise it will not detect a change mode
                  ok, so mode is really ‘context’ so you could speak to a single module
                    @sdetweil yes in the original version of MMM-voice
